I can't setup channels for Magnavox tv/vcr.
I inheirited a 1991 magnavox tv/vcr combo with no owner manuel. It works but I can't setup tv channels. The model is CRMO91AT01 and serial number is 83010910. There is a remote which works. Any ideas as to how I setup the channels or where I can get a manuel will be appreciated.
ladywinn
  • 5138 Answers
SOURCE: Magnavox MWD2205 Region Codes!
there is no code.
Posted on Jan 27, 2008
STR8JCKTED
  • 42 Answers
SOURCE: Model Magnavox DV200MW8 DVD/VCR Combo
try www.videohelp.com then type in dvd hacks there are various sites to go through.you can use search engines to your advantage.
good day
kz
Posted on Feb 27, 2008
SOURCE: MAGNAVOX DVD/VCR/TV COMBO/MODEL NUMBER------ MWC24T5B
The DVD won't play,keeps on ejecting
Posted on Mar 27, 2009
SOURCE: i need a code to program a phillips universal
code is 0247
Posted on Jun 05, 2009
SOURCE: Magnavox TV/DVD/VCR combo keeps turning off
So after calling a tv repair guy and listening to him tell me about how it is probably something to do with the transistor and it will cost me about 150 dollars to fix ( which I could buy a new tv for that price since it is only a 19 inch) I decided to look online at this issue of turning off after 5-10 seconds. I read about it being an issue with the VCR sensor, so I don't know about it being some LED that you have to replace because I just messed around with a VHS and moving the little white bar thingy on the right just inside the door for the VHS around a bit, and Voila it started working right again. I think maybe my son tripped something by sticking things in there and whatever I touched fixed it. So my advice is to just stick a VHS in and take it back out a few times and play with a few things inside and to the right. It didn't take long for it to work for me.
Posted on Feb 18, 2010
I need the codes for a magnavox tv. dvd combo.
Hello
Codes for Philips Magnavox TV/DVD combo are: 0456 [0189 0458]
Where the code is listed as [**** ****]the first is for the TV and the second is for the DVD. Otherwise just the one code operates both the TV and the DVD.
Code for Magnavox TV/DVD combo is: 0456
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Ok. Thanks for using Fixya.
Apr 06, 2011 | Philips Magnavox 27MS343S 27" TV
Magnavox 20MC4304 20" TV/DVD/VCR Combo Remote:
A universal remote should solve your problem. You should be able to find one on ebay. You may even be able to find one for your particular TV on ebay as well.
Dec 03, 2017 | Magnavox NE206UD TV/VCR/DVD Combo Remote...
I have a Magnavox DVD/VCR combo that I have lost the remote to. I have bought universal remote after universal remote trying to get one that will work the DVD player or at least will setup the date and...
Universal remote does not work with Magnavox combo of dvd vcr, because no dubbing button. But magnavox has many remotes that will NB884, NB559, NB677.NB627 which also works on Sharp dvd vcr combo.
Nov 05, 2010 | Philips Magnavox Learning Universal Remote
I lost the manual to the magnavox dvd/vcr dual player so i dont know how to set it up. so i can watch dvds and vcr tapes.
The easiest way to hook up the combo is to use the cable in and out to tv connectors located in the rear. for this connection you will hgave to set the TV to Channel 3 or 4. You can usually download an owners manual from magnavox.com, you will need a model number.
Mar 19, 2010 | Philips Magnavox DVD/VCR Dual Player
My digital comcast remote will do everything except change the channel on my magnavox TV. Volume/power control is fine. How can I fix it?
your tv needs to stay on the same channel for the cable box to work with the tv and you change the channel on the cable box not directly on the tv
Jun 12, 2009 | Philips Magnavox 20MC4304 20 in....
Good luck! We are taking our unit back. We are both professionals dealing with multiple intense things, then we get home and can't figure this stupid POS out.
May 28, 2009 | Philips Magnavox MDV530R DVD VCR
Magnavox DV220mw9 won't record from Tv, hard to connect
check out this diagram, paying close attention to the audio video cable hookups.
assume the cable tv box represents the converter box
you are going to come out of the converter box audio and video outputs into the new magnavox dvd/vcr combo audio and video inputs.
Then out of the new magnavox dvd/vcr combo outputs to the inputs on the tv if it has such inputs. The TV will have to operate on the video input 1 or 2 if the tv has such a thing, use the remote for the tv to adjust the input signal to line in 1 or 2 depending on what it has.
If the tv has no coaxial input or audio video inputs then you might have to use an adapter, you can get these from radio shack.
You say it will not record from the tv, but in all actuality the dvd vcr combo is getting the signal from the converter box not the tv, do you understand what I mean here?
So the dvd vcr combo gets input from the converter box so you will have to set it to view signal from the line input you have plugged in from the converter box. line 1 or 2 or whatever the input is.
the tv will have to be set on the line input to view the signal from the dvd vcr combo.
That is as easy as I can put it. Study the diagram closely. You will see what I mean.
Mar 07, 2009 | Philips Magnavox DVD/VCR Dual Player
Channel setup for VCR recording
WHAT YOU HAVE TO DO IS GO INTO SETUP AND DO A 'CHANNEL SET' EITHER AUTOMATIC (WHICH DID NOT WORK ON MINE) OR MANUAL AND ENTER EACH AND EVERY CHANNEL YOU WANT TO RECORD. THIS IS TIME CONSUMING BUT THAT IS THE ONLY WAY IT WILL WORK - IF YOURS WORKS WITH 'AUTOMATIC' YOU GOT IT MADE
Jan 24, 2008 | Philips Magnavox DVD/VCR Dual Player
Televison & Video Logo
435 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
