Question about Lexmark X8350 All-In-One InkJet Printer
Lexmark X2530 won't accept re-inking of cartridges
I have re-inked cartridges for many years with great success, but it seems as if Lexmark has built in a microchip either in the printer or the cartridge refusing re-inking. Is this suspicion true and if so how can I bypass the problem? The message I get is simply: Replace cartridge/ invalid cartridge or something like that. It does not even try to print until I put in a new cartridge. I have the same issue with an aftermarket cartridge. I would like to know whether there is a way to bypass the error message.
(Just because it is aftermarket does not mean it is inferior. Guru's answer above sounds like one that was written by a printer manufacturer. The manufacturers have tried to make consumers believe their warranties would be void for using aftermarket ink. That is not true.)
  • 33 Answers
This is a trick that is used on some of the HP printers. Try this, you will need at least 3 maybe 4 cartridges. The printer stores the chip ID in memory for the last 2 or 3 cartridges installed, so, take an old cartridge number 1 and install in the printer, reset power. Next step, take old cartridge 1 out and install old cartridge 2 in, let it come to ready or tell you to replace empty, then install your refilled cartridge. You just have to remove from its memory the chip ID of the refilled cartridge. You can fool it by doing this each time you refill. Can't guarantee this will work with lexmark, but it does work with HP.
Hope this helps,
Printdoctor
Posted on Jan 04, 2009
My lexmark x3470 wont recognise compatible ink Cartridges any know of a way round this
If the ink cartridges you purchased are not Lexmark - that could be the problem. I used to have a Lexmark printer and I did the same thing - I purchased ink cartridges that were compatible but not Lexmark brand. Everything seemed fine until I tried to print and then I would get the same error sign and low ink message and it would not print. I kept thinking I was doing something else wrong and tried everything. In the end I broke down and got ink cartridges from Lexmark and that solved the problem. Now I have a Brother printer and I never buy anything other than Brother ink cartridges because I'm always afraid of that same thing happening again. I wish I knew which printers WOULD accept those non name brand ink cartridges, but thus far I do not know of any printers that do. Hope this helps you.
Mar 24, 2012 | Lexmark X3470 All-In-One InkJet Printer
Epson wont recognize black refill cartridge.
I'm assuming that you are probably using Non-Epson Ink Cartridges, because those are what normally cause that problem, with a printer not recognizing an installed ink cartridge. Unfortunately, there is no way to make your Epson Printer use or accept that Non-Epson Ink Cartridge, if it cannot actually recognize it. Its even possible that some Generic or Third-Party brands, may not always be recognized by the newer models of Epson Printers, because of the inexpensive [cheap] and or incompatable Electrical Chips that are mounted on the actual ink cartridge. Sometimes you will even get Error Messages up on your Monitors screen, telling you that you are actually using a Non-Epson Ink Cartridge, or that your printer cannot recognize the cartridge that you installed. Sometimes the Ink Level Indicator, on your Status Monitor, will not show an actual ink level, but may indicate a cartridge error or problem instead. Not all Generic or Third-Party ink & ink cartridges are made the same and none of them actually contain the right formulation of ink, for the Epson Printers [formula is patented by Epson Company]. Some are probably close and seem to be better than others, but some simply can clog-up or even damage the Printhead Assemblies on Epson Printers, or simply won't be accepted at all. Epson Ink Jet Printers are one of the few printers on the market that seem to have so many problems with non-manufactors inks, especially the newer models made in the last couple of years. Its because the Epson Printers use a completely different printhead inking system than most other brands of printers. Most, if not all of the other manufactors, use thermal or bubble jetprint heads and because the other brands use a totally different system, they don't seem to have as many problems using refilled inks or non-manufactor's ink cartridges. Printer manufacters do not make available their ink formulation and in most cases, the formulation is patented. Any difference in the ink formulation can actually cause clogging in the small printhead nozzles or damage other critical components. One individual printhead nozzle is so tiny, that it will not accept a human hair, so you can see why they can get clogged so easily, or even why the nozzles can be so easily damaged...Even if you were actually using a New-Epson Ink Cartridge, its always possible that you got a bad cartridge. At this point, the only thing I can suggest is that you try a different New-Epson Ink Cartridge, or at the very least, a different brand of Non-Epson Ink Cartridges and see if that helps.
Jun 26, 2011 | Office Equipment & Supplies
Refill lexmark 37xl ink
I own a Cartridge World ink refilling store and we do not refill the Lexmark 36 and 37. The reason is that your printer turns off the electronics on the cartridge when the ink gets low, so you can't reuse the cartridge. Your printer will only function with an electronically functioning cartridge. We NEVER recommend Lexmark printers. They are poorly made, don't accept refills a lot of the time, and across manufacturer their ink costs the most and is designed to clog the cartridge if you don't use it fast enough. We recommend HP printers that take integrated print head cartridges and Canon printers that take tank style cartridges.
Mar 01, 2010 | Lexmark X4650 InkJet Printer
I bought re-inked cartridge for Lexmark It didn't work
Yes, Lexmark has been making their new printers smarter to reject refilled cartridges. Most likely what is happening is your printer is turning off the electronics on the cartridge when it gets empty so you can't reuse that cartridge. I own a Cartridge World printer cartridge refilling store and I've even had customers return original Lexmark cartridges because their printers have rejected them. If you want to be able to refill your cartridges never buy a Lexmark printer. HP printers that use integrated print head cartridges can be refilled nicely.
Apr 13, 2009 | Lexmark JetPrinter 5000 InkJet
Refilled lexmark no.28 cartridge wont work
Fixed problem by buying new cartridge.
If any help to others I have been advised that lexmark fills the cartridges with powder and if filled with ink printer may not recognise new level. Ink may leak.
Thanks again
Mar 19, 2009 | Office Equipment & Supplies
Anyone knows where to buy a cartridge carrier?
Here is a link to the user guide for your printer:
Lexmark 3500/4500 Guide
The installation of ink cartridges begins on page 70.
Thanks for using Fixya.
A Fixya rating would be appreciated.
Feb 04, 2009 | Lexmark X5470 All-In-One InkJet Printer
Ink
They are series models. They are just the same I believe.
Jul 26, 2008 | Lexmark X2500 All-In-One Printer
Hp psc1610 all-in-one after market ink cartridge problem
The following cartridges are supported by your product
black inkjet print cartridge - HP 94
tri-color inkjet print cartridge - HP 95
tri-color inkjet print cartridge - HP 97
photo inkjet print cartridge - HP 99
May 19, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
Lexmark x2500
Try cleaning the copper plates and install back again if the same message pops up try single cartridge if the error exits with 2 cartridges ,replace the cartridge as lexmark cart has 1 year warranty..
Mar 25, 2008 | Lexmark X2500 All-In-One Printer
Yes it is true although I don't know any work arounds because modern machines are very particular about their ink.
We have such resolution and vibrant colours being deployed in microscopic "guns" that dont like foreign matter running threw them.
Manufactures these days spend vast sums of money producing expensive chips that they attach to their ink cartridges that comunicate with printer telling it it's age, usage, serial number and where it has been.
They also embed in the specialised partical size controlled ink, cleaning fluids and lubricants for the print head. They make these chips unique to their needs and hence expensive to copy, keeping competors inferior products expensive to produce
Don't scream too loud any thing is eventually hacked and as more hacked chips become available in the market so do the refills, which is great because I spend a lot of my working days, repairing their devestation.
I see the end results of recycle products in printing enviroments, most calls are related, not to normal maintence, power surges, board faults, mechanical failure, but to software problems, inferior or incorrect consumable use and restoring print quality after such items have infiltrated system with a little normal wear and tear to complete my working day.
Some times on some models you can buy after market chips, shop around have a google, but remember I'm not selling here and I don't care which way you.
Tie your own rope, save a few bucks, you will soon be in the market paying those like me, big buckas, cause you've got lines, blank prints, error codes etc, and again you will be buying new.
Where is the money that you save = it goes to purchase cost of replacing machine, my repair bills, your frustration at inferior/loss of operation and downtime.
Nov 14, 2007 | Lexmark JetPrinter 5000 InkJet
Lexmark X8350 All-In-One InkJet Printer Logo
855 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
