Question about JVC RX-554V Receiver
Sub Woofer Sub out not working, gives a low output volume. Is an Amp reqiured?
    New Friend:
Jvc tu avat
Posted on Oct 17, 2014
    President:
  • 3,130 Answers
Yes, this output on this receiver is at line level, (.775 MV) Or better known as 0 db level. You will need a powered subwoofer to get the bass to work. If you need an owners manual, you can get one here: http://books.jvcservice.com/download/256239653/17839.pdf Good Luck
Posted on Apr 03, 2007
On my pd3000a receiver I have two subwoofer rca jacks but I have a sub volume control so can I still hook up pqa4100 poweramp this is all pyle equipment, please give detailed answer
First, I'm not a Pyle tech. But back in the day I used to be an audio freak (1970's 4 channel all-the-way!)
* I tried to get the exact specs on your receiver but I suspect it's a non-amplified output. RCA jacks almost never have a high level output. (yes, the old 1940-60's used RCA jacks for speaker high level output. But you have a late model receiver.) Most likely you need a separate amp to power the sub woofer (unless it has it's own power amps.) You may still use another audio amplifier if you have a spare (mono or stereo won't mater as you only use one channel) but be aware that low frequency use way more power than normal frequencies (600 to 3KHz) The low end (50 to 300 Hz) will burn out any speaker and amp as the lower the frequency it's like hooking up a car battery directly to the speaker! If you have an old style vinyl record player that's playing a warped record. watch the speaker flap around to the wave of the record. Need to turn on the 50 Hz cancel out button to prevent speaker blowout!
* This link is still for a powered woofer. It looks like the same PD3000 receiver as yours though I can't be sure:
https://www.youtube.com/watch?v=OXEtib5OnGI
* This is an external "Powered" sub woofer (powered amp and additional cross over "filter" to extract just the lower frequencies. The following you tube link is a detailed example of how this type of system works:
https://www.youtube.com/watch?v=ZpSAQDjuWN0
Aloha, ukeboy57
May 11, 2018 | RCA Audio Players & Recorders
Broken connector in subwoofer connection on receiver
The only thing you do is to open your receivers,then locate the output connector if you see the female RCA jack ,then push it out the broken piece ,that's it
Jul 27, 2008 | Audio Players & Recorders
Kef kube 2 sub woofer ssems to have just gone really quiet, I have checked my setting, tried cranking up the volume on the sub woofer which does affect it but not by much, I have a yamaha RX v107 amp, My...
You need to determine if the loss of volume is connected to the output of the amp, or it's the subwoofer's fault.
If you are able to adjust the volume on the sub, that to me sounds like it could be your amp that has lost volume. If you can borrow or get another sub from somewhere, you can test it on the amp. If that is weak you know the faulty part. If it is the sub I would check the Electrolytic Capacitors as they can cause loss of volume.
Nov 01, 2017 | Audio Players & Recorders
Do you plug the sub woofer outputs to another amp?
Yes, for best results. Your subwoofer should have a seperate amplifier because it has low pass filter that produces low frequency signals. It is done by connecting the sub woofer output to the input signal of the amplifier and then connecting the output signal to the subwoofer speaker terminals. Hope this helps.
Jul 01, 2011 | Car Audio & Video
I'm not sure how to hook up a powered sub woofer to my rx4109 reciever
It doesn't have a specific low-frequency or subwoofer output.
Depending on your unnamed subwoofer we may be able to work something out. Any sub should be able to work with a full-range Line Level feed.
If you use a Line Level input you won't have volume control of the sub through the receiver.
That would be available at either Tape Out or Aux Out. Just run an RCA pair (or combined to one male out if that's what the sub amp requires).
Whichever one you use, you won't be able to activate that function for listening as it would remove the input to the sub amp.
If your sub accepts speaker level High Level inputs you could drive it with speaker outputs and yoi WOULD have some volume control, assuming the sub had a way to match its initial volume to your other speakers.
Of course, the manual for your sub might explain some of this, too.
Jan 10, 2011 | Sherwood RX-4109
How to hookup
hi,
if u want to hook up the sub with ur av receiver the connect the sub woofer output of ur AVR to any one (left or right) input of ur sub woofer. then connect its power . set the frequency range between 90 and 120Hz. set the volume of sub woofer to 40% of its total. also check the av receives speaker setting. goto speaker setup and make ON the sub woofer out.
if want to connect the sub to a stereo amp without sub out. then connect the amps speaker line to the speaker input of sub woofer and connect the speaker out of sub to left and right speaker ( make sure to connect the red to red and black to black). set the volume and frequency as above
ok
Jan 01, 2011 | Wharfedale PowerCube PC-10 Subwoofer
If i increase the sub woofer volume the voice distorts and gives a buzzing sound. it works fine on low volume
Your sub woofer is not mean for voice sound...check that you have connected the systen up properly and that you have put the sub woofer into its wn connection..if it is in the right connection the woofer could be blown.also try decrease the midrange hurts on the woofer
Jan 03, 2010 | Audio Players & Recorders
YAMAHA AV receiver RX-V861 I have the message 'Vol-fix' appearing on Zone 2 and no sound. This was working fine until then
Setting the RX-V861 remote control to operate Zone 2:
  1. Using a ballpoint pen or similar object and press the [CODE SET] button RX-V861 remote control. The[TRANSMIT INDICATOR]on the remote should flash twice.
  2. Using the [NUMERICAL KEY PAD] on the remote and key in 9992, the [TRANSMIT INDICATOR] should flash.
Assigning the receivers internal amp for Zone 2:
  1. Set the remote control selector to [AMP]. (Located to the right of the volume buttons on the Remote.).
  2. Press the [SET MENU]button on the remote control.
  3. Arrow down to Manual Setup and press the Enter button on the remote control.
  4. Arrow to the [SOUND MENU] option and press the [ENTER] button on the remote control.
  5. Arrow to Speaker Set and press the [ENTER] button on the remote control.
  6. Arrow to the EXTRA SP ASSIGN and select ZONE2
  7. Press the [RETURN] button on the remote control to exit out and return to the Manual Setup.
NOTES: There is an option for setting the Maximum Volume and Initial Volume in the Zone Set menu.
  • Max Volume: This is an optional feature but isrecommended to prevent the accidental change in volume levels thatcould damage the speakers and receiver.
  • Initial Volume: This is also a great feature that would seamlessly start the volume level for the second or third zone at the desired level.
We do not recommend using any Speaker Selector boxes to enable more than the recommended number of speakers per terminal.
Controlling Zone 2 using the RX-V861 remote control:
  1. If the Main Zone on the receiver is on, press the [POWER BUTTON]down and while holding that button down press the [PHONO]/[**] button on the remote. The [TRANSMIT INDICATOR] will light up.
  2. You will not be able to use the following buttons on the remote: (Pressing any other button will cause the remote to exit Zone 2 mode. [POWER], [STANDBY], [VOLUME], [MUTE] and the [INPUT SELECTOR] buttons [DVD], [CD], etc.)
There are the instructions as written straight from yamaha. If you need any further assistance please let me know.
Thank you,
Lee
Dec 13, 2009 | Audio Players & Recorders
Connect stereo amplifier to powered sub
You can y out from the main out to the sub.This output is post volume control. set level on sub to desired balance of lows feq to highs
Nov 20, 2009 | Yamaha YST-SW015 Subwoofer
Subwoofer to receiver hookup
In general, there are two ways to hook up your sub-woofer. First using the high level outputs from your receiver ( speaker output from the front R & L speaker terminals ) run a set of wires from the outputs to the speaker inputs on the sub-woofer, you do this in concert with the speaker wires going to the front R & L speakers which you then attach to the R & L speaker outputs on the sub woofer amp. Note that the sub woofer doesn't power your front speakers, the connections from the sub amp are just a pass through connection where the signal needed by the sub is parasitically taken from the inputs.
Second is via a low level output from your receiver / amp to the low level input on your sub amp. This is normally done via a RCA type of patch cable and connected to the sub woofer RCA jack on the rear of the source receiver or amp, Next run the patch cord to the sub amp an into the RCA jack input. IF you have a right and left input, use the Right input.
john
Aug 18, 2008 | Audio Players & Recorders
JVC RX-554V Receiver Logo
233 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
shaun taylor
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
