Question about Samsung LTN226W 22 in. HD-Ready LCD Television
Samsung ltn226w - picture "washed out"
I have 4 of these units with essentially the same problem, but to different degrees. Using the s-video or rca inputs (component and dvi not tested) I get sound from my source but I can barely make out the picture, same problem when accessing the menu. The screen is bright, so I doubt it is a back-light issue. On the units where I could see well enough, I adjusted contrast and brightness settings with no success. I bought these 4 units at auction, and there were dozens more with the same listed problem. Do you think these are worthy of repair? Thanks
    Top Expert:
  • Samsung Master
  • 76,016 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on May 02, 2017
2 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: Hi Samsung LE32A456C2D with a very bright picture.
Replacement of T-Con board is only test for it.
There is no voltage data or other info available in service manual to confirm t-con board.
Required T-Con board is available in discount-merchants.com for $50 and if that does not solve over bright picture problem then lcd panel (screen) is bad and it will cost approx new tv price.
Thanks.
Posted on Dec 29, 2010
The player does play the dvd's and everything but the picture wont show up in my television. I already connected the RCA connectors into the television and the player but still no picture. Please Help.
Assuming you used the standard YELLOW-WHITE-RED RCA cable, between the unit and the TV, the colours of each of the plugs should match both the outputs on the rear of the unit and the respective inputs at the rear of the TV. The TV must also be on an AV input 'channel' to receive the connected unit. (for example, AV1 or VIDEO 1)
Try changing the RCA cables - just in case the ones you currently have are defective in some way.
Being a combo unit, there should be a DVD-VCR common output on the rear - using RCA cable, the YELLOW is video, the WHITE is left channel, the RED is right - these MUST match the input on the TV, and the TV AV input must be selected in order to view the pictures and audio from the unit. To enjoy both VCR and DVD, using the RCA connection, the common output on the rear of the combo unit is recommended.
Better quality video is possible using S-Video cable (available from electronics stores such as Radio Shack etc. but this does not provide audio; you would still require RCA RED-WHITE cable for that, and your TV may not have S-Video input). Your TV may have a TV/AV button on the front - select the correct AV 'channel' with that if necessary.
It makes sense to check everything twice before assuming anything is broken.
Jun 28, 2011 | RCA DRC8300N DVD Recorder/VCR
Have Samsung HLN567W and recently started having
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 12, 2010 | Samsung HLN567W 56" Rear Projection HDTV
LCD TV IS CONNECTED TO CABLE USING SATELITE. CABLE IS RUN APPROX 150 FT FROM SAT DISH TO TV. RECEPTION IS VERY GRAINY,,,IS IT THE LENGTH OF CABLE? THE CABLE IS 100FT CONNECTED TO 50FT CONNECTED TO TV....
Is the satellite receiver HD or standard?
If it is standard you should hook up the box to the tv via RCA cables (Yellow/Red/White) and this will help with the picture quality.
If it is a HD receiver then hook up the box to the tv using a component video cable and this will drastically change the quality of the picture.
Using a coax cable to attach from the box to the tv essentially is connecting an analog signal to the tv and this will produce a lower quality picture...
Good Luck!!
Jan 02, 2010 | Samsung LN32B360 32 in. LCD HDTV
Computer TV output (RCA) - no colour
I had the same problem and nothing worked for me until I changed laptop settings to NTSC_M
So, briefly what I have: S-Video to S-Video cable, laptop (Thinkpad R51, Windows XP, with Intel(R) extreme graphics controler ) and TV set (Samsung, quite old one). The problem was that after connecting my laptop S-Video (4 pin) with S-Video (4 pin) of my TV, I had black and white (no colour) picture.
Solution is the folowing:
- connect your laptop and TV (both S-video 4 pins)
- mouse right click on your laptop desktop screen
- in the popup menu select: 'Graphics Properties'
- "Output to"
- select "TV"
- properties "NTSC_M"
keep in mind that if your are not connected to TV, Graphics Properties don't show TV as an option. So, that was very confusing for me, as I saw similar solution somewhere but was not able to find NTSC_M settings on my laptop
Good luck
Dec 15, 2008 | Computers & Internet
Speaker Noise when volume turned down LTN226W Samsung
this is due to leakages in your internal circuit... this generally happens due to aging... the part which has suffered damage has to be found and replaced... but this part can be identified only physically testing the voltages and currents on the internal circuit...
Nov 09, 2008 | Samsung LTN226W 22 in. HD-Ready LCD...
No picture
How is the player plugged into the TV set? Are you using the S-video or RCA type plugs? Have you tryed a differant input on a differant TV? It could also be your cables. If you tryed differant cables and a differant input then your problem is a broken connection on the video jack or in the video output processor IC inside the unit and thats not a user fixable problem, Sorry. Good luck
Jul 23, 2006 | Sanyo DWM400 DVD Player
Samsung LTN226W 22 in....
I'll go through the basics that you can try yourself. It might be a problem with the backlighting, which usualy is very cheap to fix - take a flash light, dim the lights in the room and flash the light into the screen to see if theres any picture visible. If so then you're looking at a backlight or backlight inverter failure, like I said, cheap. second(or first) thing to try is changing the cables you have the TV connected with, they might not be seated well, or have some other problem. For a tutorial on changing the inverter click here: http://www.lcdpart.com/doc/inverter_installation.html BUT - have a warranty? don't touch it and take it back to the shop. Good luck
Mar 23, 2006 | Samsung LTN226W 22 in. HD-Ready LCD...
Samsung LTN226W 22 in. HD-Ready LCD Television Logo
Demonic-2011
Demonic-2011
Steve Allison
Steve Allison
