Question about Toshiba PA1390U1NKP Keypad
Toshiba PA1390U-1NKP fails under Windows Terminal Services from XP to Svr 2003 R2
Operates fine under stand alone Winxp, fails to operate durint Terminal server sessions to Win2003 r2 server. Toggles numlock instead. Machine: dell Inspiron 6000 to Dell Poweredge1950 server.
Turns out it in fact was a setting on Terminal Services clients. Seems as if default behavior is to pass windows keys on full screen mode. Leaving windows key combinations on the local device solved the problem (unless one needed to pass windows key combinations, which is unlikely.
Posted on Apr 03, 2007
  • 624 Answers
I don?t have the equipment to test your setup; however, I suspect your problem is in redirecting the device to the terminal server session. Check the terminal server system event log file to see if you are generating any messages when you connect. When my users have issues, typically with printers, they will be listed in the log as *Errors* and the source will be *TermServDevices*. If you?re using the latest Remote Desktop Client there is a tab in options called Local Resources which is used to deal with configuring your workstation sounds, keyboard, printer, and other local resources to redirect to the terminal server. Click on the More button at the bottom and you will be taken to the more generic section of resource redirection that deals with other items. Your device is probably USB so if it is going to work is would fall under the scope of the section labeled *Supported Plug and Play devices*. You would start by placing a check in that box, reconnect and see if you keypad works now or if anything shows up in the event log. Let us know how this turns out and if you have any other questions. As always please don?t forget to rate this post.
I am using Epson TM T81 thermal printer and it is showing status USER INTERVENTION REQUIRED , printer is not printing document. I uninstall drivers and install it again it works but whenever I restart the...
Sir/Madam
i suggest You download Epson Printer Driver From official Epson Printer Website and Perform Below Following Step Mention On Epson website on Below, i hope You Fix Your Epson Printer problem,
1. About this software This package includes the following two software programs to use with an EPSON TM-T81 printer. 1) Windows Printer Driver This driver is a Windows Printer Driver for the TM-T81 printer. This driver makes it possible to print from a Windows application.
2) StatusAPI StatusAPI is a program that works in conjunction with the TM-T81 printer driver. It offers an Application Program Interface for obtaining the printer status whether or not the printer is printing. This API makes integrating printer status handling functions with applications more simple. For detailed information, please see each reference manual. The driver operation has been verified with the following operating systems. Windows 7 Ultimate SP1 32/64bit Windows Vista Ultimate SP2 Simplified Chinese 32/64bit Windows XP Professional SP3 Simplified Chinese 32bit Windows Server 2008 R2 Enterprise SP1 64bit Windows Server 2008 Standard/DataCenter SP2 Simplified Chinese 32bit Windows Server 2008 Standard SP2 Simplified Chinese 64bit Windows Server 2003 R2 Enterprise SP2 Simplified Chinese 32bit Windows Server 2003 R2 Standard SP2 Simplified Chinese 64bit Windows XP Embedded 32bit SP2 Windows Embedded Standerd 2009 32bit Windows Embedded POSReady 2009 32bit This driver is not supported by Windows 95/98/NT/2000 and Windows XP 64bit. EPSON IM series PC or IBM compatible PC Supported Printers EPSON TM-T81 The printer driver operates regardless of the pritner firmware version. 2. Supplied Files APD_415bSC_T81.zip : Printer Driver,StatusAPI installer with manuals Refer to the installation manual APD4_T81_Install_SC_RevE.pdf. 3. Remarks - For detailed information, please read each manual that is created by the installation. -When an error message is displayed during installation, the following procedure may enable to recover from the error. 1) Specify the uninstall option, and execute the installer "APD_415bSC_T81.exe /uninstall". 2) Remove the error factor.
3) Execute the installer "APD_415bSC_T81.exe". -Characters may not be printed correctly when using Easy Print of Windows Server 2008. For detailed information of this problem arising from the operating system, see the following web page provided by Microsoft Corporation.download epson biz com
Or If You Still Need Epson Printer Help Then Follow Us On:
Epson Printer Support
May 11, 2011 | Epson POS TMT88IV Thermal Receipt Printer...
Tip
How to reset a lost or unknown Windows 7 password to blank?
Now Windows 7 has been official released for more than 1 year. With its increasing sale, more and more people may get confused by a forgotten or lost Windows 7 password. Well, if you forgot Windows 7 password, you can simply get help from Windows password recovery software for <b><a href="http://www.recoverwindowspassword.com/windows-7-password-recovery.htm">Windows 7 password reset</a></b> or recovery.<br /><br /> What can Windows Password Breaker do for you?<br /> <br />Windows Password Breaker is professionally designed for common users to reset forgotten or lost Windows 7 password. It has 3 editions to meet your needs.<br /> <br />Standard Edition - Help you burn a bootable CD/DVD to reset forgotten Windows local password (administrator and other user passwords). Windows 7, Vista, XP, and 2000 are supported. <br /> <br />Professional Edition - Help you burn a bootable CD/DVD or USB flash drive to reset forgotten Windows local password (administrator and other user passwords) . Windows 7, Vista, XP, 2000, 2008(R2), 2003(R2) are supported. <br /> <br />Enterprise Edition - Help you burn a bootable CD/DVD or USB flash drive to reset forgotten Windows local password and domain administrator password. Windows 7, Vista, XP, 2000, 2008(R2), 2003(R2) are supported. <br /> <br />Why to use Windows Password Breaker?<br /> <br />Here are just a few features that make Windows Password Breaker stand out, as well as the reasons why you choose it if you lost Windows 7 password.<br /> <br />Powerful. You won't ever need to go searching for any other tools - you can use this Windows password recovery tool when you lost or <b><a href="http://www.recoverwindowspassword.com/">forgot Windows password</a></b>, to reset various Windows passwords, like Windows local password (including Windows administrator, standard and guest password) and Windows domain administrator password.<br /> <br />Easy and fast. No computer reinstallation, no old password, no computer skills. This Windows password recovery software personally assists and guides you in safely regaining access to your locked computer in less than 5 minutes when you <b><a href="http://www.recoverwindowspassword.com/windows-7-forgot-password.htm">forgot Windows 7 password</a></b>.<br /> <br />Reliable. Windows Password Breaker is widely used by lost Windows password users. It has little bad impact on your computer during Windows password recovery. All your computer data all well kept after lost Windows password recovered. No data loss or data damage. <br /> <br />Works all popular Windows OS. This Windows password reset software runs equally well for users with Win PCs, like Windows 7/Vista/XP/2008(R2)/2003(R2)/2000. So if you forgot Windows Vista or other Windows OS password, you can still use this Windows password recovery tool. A single code of it can be used for up to 3 computers of your own.<br /> <br />How to use Windows Password Breaker?<br /> <br />1. Download Windows Password Breaker.<br /> <br />2. Run the program to burn a password reset bootable CD/DVD or USB <br />flash drive.<br /> <br />3. Reset lost Windows log on password to blank.<br /> <br />4. Log on again with no password.<br /> <br />With just 4 steps to reset a <b><a href="http://www.recoverwindowspassword.com/lost-windows-7-password.htm">lost Windows 7 password</a></b> to blank, you can get the software when you are locked out of your computer.<br />
on Jan 12, 2011 | Computers & Internet
I'm having 512mb of ram can install .net on this and please send details to install .net package in a system.
Hello For .Net Framework 4.0 following are the pre requisite:-
System Requirements Supported Operating Systems:Windows 7;Windows Server 2003 Service Pack 2;Windows Server 2008;Windows Server 2008 R2;Windows Vista Service Pack 1;Windows XP Service Pack 3 Windows XP SP3 Windows Server 2003 SP2 Windows Vista SP1 or later Windows Server 2008 (not supported on Server Core Role) Windows 7 Windows Server 2008 R2 (not supported on Server Core Role)
Supported Architectures: x86 x64 ia64 (some features are not supported on ia64 for example, WPF)
Hardware Requirements: Recommended Minimum: Pentium 1 GHz or higher with 512 MB RAM or more Minimum disk space: x86 - 850 MB x64 - 2 GB
Prerequisites: Windows Installer 3.1 or later Internet Explorer 5.01 or later
If you fulfill above requirement then go to http://www.microsoft.com/downloads/en/details.aspx?FamilyID=9cfb2d51-5ff4-4491-b0e5-b386f32c0992&displaylang=en
and click on download, you will found other instructions over there
Good Luck, do rate the solution if got help
Dec 31, 2010 | Computers & Internet
Unable to relay messages larger than 1024 KB in Win-2K3
plz go to right hand side 7 where show postmaster-right click here and
go WEBMAIL when open Vpop3 console log on and go to Services then SMTP SERVICES- Maximum Message Size- 20000000 bytes (0= no limit)
Dear 100% Solved Problem
Narender Kumar
Nov 28, 2009 | Microsoft Windows Server Standard 2003 for...
Where can I obtain a operating system CD for Dell Inspiron B130 New Internal drive installed but will not boot. Message's (NO BOOT SECTOR ON INTERNAL DRIVE) (NO BOOTABLE DEVICES) NOTE: F2 screen comes up...
Your options are go to Dell to get one for your particular computer (probably at a cost) or get a stand alone new Windows, XP, Vista or possibly 7.
Your computer will not boot because, as you are aware, it has no operating sustem.
You could get the public domain Linux at http://www.linux.org/ There is no charge for this operating system and it operates in a very similar fashion to the other OS we all know and love.
Thanks for using FixYa.com
positive comments are always appreciated for service received at this free web site - we are all volunteers here - working for bragging rights.
Thanks
a
Oct 26, 2009 | Dell Inspiron B130 Notebook
How to install Windows XP onto a newly formatted laptop
put winxp cd in tray
at boot up press F12 - right-arroweto CD icon --> Enter
winxp should go into install
you'll probably need a version of winxp that can recognize Sata hdd. or hae sata drivers handy.
Oct 13, 2009 | Toshiba Portege M200 Notebook
\windows\system32\config\system is missing or
You can repair your system by inserting the cd windows xp installer in your disk drive then go to setup mode by restarting your system and booting in the CD or you can reinstall your system to replace new and fresh set of files for your operating system and its services operates normally and effectively.
Thanks
Jul 14, 2009 | Toshiba Satellite 1410-S173 Notebook
How to download ms office for winxp
You can download here: http://office.microsoft.com/en-us/downloads/default.aspx
See the second section of the left sidebar to choose a version.
Oct 29, 2008 | Microsoft Windows XP Professional
Abnormal Shutdown of windows 2003 standard
y cuse its sharing isssas to 1st off way to maby boots 2 max os on hard drive unless u want to fail soon do all your updates
Jan 25, 2008 | Microsoft Windows Server Standard 2003 for...
Toshiba PA1390U1NKP Keypad Logo
222 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
