Clothes esp sheets and towels ball up in my new LG Tromm washer
I just splurged on new LG Tromm washer and dryer and I'm having a problem with both which I didn't ahve with my old front loader Frigidaire washer and dryer. The clothes ball up inside very tightly in both washer and dryer, and I have to stop the dryer to straighten them out several times during the cycle. The price I paid for these monsters makes me really #($)*(#-off when I have this problem whcih I didn't have with my old trusty ones! Dryer balls (2 of them) don't seem to help. Any thoughts?
SOURCE: Spin Cycle doesn't work on our GE Energy Star frontloader, please help
You may have to remove the lower panel and clean the drain pump filter. Easy job, once the panel is removed the filter will be right in front. Get a bucket and unscrew the filter cover (3 very small screws at the bottom of the front panel) and you should find a ton of lint and stuff in there. This model has a pressure switch that detects if there is water in the tub. If so it will do this pause and slow spin. Once the pump filter is clean you should be good again. It worked for me.
Posted on Apr 13, 2008
  • 530 Answers
SOURCE: clothes and sheets come out wrinkled and twisted
Try not to wash large items with small items the large items like sheet will twist around the small item. causeing twisting and wrinkling. Also If you are overloading the clothes or underloading the clothes they will come out wrinkled. I would try to do some testing wash a load of only towels then wash a load of only t-shirts and other light weight items that you may have. Then do just a load of your jeans. What happens? Please let me know
Posted on Jan 11, 2009
  • 240 Answers
SOURCE: Whirpool Cabio washer knots clothes/sheets into tight balls
whirlpool had a service bulletin on this. New agitator design. replace with new design.
Posted on Mar 14, 2009
  • 330 Answers
SOURCE: Our LG Tromm front loader
the draiin pump is blocked or failed & needs to be replaced.
Posted on Jan 11, 2011
  • 6277 Answers
SOURCE: samsung dryer makes loud noise; just started
'purchased approx. 2 yrs ago. always had trouble'?
Even whilst under guarantee/warantee?
I need to explain our situation.The washing machine forum is just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing mostly mechanical and electrical/electronic problems and giving guidance on these for free on the web. In addition the members are not 'affiliated' to, or representative of, any manufacturer of washing machines or detergents whatsoever so we have to be carefull what we say;-0)
Sorry but all I can suggest is that you call your local Samsung service agent to see if it can cure your problems. You do not want to go to the expense of purchasing a different washer!
If this has clarified the situation for you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Oct 31, 2011
LG Tromm Washing Machine no power unless I unplug it and reset it.
See if you can lift the top of the washer by unscrewing it from the back and you should find a code and test sheet in there. Very easy to follow and run the test.
Jan 02, 2016 | LG Washing Machines
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
I have exactly the same problem!
Try using the tub clean cycle and use a good dose of bleach or vinegear. Here is how to run the tub clean cycle.
To start the TUB CLEAN cycle:
1. Remove any clothing or items from the washer and close the door.
2. Open the dispenser drawer and add liquid chlorine bleach to the bleach compartment.
NOTE: Do not add any detergent to the detergent compartments. Excessive suds may be produced and leak
from the washer.
3. Close the dispenser drawer slowly.
4. Power On and then press the Extra Rinse button for 3 seconds. (Prewash option will be selected.)
5. Press the Start/Pause button to start.
6. After the cycle is complete, leave the door open to dry around the washer door opening, door seal and
door glass.
Jul 11, 2009 | LG WM2688HWM TROMM SteamWasher
Mar 14, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
LG Tromm Washer
Wash empry with detergent and double bleach with extra hot water. When cycle is complete open the door to the washer and let airdry. When you close the door with it wet it becomes a breeding ground for bacteria. You may also not be using the correct detergent or the correct amount of detergent.
Jan 28, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Clothes smell......
The following are the methods you can avoid odor in clothes after washing.
  • Check that the drain line is clear
  • Check the drain hose for kinks or blockages
  • Check pump for blockages
  • Check for build up of soap in the outer tub
Good luck.Please do post comments if the problem is still not solved or if there are any doubts in this post.
Jan 20, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Clothes and sheets come out wrinkled and twisted
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Towels smell burnt after washing.
Are you sure the burnt smell is coming from the washer and not from the dryer? If you've placed a rubber backed rug or other similar article of clothing, it is not uncommon for that rubber backing to melt and get embedded in the heated duct of the dryer . Not sure this helps but if you can clarify the point at which the burnt smell is first observed that would help..
Thanks
Aug 31, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
139 people viewed this question
Top Washing Machines Experts
