Question about Compaq Evo N610C Notebook
Low disk space recovery D
Zt affinity pc laptop running vista, only 1 yr old...already deleted shadow & restore points, compressed everything..worried i will regret that!! want to get rid of annoying pop up, every couple minutes, but don't want to ignore problem...i've ran out of ideas, not a computer tech by no means. any help w/b appreciated. happy holidays, and merry christmas.
  • berni wright Jan 17, 2009
    keep getting pop up about low disk space. lets me know i need to empty recycle bin ( bin empty). still getting pop up. can anyone advise a not so very technically minded person.
    Problem Solver:
  • 5 Answers
Option 1: Vista itself requiers a large amount of memmory, consider switching to a less demanding operating system like Windows XP, If you prefer the Vista look you can get themes that make Windows XP look like vista (Remember: you will need to backup files which you wish to keep).
Option 2: Insert you vista disk and follow on screen instructions to modify which vista components you want on your computer or use the add/remove windows components wizard on you computer, you may find there are parts of vista you do not require.
Option 3: Continue what you have already started.
Posted on Dec 20, 2008
Laptop C partition low disk space
1st run disk cleanup. Then compress you C-drive this will compress all your file freeing up space. Then download CCleaner and run that. Finally, run disk defrag. But you should also erase stuff you do not need.
Nov 27, 2014 | Computers & Internet
I have a Toshiba satelite laptop that runs slow and says that it is neary full. I need to free some some space but do not know what to delete. Everything on it seams to relate to microsoft.
You may have installed every softwares on your System Drive (typically C:/, where the OS is installed). Try to install them on other partitions, this will free up some spaces.
You may try with Disk Cleanup utility. To use it go to: Start> All Programs> Accessories> System Tools> Disk CleanUp. This will ask you which of the disk to be cleaned up. Select the desired System Drive Letter and click on OK. You may delete Windows Error reporting files, System error memory dump files from there. You can also delete older restore points by clicking on Clean Up System Files. Select System drive letter as before and click on more options. Under System Restore and shadow copies click clean up. This will remove all but the latest restore point.
Hope this helps, Mrityunjay
Jun 20, 2012 | Toshiba Satelite 2405-S201 Notebook
I have a dell Inspiron D530S computer with Windows Vista. I keep getting a alert that say's that I have Low disk Space on my Recovery D.How do I clean out this Recvery D program and restore it back to...
The alert is a notification that your Hard Disk(HDD) space is almost fill up. You should not remove or delete the "Recovery D Program"! , if you do not have any copy of Recovery CD, just in case of emegency if your PC/Laptop have any booting problems. Dell embedded the "Recovery D" because they do not give you any "Recovery Disk" in a CD/DVD form nowdays. On the safe side make a copy of the recovery disk.
Options you can do is to reduce you data on the HDD, by
1. You can uninstall programs you don't use.
2. Transfer your data to another external media
Alternatively you can upgrade your PC/Laptop with a bigger capacity HDD, and fresh install Windows on it.
Jul 28, 2010 | Dell Computers & Internet
How do I remove all the deleted e-mail from my pc because I got a message telling me I have used all the 20 space i am intartle
Just click the Start button and click Run (or Search if you are using Vista or Win 7). Type the command and then press the Enter key: cleanmgr
Click OK on the next screen. Windows will calculate the files it can compress and delete and will give you a list after a little time. It may take a few minutes as it says.
Select or unselect, whether you want to delete or not and press OK. Click Yes when asked.
Once again, start the cleanup manager using the above method. This time, click on More Options. You have a few more options to free up space on drive C. You can free up quite an amount of space by using the second and third cleanup buttons. Use them. use the third button first, for removing the old restore points.
After removing the unwanted or very old and unused programs and old system restore points, click on OK
Want to free some more space? Copy stuff from your Documents or My Documents folder to another drive or partition if you have (like D or E), on the hard disk. Or just move the old/unwanted stuff to a CD/DVD.
Hope that helps. Regards, Raspal
For Windows XP Driver Files and How-to Resources, visit XPDrivers.
May 02, 2010 | Acer Computers & Internet
Not enough space on friends laptop
First you need to disable system restore on the drive to reclaim the missing space. To do this, you can do the following:
1. Go to Start > Control Panel > System
2. In System > Click on System Protection at the left side
3. In the System Protection Window > go to the System Protection Tab > then uncheck C: then hit Apply then OK
After disabling system restore, run disk clean up:
1. Go to Start > Computer > Right-click on C: > Disk Cleanup - make sure to check all of the files to be deleted to clear as much space as possible
2. After initially running Disk Cleanup you will now be able to see the More Options tab in the Disk Cleanup window > go to this tab then cleanup the System Restore and Shadow Copies to remove them completely
3. Enable the System Restore from the System Protection tab in System.
4. Resize the maximum amount of Shadow Copies that can be saved on the system, this will lock the System Restore feature from saving more than allocated amount. Run Command Prompt as administrator (go to Start > Programs > Accesories > then right-click on Command Prompt then Run as Administrator)
Set the maximum to whatever amount you feel is necessary. Setting it to 1GB should be more than enough for System Restore to create at least two restore points. Type the command: vssadmin resize shadowstorage /on=c: /for=c: /maxsize=1gb
5. Once this is done you should have reclaimed at least 30 to 40% of the missing space. Once the System Restore has been reenabled it will automatically create the restore points so there will be no need to manually create one.
Mar 22, 2010 | Compaq Presario Notebook
Keep getting a box coming up in the bottom right hand saying low disk space saying you are running out of space on my disk
delete the temp files and other system restore points... right click on c or d and go to properties... and disk cleanup
Jan 28, 2010 | Acer Aspire One PC Notebook
My laptop has been using lots of room lately, and its vista. PLus i tried lots of techniques, cc cleaner, and avg, and stuff. I had 300 gb, yesterday it went down to 240 now its 231! Help!
1. Run 'Disk Clean Up' on all drives.
2. Goto My Computer -> Select any Drive (C: ,D: or E:)
3. Right-Click the drive and open Properties.
4. Click on Disk Clean up.
5. It will ask permission. Click on "Files from All Users on this Computer".
6. A window will open. Click on 'More Options' .
7. Click on 'Clean up' button under 'System Restore and Shadow Copies' option (its the 2nd option).
8. It will ask for comfirmation. Click on Delete and OK.
9. It will delete all the restore points, except the last one.
10. Now you can check the free disk space!
if it helps tell me...tc! :)
Nov 22, 2009 | Toshiba Satellite A135-S2276 Notebook
Deleting updates, freeing space on hard drive
if you are running windows vista, this might help alot, if running xp, it might not, go disk clean up for drive c. to do this, open up my computer, and right click on drive c, and open up properties. click on disk clean up, and a window should show up. if you are running windows vista, its going to ask if from current user, or all users, click all users. after the calculating window, a window that says disk clean up for drive c will show up. click on the tab at the top of that window that says more options, and on the bottom box, which should say system restore and shadow copies, click the clean up button. the longer it takes, the more space its freeing up. Goodluck
Jul 07, 2009 | Dell Inspiron 1525 Laptop Midnight Blue
Deleted Vista Recovery Partition. Now XP installer can't read HDD
if you have created recovery disk before the deleting of the recovery partition u can format the drive from your bios and create a new recovery partition using the recovery disk if not if your pc has crashed and your recovery partition is gone u will have to get a new operating system software but if your pc is still stable just run the recovery manager and restore to factory settings and it will put recover partition back on your hard disk
Feb 04, 2009 | Computers & Internet
Need to help to clean my recovery H disk is coming almost full.
A hard drive is usually partitoned, one hard drive will show up as two. The recovery drive should not be messed with. Don't add files , nor delete files from that drive.
Jan 17, 2009 | E-Machines eMachines Desktop PC
Compaq Evo N610C Notebook Logo
104 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
