Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Dryer won't start, but all indicators on front look like it did
I can push any of the buttons to "jeans", "normal", "casual" etc. It displays proper time and other indicators...but when I press Start, it clicks and does not start...
  • 84 Answers
Check it is not set to time delay start , if not you may have an electronic module fault
Posted on Jan 29, 2009
Whirlpool electric dryer will not start when start knob is pushed
First check beaker flip it off than back on next check the door switch if tab missing or loose it should spring back when pressed next the dryer may have over heated the thermal fuse may have blown
Nov 03, 2015 | Whirlpool LER4634J Electric Dryer
Dryer won't start
If you look closely, there are 3 separate pins that must latch. One is a simple push-button style which latches no problem.
The others are little prongs at the top and bottom of door. The bottom prong latches cleanly, but the top one will not latch because the door is a bit too flexible.
Close the door normally, then firmly press on the top edge of the door. You will hear the final latch grab, then you press and hold the start button. The dryer starts normally.
Oct 21, 2012 | Whirlpool GEW9250 Electric Dryer
LG Gas Dryer (dlg0452w) needs a push to get going
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 19, 2010 | LG DLG0452W Gas Dryer
I have a ggw9868 gas dryer it works fine but it beeps at all times... i use the test diagnostic and casual led constantly flashes and also beeps. when it finish a cycle after a few minutes display goes on...
The display board with the buttons, or user interface has a stuck keypad on it. Sounds like the casual button is the culprit. The dryer thinks you are constantly pushing the key that is stuck and is beeping and starting itself up. I tried looking up the part number for you but it looks like the model should be ggw9868 and then K then L,Q, or T and then a number. You will also need the color for the part lookup. The part is called Panel, Console (includes key switch). This replaces the whole front panel assembly and should take care of your problem.
Please rate this post. Thank You
Jan 21, 2010 | Dryers
Whirlpool GGW9250PW Automatic Cycle not working
We are sorry to hear of the problem with your Whirlpool dryer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Reviews@Whirlpool.com with your name, phone number, address and the model and serial number for your refrigerator.
Apr 04, 2017 | Whirlpool GGW9250PL Gas Dryer
Dryer displays PF when start button is pushed
might want to have a electrician check to make sure its not dropping neutral
Aug 29, 2008 | Kenmore Elite 45986 Front Load Washer
3 beeps mean what
If the only thing that happens is three rapid beeps when you select a feature from the console this is usually a symptom of a defective door switch.  The door switch must be closed to complete the circuit from the timer to the heating circuit and drive motor.  If the switch is bad, or the wiring is broken, the dryer will not run.
Oct 17, 2007 | Kenmore 62062 Electric Dryer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
43 people viewed this question
Sal De
fordexpert
Robert Rankin
