Question about Canon PIXMA iP4300 InkJet Photo Printer
IP4300 lines uneven
My IP4300 canon printer prints half of the line one direction and the other half of the line the other direction. They don't match up. It is not every line, just random lines. On pictures it has one block one direction and the next block the other direction. I have aligned it both automatically and manually multiple times. I have cleaned the print heads also. Canon tech support said it might be the encoder. Is this something I can fix on my own?
    Problem Solver:
  • 16 Answers
Reload the driver
Posted on Dec 31, 2008
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Computer skipping lines when printing
possible defective cartridges, car printing
Nov 04, 2017 | Canon PIXMA iP4300 InkJet Photo Printer
My ip4300 keeps printing the same page over and over again. There's nothing in the print Q, but no matter what new job I send to the printer it prints the same old page. Is there a way to reset the printer...
Have you rebooted your computer? The printer's memory is very limited -- certainly not enough to hold an entire page. Your computer feeds the printer a line at a time, so it would seem that your computer's print spooler is 'stuck' on that print job. Try shutting the computer down completely, then restarting and see if that print job clears out.
Mar 24, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Prints a page and random lines have a line running across
I had a problem similar to this where it would print 7/16" horizontal band blank and then a 7/16" horizontal band correctly. This problem occured systematically when printing text.
Called Canon support after a great deal of searching around on the web and they shipped me a new printhead. Problem solved.
If your printer is anywhere near a year or less old call them up and explain the problem. They were very helpful.
Dec 01, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Lines on a photo when printed
The print quality usually depends on the program you're using to print them on your pc.
Your camera only ever sends photos to your printer, so the best settings are already selected by the camera and it's built-in photo program.
Your printer doesn't 'know' whether your printing a document or a photo, so the settings for each program on your computer are basic (known as default settings), and need to be changed by you to get the best from your printer
Find the settings that let you alter the printers options (in Word, it's FILE \ PRINT \ PROPERTIES), and make sure the printer output is set to maximum quality, and that photo paper is selected as the paper type.
Some options such as 'maximum quality' only appear when you've chosen 'photo paper', and some printers (such as the ip4300) have seperate options for gloss or matte paper, so go through all of them until you see what you need.
Hope that helps :)
Oct 06, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
IP 4300 Canon Printer printing horisontal gray lines
To solve this problema, proceed with LF correction procedure, which is well documented on Canon IP4300 simplified service manual (it can be found at Emule network). This procedure prints some patterns and the user has to choose the best among them. One of them will probably enough to compensate (or, at least, to minimize the problem to the point that naked eyes can't observe it) the line feeding error which causes dark horizontal lines along the printer lifetime (probably because of feed roller wearing).
Jan 22, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Canon iP4300 - ink tanks not recognised
Buy HP instead Canon :) This is the only solution..
Oct 05, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Canon PIXMA  iP4300 InkJet Photo Printer Logo
310 people viewed this question
Clive
Clive
old marine
old marine
