Question about Kenmore 75944 Gas Dryer
My kenmore dryer turns on but there is not heat. It is a gas dryer and shows model/stock no. as 76512694 76512
  • kerri71782 Jan 06, 2009
    Where is the sensor located?
    Problem Solver:
  • 3 Answers
Check your sensor
Posted on Jan 05, 2009
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
Old Kenmore Dryer can't turn-off and won't heat
Look like you need a timer control
model number should start with a 110. number timer for your dryer is about $70
Dec 05, 2013 | Kenmore Dryers
Kenmore 70 series model #97573200/stock # 75732. It's a gas dryer with an electric igniter. The problem is, dryer runs but there is no heat. I'm thinking there's a problem with the igniter? ...
if the ignitor is lighting up, the problem is going to be in the coils that are attached to the gas valve itself, heres what they look like http://www.applianceaid.com/images/2coilsgenaralgas.JPG
Jul 04, 2011 | Kenmore Dryers
Kenmore gas dryer,model 110 97220100 stock 72201 seems to function fine but does not heat I have contenuity across part no. 43
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 16, 2010 | Kenmore Dryers
Gas dryer starts blowing cold air after 5 minutes
This sounds like the dryer coils are failing. They tend to fail as they heat up. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Jun 24, 2010 | Kenmore 73932 Gas Dryer
KENMORE 80 SERIES GAS DRYER RUNS BUT DOES NOT HEAT
You have a defective gas valve solenoid. If you have an appliance repair center in you area, go to the parts dept, give them your exact model number and they should have the part you need in stock. The solenoid is easy to replace....you can do it yourself and save some money..
Good Luck,
Eric
Jul 09, 2009 | Kenmore 72802 Gas Dryer
Is gas turned on with pilot light or electronic?
No pilot. Unplug the power to the unit and it cannot run/ignite. There is a shutoff on the valve behind the front panel if you want to turn off the gas supply without moving the dryer.
Jun 28, 2009 | Kenmore Dryers
Drum turns, no heat
either the heating element or the thermal fuse very worst case would be the timer but i have all parts in stock whirlpoolpartssurplus.com
Jun 24, 2009 | Kenmore 63942 Dryer
Kenmore gas dryer that turns but does not heat up
mostly you need a thermal fuse,,take the back of ,,maybe 12 1/4 nut driver screws,,you will see a little white fuse,,replace it..onthejob
Jan 12, 2009 | Kenmore 74902 Gas Dryer
Kenmore 75944 Gas Dryer Logo
255 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
