Question about EliteGroup ECS PT880Pro-A (1.0A) Via Socket 775 ATX Motherboard / Audio / AGP 8x/4x / PCI Express Lite / 10/100...
Computer wont do POST
How do I check if my motherboard is bad? I have a ECS PT880PRO-A. Thanks!
  • 45 Answers
Reseat RAM, CMOS re-boot.If this results ina no boot, your board might be dead.
Posted on Dec 21, 2008
When I push the start button of the PC, the fan of the processor of the motherboard ECS 945GCT start running and nothing appear on the screen. It seems that it hangs somewhere on the POST. Is there a...
one bad/faulty lead can cause a computer lots of problems
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty
hope this helps
Sep 30, 2010 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
"my windows cannot detect the harddrive of my computer"
Step1:Select first boot dives is HDD in bios
Step2:Select second boot device CD-Rom in bios only
Step 3:After that insert the o.s cd in your cd rom
Step 4:Restart your computer and go to setup menu by pressing the right key on your keybaord (Ex:Del key,F2 key...)
continue this prosses you will get sucess.
Sep 14, 2009 | EliteGroup ECS PT880Pro-A (1.0A) Via...
ECS 6100SM-M hangs on POST
Check memory, remove or replace sticks of memory with just one piece in the slot closes to the CPU. Now try a power on and see if it boots. You have at lease one good stick of memory to boot.
May 20, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
No video.
Try to check your monitor cable.. Is it ok?
Sep 19, 2008 | EliteGroup ECS P4M900T-M2 Socket 775...
Wont power up ecs motherboard
Your 4-pin power connector supplies voltage to your CPU through some series of MOSFET transistors. First try to disconnect your CPU from the socket and power up your motherboard. Your CPU might be toasted. MOSFET transistors might be bad. Also look at your big caps around the CPU. If they have bubbled tops, you need to replace them.
Good luck
NetSalem
Jul 17, 2008 | Intel Motherboard
Windows can't detect any hard drive
Hello.
Have you check if every thing is ok in the setup ?
If you have the documentation of your Hard drive, set the HDD
manually( cilinders, heads, etc), i don't know the difference between 4M and 3M models, but may be significant.
The battery wont have any effect in the BIOS, you should thanks god for that, because if you could erase what is in the BIOS you could say good bye to your PC.
In order to recognize many new devices the BIOS manufacturer make software updates you can download ( if available)from they website an install it ( i don't recommend you to do that unless you have no other option).
The battery is only for the CMOS, a memory that keeps your setup configuration when you turn off your PC.
- Most Probable cause of that problem and possible solution:
You hard drive must be partitioned and properly formated.
You will have to start you computer using a 3 1/2 floppy disk or bootable CD with MS-DOS.
Note: go to SETUP and set the right drive to boot from first( A: in case of floppy, CD in case of CD), save and exit
Make sure the disk have some commands you will need, FORMAT among them.
I suggest you look for totorials about partitioning a hard drive.
Is no big deal but you have to know what you are doing.
Create a partition using FDISK command and activate it
then format the drive.
Now it is ready to be recognized for Windows.
In the process of windows installation( only XP), right before it start it will ask if you wish to format de Drive, answer yes( the fast one) and choose NTFS( a more efficient Partition for windows XP.
I hope this help you.
Good luck
Jul 12, 2008 | EliteGroup ECS PT880Pro-A (1.0A) Via...
Sytem wont post
remove the rct battery and try again power on again.
Also look for and replace bad cappacitors. If nothing works, you need a new momo!.317cfa4.jpg
Feb 12, 2008 | EliteGroup ECS 755-A2 Motherboard
Computers & Internet Logo
121 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Computer Links
Matson Kurian
Matson Kurian
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
