Question about Xerox Office Equipment & Supplies
I have a Xerox 15i. On every sheet I print, the machine leaves a small mark/tear (1mm)on the top. Approximately 1 and 1/2 inches from the side of the sheet.
  • 2,072 Answers
I would suspect that one of the fiser fingers has lost a spring or it is out of position.
Going form paper tray to exit, I also would look on the right side, just where the paper comes out of the paper feeder, there are some clear mylar ( plastic ) guides, inspect them for damage.
Lastly right where the paper feeds out, there are some small rommers that can pop out and cause a nick in the paper.
But more than anything I suspect a fuser finger, or even the roller baing bad.
The fuser is located inside the right door, on top. It is VERY HOT, you can remove it with the 4 silver phillips screws and inspect it.
If you need parts, google a business called " the parts drop". Give them a call, ask for Britt and they will have what you need...
Posted on Dec 23, 2008
  • Rick Kasper Dec 23, 2008
    Sorry, I just reread my post. I meant FUSER finger, not fiser. TYPO, my appology.
Xerox 3250 printer
The transparency should have a white peel off strip! Without that the machine doesn't know it feed paper. Some transparency paper will have a backing sheet you peel off after printing. Check Staples for correct type.
This should be the edge that feeds first and should be on the on the non print side. if your not sure which side is printed on (face up / face down) open tray and draw an X on the top sheet.
then print anything and see if it prints over the X. If not then put peel off strip on the side (face up / face down) not printed on .
Oct 02, 2016 | Xerox Phaser 3250D Laser - Monochrome...
Dark band the length of the right side of the printed page
Hello sir; I suggest you go to replace a new cartridge, see what's happen.
Apr 07, 2009 | HP LaserJet 1020 Printer
Xerox WorkCentre PE120i - Paper Jam 1
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 05, 2009 | Xerox WorkCenter PE120i All-In-One Laser...
Repeating defects appearing on every 3rd page
That most likely is on the transfer belt assembly, You can look at that belt and see if the defect is a mark that may be cleanable or actual damage to the transfer belt, which would require replacing the transfer belt.
Jun 02, 2008 | Xerox Phaser 6200DP Laser Printer
Xerox Phaser 7400 printing
Reinstall the latest print drivers. This issue has been resolved previously
Apr 22, 2008 | Xerox Phaser 7400/DXF Laser Printer
Printing a booklet on WorkCentre 7345 , need help argent !!!
OK, same problem, I've gotten through the solution. I can print and have the first page and last page on one side of the large sheet and the two inside pages on the other side, so that is foldable into a booklet.
I start with a 4 page (US letter sized) document I wish to print as a booklet on tabloid paper.
In the (page layout or editing program's) print dialogue, I've said print all pages, set it at 1 page per sheet, then clicked the printer properties button to open the Xerox Workcenter 7345PS option dialogue.
In the Xerox dialog on the "Paper/Output" tab, selected the larger (Tabloid, 11x17" in my case) paper size, selected 2-Sided Print. Then I select the "Layout/Watermark" tab and clicked the Booklet Layout radio button, chose "Landscape" for the Page Layout Option. Note: I saved these settings as "Tabloid Booklet" by clicking the down-arrow to the right of "Driver Defaults" so that I could select them and not have to dial in every one of the settings whilst experimenting.
Apr 11, 2008 | Xerox Office Equipment & Supplies
Repetative mark along right side of printed page.
Roller is misaligned somewhere or gear is broken. It will repeat every several inches depending on the diameter of the roller and the section that broke. A small section break that repeats every three inches indicates gear malfunction on a roller whose circumference is approximately three inches.
Mar 06, 2008 | Dell 1600n All-In-One Laser Printer
Small group of spots repeating on page
Have you tried contacting Okidata, 2000 Bishops Gate Blvd.,Mount Laurel, N.J. 08054-4620 Phone 1-800-OKI-DATA(654-3282) or visit I have a similar problem with my OKIPAGE 10e. 1 inch wide black line, 2 inches from right hand side of page from top to bottom of 8 1/2 x 11 pages. I also cleaned black dust off green roller. Problem continues. Conclusion: I'm not an expert, but I think your wiping, checking, and cleaning, is a waste of time. I think your problem, and mine, is probably not a hardware problem, although I removed my black toner cartridge out of curiosity and perhaps re-installed it incorrectly. My guess is it's some sort of electronic problem, such as programming error, or software problem.
Aug 24, 2007 | OKI B4350n Laser Printer
77 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
