Question about Panasonic KX TGA270S Cordless Expansion Handset
The speaker on the speaker phone does not work.
I can not use the calling feature due to no sound, I receive a dial tone and I am able to use the phone. Also, I do not hear the phone ring.
    Problem Solver:
  • 12 Answers
CHECK THE SPEAKER LINE IF ANY PROBLEM IS SEE THEN CHANGE THAT LINE
Posted on Jan 05, 2009
I have the same problem, I checked the speaker wire and they are fine.
Posted on Nov 11, 2012
Dial tone nortel phone
It\'s in system programming: feature CONFIG, Terminals & Sets, enter ext #, Prime Line: set to I/C (for intercom dial tone) or Line xxx. It is probably set to None based on your description.
Aug 26, 2014 | NorStar T7316E Corded Phone
M7310 Non-Stop Dial Tone
Intercom button/s provide dial tone when they are pressed. They are required to call other phones on your system.
Sounds like your button is stuck or issue with the motherboard.
Dec 17, 2012 | NorStar Meridian M7310 Phone
Nokia 5800 XpressMusic dial tone not coming and auto call on
My suggestion is that you upgrade your software and firmware. A good place to start is the Nokia Download Center. CLICK HERE
Jun 17, 2012 | Nokia 5800 XpressMusic Smartphone
Driverts calls
Hi, You can use this instruction to activate and de-activate Call divert .Works on all phone
Turning Call Divert On
by Touch Tone phone
Step 1 Lift the receiver and listen for the dial tone.
Step 2 Press the Divert On button if using an Optus OneTouch phone, or dial *78 from any other touch tone phone.
Step 3 Listen for three beeps followed by a continuous tone.
Step 4 Dial the telephone number to which the calls are to be diverted.
Step 5 Listen for two short beeps, confirming the diversion.
Step 6 Replace the receiver
Turning Call Divert Off
By Touch Tone phone
Step1 Lift the receiver and listen for the dial tone
Step2 Press the Divert Off button if using an Optus OneTouch phone, or dial #78 from any other touch tone phone
Step3 Listen for two short beeps to confirm removal of the diversion
Step4 Replace the receiver.
Other Call Divert Options - Selective Calls
With selective call options, you can choose which numbers you wish to divert, accept or reject by adding these numbers to a list. You can list up to 30 numbers for each call option.
Turning On or Off Selective Call Options
Step2 Press the access code for the service you require. You will hear a prompt telling you the status of the service and how many telephone numbers you have on your list. To turn the service on/off press 3.
Access codes Dial
*63 for Selective Call Divert Dial
*68 for Selective Call Accept Dial
*60 for Selective Call Reject
Step3 For Selective Call Divert you will then hear the 'divert to' number that is currently entered. If this number is correct press 1. If it is incorrect, press 0, then re-enter the phone number you wish to have your calls diverted to. When turning this feature off dial 3 again.
Step 4 The feature is now on/off.
Step 5 Replace the receiver.
Note: You can divert calls to a local, national or mobile. However, you cannot divert calls to emergency, 0055, 1900, 008, 1800, 0050, 13, 1300 or international numbers.
Hope it helped.
Thanks for using fixya...
Jan 11, 2011 | Cell Phones
TIME CHANGE
Hi!
System Time/Date can be set via admin programming or using feature code 692.
To set using the feature code:
1. Dial [692] on the dial pad. A confirmation tone will sound.
2. Enter date and time as follows: YYMMDDHHMM
When the correct number of digits are entered, a confirmation tone will sound.
3. Press the ON/OFF button (SPEAKER button on IP Phone) to OFF to update the display.
YY = Year (00-99) HH = Hour (00-23)
MM = Month (01-12) MM = Minute (00-59)
DD = Day (01-31)
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 26, 2009 | Vodavi 30-Button XTS Telephone
No tone unless speaker is used.
Have you changed the fasica? if so you may have disposed of the speaker as it sits in the old fasica
where the grill is
May 22, 2009 | Nokia Consumer Headset
Cannot receive calls and dial tone flashing
You have a feature active on your phone it's more than likely a call forward feature which would redirect you calls. The broken dial tone or stutter dial tone is an indicator a feature is active. Contact you system admin for the clear all feature code and the clear all call forwarding codes.
Feb 26, 2009 | Mitel 5220 IP Phone
My phone will not dial a call. I get a dial tone,but it won't work. I also can not get it to ring the different ring tones or do the hands free speaker phone.
You have got to be kidding. I pay $25.00 for a phone that does not work and you have the ordasity to tell me that if I pay you an additional $9.95 you will e-mail me with a possible solution to my problem. If I do not here from you within 24 hours, I am going to report this to the Better Business Bureau and my local Consumer Advocate News station!
Mar 02, 2008 | Innovage LCD Touch Panel Phone
Nec DTerm Series i - Feature Light Flashing URGENT
Thankfully I have found a solution that has worked.
A 'winking' (flashing) feature button indicates the station is in call forward - all calls mode.
To cancel this setting do the following
Lift the handset or press speaker
Dial the access code 4 + 2 (set as default)
Receive confirmation tone and restore handset or press speaker
I have found the manual at the following link to be the best resrouce ever - very easy to understand
http://www.nec.co.th/html/download/Manual/Features%20&%20Specifications.pdf
Jan 16, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Panasonic KX TGA270S Cordless Expansion Handset Logo
1,797 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
