Question about Cuisinart DLC-5 Food Processor
DLC-7 missing a piece?
The base works fine. But when I look at the white pin that depresses the button on the base, I find it is not engaged, and I do not see anything that will depress this pestle. What is the part I am missing?
Thanks
    Problem Solver:
How do you remove the top off of the motor base of my Cuiusinart DLC-7?
Posted on Apr 08, 2010
    Problem Solver:
  • 17 Answers
The workbowl has a spring-loaded assembly inside. You can see it through the plastic. When the workbowl cover is in place and locked, it depresses the button on the base. If this is not happening, then you need to determine whether the workbowl or the cover is at fault. Once you figure that out, you need to replace the faulty one. I usually get my replacement parts at GourmetDepot.com.
Posted on Dec 28, 2008
Motor base cover for dlc 7 super pro
Try buying a new motor base on eBay. It's actually quite cheap. If you are daunted by the shipping cost of this monster, you can always ask the seller to sell you just the brown bottom cover. Under each foot is a screw which attaches the molded base it to the rest of the assembly. It's a lot cheaper to just have that part sent to you. This works as long as you are handy in making the switch of the base.
May 27, 2014 | Cuisinart DLC-7SFP Pro Food Processor
I have all pieces locked into place and it will not work! I have the prep 11 plus
First thing to do is check your base to make sure it's not something wrong there. If you take everything off the base and look on top, either in the 6 or 12 o' clock position there will be a black button set into the base slightly. You want to find a ball point pen, and with the base plugged in, press and hold that button while turning on the unit.
If that works, you want to go through each piece one at a time. First w/ the work bowl, and notice there is a plastic rod w/ a spring at the bottom set into on side of the work bowl. Make sure that is lined up over the black button. Then in the cover, usually on the back of the feed tube, there is a lever within the clear plastic, that should line up over the rod in the work bowl. Finally, you must add the pusher/sleeve portion at the very last, or else it all won't engage right and it won't work. Just make sure the tabs on the large pusher are locked into the cover last, and it all engages so that the spring in the work bowl is depressed. The processor won't work until all the pieces are in the exact place and put on one at a time (I can't stress that enough because these processors are very exact when it comes to that, some kind of safety mechanism).
If all else fails, call customer service at 800-726-0190, they can walk you through those steps if I haven't been clear enough. :)
Aug 06, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart dlc-7 superpro food processor won't run.
The DLC-7 SuperPro is awesome -- very powerfull. Be aware they are 1.5 horsepower; the blade can take your hand completely off in a blink of an eye. Because of the potential danger, SAFEGUARDS are in place such that everything must be aligned and in correct position or it WILL NOT POWER-UP. So, yes, is very likely the safety switch.
Simple test: Use just the BASE, (no work bucket, no top, no blades), such that if it starts, only the spindle will turn. There is a little black button on the base, just back of the spindle. Use a chop-stick to depress it. Plug-in, press the button w/chop-stik, press the PULSE button. It should power up.
Presuming it powered up okay, the "problem" is probably in how the unit is assembled; such that the button is depressed properly.
1. The work bowl must be all the way down on the base, and the alignment column in the back, work bowl base skirt turned to the "Hard Stop". It will feel very solid when docked properly.
2. The top inserts and rotates into and snaps into position while pressing the plunger into the button.
It all sounds too easy, but if something is just a little off, the plunger doesn't plunge ind the power doesn't go on.
These are FABULOUS machines -- spend the time into getting it working. The near- equivalent if something this robust and powerful in today's products will cost nearly a THOUSAND dollars - seriously.
May 04, 2009 | Cuisinart DLC-2014 PowerPrep Plus Food...
Motor runs but switch won't activate despite new parts
Make sure the handle of the bowl is facing the front of the food processor. Place the lid tab just to the left of the handle and slide it toward the handle until it won't turn anymore. Remove the pusher sleeve from the lid and reinsert it with the lock facing the front of the food processor. Slide the lock into the locked position. If it still doesn't work, replace the third piece on the work bowl - the one piece that you haven't replaced. It will then work.
-Tha Mp3 Doctor
Jan 10, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart 7 cup food processor wont' start
Remove the work bowl completely. Turn the machine on and use a pen to depress the dark grey or black button on the base of the food processor. If the motor doesn't spin, it needs repair. If there is spinning:
Make sure the handle of the bowl is facing the front of the food processor. Place the lid tab just to the left of the handle and slide it toward the handle until it won't turn anymore. Remove the pusher sleeve from the lid and reinsert it with the lock facing the front of the food processor. Slide the lock into the locked psoition. If it still doesn't work, replace the third piece on the work bowl - the one piece that you haven't replaced. It will then work.
-Tha Mp3 Doctor
Jan 06, 2009 | Cuisinart DLC-5 Food Processor
Installing Cuisinart Sleeve/Sheath for DLC -7EMotor Shaft Cover
I have a DLC 7 pro circa 1982 - just replaced the sheath. First - remove old sheath - I found that using a plumbers pipe cutter to cut old sheath off in sections then pulling each section off with pliers works great. Make sure ALL the plastic comes off the metal shaft - as well as the brass ring portion of the sheath.
Next use a sharpie marker to mark the the "flat" side of the shealth = you must look inside the sheath, find the 2 "nubs" that form a "flat" side. These nubs must line up perfectly with the flat side of the shaft - mark the base of the shaft as well so you can more easily line up the flat of the sheath with the flat side of the shaft (and no, the flat outer sides of the the sheath do not match up with the flat inside section of the sheath - that would make life too easy!)
Press the new sheath on with your hand as far as it goes - should go down to about 1 inch from the base.
Now you need a hammer, piece of 2 x4 wood and brute strenght! (keep in mind that once you hammer it - even once - it will NOT come off) Put the 2" side of the wood against the top of the sheath - Use a LOT of force to hammer the sheath all the way down. will probably take 3 - 5 good strikes. It will take much more force than you think you should need to use. Make sure the base of shaft is as far down as possible - if it rubs against the workbowl while spinning it will fuse to the bowl! Good luck! -
Dec 02, 2008 | Cuisinart DLC-10S Pro Classic Food...
Safety-rod of bowl does not depress microswitch of Cuisinart processor
Cuisinart does not have the original pieces available, but you can order a replacement work bowl, lid, sleeve, etc that will work from the company. First do a motor test to make sure the motor is still working:
Cuisinart Food Processors – Motor Test
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
Oct 20, 2008 | Cuisinart DLC-5 Food Processor
I have a cusinart pro classic, went to use it yesterday, filled it and turned in on, got nothing. i tried a different plug and still nothing. it is not even making a sound.
It usually goes something like this, with minor variations depending on model number:
1. Remove the work bowl completely from the base
2. Plug the food processor in and turn it on
3. Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4. Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the workbowl
5. Place the lid on the workbowl with the tab slightly left of the center of the workbowl handle – slide the lid counterclockwise until it won’t slide any more
6. Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7. Slide the lock to the right into the locked position
The food processor should now work
-Tha Mp3 Doctor
Oct 19, 2008 | Cuisinart DLC-10S Pro Classic Food...
Food processor
-Tha Mp3 Doctor
Apr 20, 2008 | Cuisinart DLC-10S Pro Classic Food...
Cuisinart DLC-5 Food Processor Logo
172 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Rommel Balcita
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
