Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Gas stove with a electronic igniter
I just clean the top of stove with water and now the electronic igniter is going off by itself, only stops when I unplug it.
  • campman77 Dec 23, 2008
    I cleaned the stovetop with water and now the electric igniter will not stop unless I unpkug it. How do I solve this
  • murillorober Apr 01, 2009
    I have a Jenn Air range and while cleaning around the knobs with a wet sponge one of the burners did a small explosion and now the electronic igniter of that burner does not work; however I can light up the burner with a an elctronic flame used for gas burners. Can you help me?
    Thanks, Robert
    Scholar:
  • 111 Answers
You got things wet that don't like to be wet. Once it drys out it should work fine
Posted on Dec 20, 2008
Gas stove tops: After 3-4 minutes of the gas being on for one or more burners, all of the ignitors keep on attempting to spark. They keep going even after the gas has been turned off and stop after 5 or...
Hi abbilou_78,
I believe your ignition switches have come in to contact with either water or moisture.
Please read my below Tip on how to fix the problem:
GAS KITCHEN APPLIANCE CLICKING SOUND...
If it does not solve your problem, I'd suggest replacing the ignition switches.
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 30, 2011 | Whirlpool Cooktops
Electronic ignitors won't stop clicking
Pull the burner caps, etc off the stove and completely dry the area ..Be sure to inspect each ignitor contact for cleanliness as well. If the ignitors have soapy buildup or water, around them, they can act like this.
You should be able to pull the burner caps and flame diffusers off and clean with a paper towel, and if needed, a light scouring sponge. Be careful not to scratch the surfaces, but scour the top of the ignitors carefully if you need to clean them.
Jul 31, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Right side stove top igniters dont fire off of right side knobs+
clean the pilot jets out sonds as if they are clogged. if the right side is only being lit once the left side is on then you better not run the right until you do get it fixed as more than likely whats happening is the enough gas is traveling through the chamber to be ignited by the left sides flame and that can be dangerous, however your stove uses an electronic lighter all you need to do is clean the contact points so that they will spark cleanly if it still won't light you need a repairman.
Dec 07, 2009 | Ovens
I have two burners that don't ignite
FIRST MAKE SURE YOU TURN OFF THE GAS AT THE MAINS , THEN REMOVE THE ALL BUNERS AND GIVE THE TOP PORTION A GOOD CLEAN WITH WARM SOAPY WATER TO EXPOSE THE SCREWS WHEN LOCATED REMOVE THEM AND THE TOP THEN YOU NEED TO FIND THE IGNITE WIRE FOLLOW IT TO ITS SOURCE CHECKING FOR ANY BREAKS AND ALSO CHECK CONNECTIONS . GOOD LUCK .
Nov 17, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Pilot on GE stove keeps popping non-stop
As far a "popping" do you mean the igniter on the cook top "clicking"? Did you clean the range and use too much water? If water gets into the igniter switches they will short out and constantly click. Also if the polarity at the electrical plug you can get what is called "ghost spark" so make sure that the polarity is correct at the electrical outlet. Each gas control valve has a switch that turns on the igniter when the knob is in a certain position and they are all wired in a sequence. One of those switches may be shorted out or have a loose wire(range dis-assembly required to inspect). Do you visually see a spark at the electrodes of the burners or do the burners ignite? If you cannot see the spark then there may be a grounding issue and possible loose wire.
Sep 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Stove top ignition doesn't stop ticking
My Dacor cooktop had a similar problem of continuously clicking igniters. I unplugged it a couple months ago and used a piezoelectric igniter to get it started. Then I looked in the Dacor FAQ and it said to clean the ceramic igniter posts with alcohol not water. I had to scrape some gunk off a couple of the posts with a knife before cleaning with alcohol. Now it works.'
I think the igniters use electrical conductivity to detect when they need to spark, so even slight invisible contamination on the igniter insulator can confuse the sensing system. Also they all seem to fire as a group, so all of them need to be clean because if any one of them is dirty then they will all malfunction.
Mar 22, 2009 | Creda Colonial 42352 23 in. Electric...
GE profile gas stove igniter don't stop igniting
take a look at the igniter located in the center of two burners. clean the gap with a stiff brush between the eletrode and the upper plate. the distance is preset at the factory. you may have enough buildup to close the gap enough to trigger the igniter.
Oct 23, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
314 people viewed this question
Top Kitchen Ranges Experts
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
