Question about Hotpoint WMA58 Front Load Washer
Cleaning the machine. pipe???
Hi there My washing machine obviously keeps on getting blocked somewhere because my washing comes out very smelly. I have lost my manual. Am I supposed to clean some part of it. I can see no simple area. Do I have to remove the back, because that seems to be a bit over the top. Please help. Many thanks. Ian
  • Ian Noble Apr 03, 2007
    Many thanks for your help. Problem sorted. What an excellent website!!!!
    Thanks
    Ian
  • Anonymous Dec 31, 2007
    From clogging of the filter the pump burned out. The engineer said if you regularly wash dog bedding or anything very hairy/fluffy you should clean out the filter but it isn't very accessible.
    President:
  • 1,462 Answers
Are you using liquid detergent? this has the effect when used for long periods of making the machine smell like drains. if so, put on a boil wash with no clothes and revert to powder detergent. there is a filter which needs clearing if drain is slow.to access, remove bottom panel at back. filter is located in large pipe leading from tub to pump on the lhs. undo this pipe at the tub end and the filter is inside. some water will come out so be prepared. unplug from mains first
Posted on Apr 03, 2007
Hi when kitchen sink drains water is coming out of the back off washing mashine on to kitchen floor whats wrong
You have a clog in the drain somewhere after these two join the main drain pipe.
Dec 13, 2017 | Dishwashers
Cleaning screen
take the filter out of the bottom of the dishwasher and clean them.make sure that the pipes arent blocked,you can do this with a wire coat hanger,but carefully.then reassemble and get a dishwaher cleaing product and run it through the machine
Jun 23, 2012 | Washing Machines
Smelly cloths and on the fast wash did not rinse well
check the drain pump motor. if partially blocked it will restrict the outlet. Open the thumbwheel and remove the lint. Chech the 2 pipes for any blockages
Aug 21, 2010 | Electrolux AWF1220 Front Load Washer
Smells like old smelly socks
this might be coming from the rubber door seal clean it all the way round make sure holes at bottom are not blocked and the rubber door seal is all clean. also clean the draw so there is no power left in there and it is all clean. also a good thing to do is run it though a cleaning cycle with normal detergent at max temperature that the machine can do. hope this helps.
May 20, 2010 | Creda IWD12 Front Load Washer / Dryer
Whirlpool frontend washer smelly cloths...need
I have this problem with my Siemens machine, it is due to mainly running low temp washes and bateria building up in the hoses etc. (more prevalent if the machine is connected directly to the sink and not on a stand pipe). I run a 90 degree cycle every 4 weeks with the machine empty except for two capfuls of baby sterilisng fluid (approx half a mug) I buy stores own as it is cheaper than miltons. The first time I did mine I ran the cycle twice to be sure it was cleared out. My machine is six years old and the first smelly signs were when it was about a year old, I run the maintenance wash religiously ever 4 weeks and run a machine descaler such as oust thru every 4-6 months. Hope this helps. Roni. (ps don't be tempted to use bleach as it foams up and can cause more problems!!)
May 11, 2010 | LG WM2688HWM TROMM SteamWasher
Dirty smelly front loading washing machine
you need to find and clean the water return filter
Oct 11, 2009 | Washing Machines
Smells coming from machine, leaving washed item's smelly
Get whirlpools new affresh washer tablets. They clean the inside off the machine and kills mold ect. and if used regularly it keeps your washer smelling fresh. They are designed for front load machines but work great in top loaders too. They are available on line at any parts store and are around 8 bucks.
Nov 21, 2008 | Hotpoint Washing Machines
SMELLY WASHING MACHINE
A mouldy smell is often a sign of trapped residual water stagnating somewhere in the machine often just inside the door seal at the low point or in the filter.
Providing there is nothing like a old sock trapped in the pump or filter then there is not much you can do other than to dry the door seal and powder dispenser after use.
Please remember to rate this solution.
Oct 22, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WMA58 Front Load Washer Logo
188 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
