Question about Behringer Ultralink WMI2000 Professional Microphone
Switcing on I've just bought secondhand one of these. It has a tiny on/off switch in the microphone which has to be held on for 2 seconds, but I've only managed to get this working once. At other times nothing happens. I'm certain the batteries are good & properly connected. Is there something I'm not doing or is there a fault?
  • 944 Answers
Here is the link to the product page on the website - there you can find the user manual and much more; http://www.behringer.com/UL2000M/index.cfm?lang=ENG check page 12 and 13 about channel selection, and page 24 has a good summary of the procedure. If you still have a problem after doing this then there is almost certainly a fault - the fact that you got it working once would indicate that the switch itself, or a connection inside the mic near the switch may be the problem. If you fancy trying to hunt this fault down yourself and want some pointers, please post again, if not it may be cheaper to get a new mic than to get it repaired professionally, but ask for a quote just to check this. Hope this helps :)
Posted on Apr 03, 2007
Hi i have just bought a brand new but second hand
Your brand new secondhand USX-800 may be no good. From your description it seems you have done everything possible to get it to work
Aug 07, 2013 | Audio Players & Recorders
CAD GXL2200 stopped working.
The first thing you can try is to unscrew the base by turning counter-clockwise, holding the body and screen together carefully. Then carefully slide the main body sleeve downward, and off. The rest of the mic is held together with a frame. You will be able to inspect all the internal wiring and solder joints for poor connections or cracks, The rear PC board is held on by two tiny Philips screws. Remove them and slowly lift the back PC board - it is connected by 3 short wires. This will just allow you to inspect the PC board for bad solder joints or cracks in the metal film. If that doesn't help, you may have to start removing and testing diodes and transistors etc.
BTW, on the front board you will find a tiny lo-cut switch I'll bet you didn't know you had.
Feb 13, 2013 | CAD Microphones GXL2200 Professional...
Hi I have a vhf digitech AM-4071 wireless microphone system and the problem is that both microphones are going only through one RF, on the transmitter. The second mic goes but its not receiving on tr
You need to check that they are both operating on different channels there should be a switch or POT on the microphone and possibly one on the reciever. If they are static or preset you need to swap one for the other channel. Some (usualy cheap) mics have a preset or static channel often ch-A and ch-B, there should be one of each in the box. If you bought the extra body packs they will also come with the preset channels.
- thegorisb
Sep 07, 2012 | DIGITECH VOCALIST LIVE 2
I have bought an sE USB1000a condenser, and am pretty new to microphones. what does the ' . A P ' switch on the front do?
For what I could find, the A-P switch is the Apple/PC switch, which
should compensate for the difference in signal sensitivity between
the 2 types of computersystems.
Sep 05, 2011 | SE Electronics USB1000a Professional...
My microphone doesn't work, I can't hear any voice. Can you help me? That is R21S microphone
its probably a wire came loose, unscrew the head (airguard) then you should h ave 2 tiny screws that hold the switch in place, carefully slide it forward and as you do push the main cord for the amp plug in along with it as you push it through,, check those wires to be sure the connection hasn't come loose
Jun 12, 2011 | Samson R21S Microphone
Can you tell me the plug wiring mike end
It should be standard balanced XLR. The wiring is 1= ground/shield, 2=hot(+ve), 3=cold (-ve). Do not bridge any of the pins especially not 1 and 3 if you are using phantom power with this microphone. Let me know if this helps please.
Nov 19, 2009 | SE Electronics SE2200A Professional...
Microphone does not pick up any sound
Your mike requires a 48 volt phantom power supply which your preamp should be supplying. The most commonly overlooked problem is the cable. It must be wired for a balanced connection for phantom power to work correctly. 1=ground/shield, 2=hot(ve) and 3=cold(ve). None of these connections should be bridged to another and need to be kept separate to maintain a balanced connection. You will need to eliminate the preamp and mike cable as sources of the problem in order to determine if the mike is working correctly. You need to test this combination with a volt /ohm meter. If you don't know how to do this you should take it to the dealer you bought it from for testing or advice.
Oct 15, 2009 | M-Audio Luna Professional Microphone
Power problem on Game Boy Advance
since it's secondhand, you may want to go onto Ebay or check in with your local Game Stop and see about getting a replacement battery.
Jun 03, 2009 | Nintendo Game Boy Advance Console
CIC60 01 tumble dryer only works if on/off button is held in
is the new on/off switch new or second hand if its new get it exchange cause these switchs have a spring in them with 2 channel cutouts in them once depressed when it starts to come back up it automatically goes into another channel which keeps it on faulty switch thats all it can be if secondhand again take it back cause its faulty this is the only thing it can be they are simply made so they dont mess up try doing it when its not on the washer love peter
Nov 16, 2007 | Dryers
Behringer Ultralink WMI2000 Professional Microphone Logo
56 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Rob Beech
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
