Question about Nikon Coolpix 4600 Digital Camera
Memeor card problem
When I turn my camera on it says memory card is write protected. The little thing on my memory card isn't in lock posotion or anything so I'm not sure how to fix it.
  • kelbel4 Dec 26, 2007
    i have the same problem! how do i fix it!?
  • Anonymous Feb 11, 2008
    when i turn my camera on, it says: memory card is write protected. what do i do?
I just had this problem and was looking on the net to solve it and could find nothing. I finally opened up my camera. I wouldn't suggest it because I found the problem and I could have fixed it without opening it up. The solution to my camera is that there is a little, spring held lever that lets the camera know whether the card is in write protected mode or not. For my camera I just stuck a tiny screwdriver in side the card slot and worked that lever back and forth a couple of times. I turned my camera back on and finally after months of not being able to use my camera, the card formatted and I am taking pictures again.
**do this at your own risk of damaging the camera, I am not a camera tech. but it didn't hurt mine at all.
GOOD LUCK
Posted on Jan 29, 2008
  • 68 Answers
Try to clean the connections on that card..use a pencil ereaser..good luck
Posted on Apr 03, 2007
My camera says the my memory card is locked.?? i dont no how to unlock it My Ixus 70 says my card is locked, but the card is NOT locked (button on the side of the card is in unlock position). The came
Oops. The little latch on the side in the unlock position, should engage a switch in the camera, indicating the memory card is not writ protected. It is not an electrical switch doing something in the memory card. But is the switch in the camera is defect, you get the same result. If someone once tried to press in a memory card, the wrong way around, this could have been the cause of a damaged switch. Just check the memory card slot, of nothing is in the cardholder, blocking the little switch from working correct. Sure the switch is in the up position, like in the picture? 25288825-qj532vtjsqner5bmetfl14fj-5-0.png
Nov 18, 2014 | Sony Cyber-Shot DSC-W530 Digital Camera
Says memory card protected when I try to use it
If card lock button isn't faulty and doesn't free by sliding it a few times does your camera have a memory lock function in the menu?
Sep 27, 2012 | Panasonic Lumix DMC-FZ7 Digital Camera
Whenever i turn on the cam, it says that the memory is locked
SD type cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
There is also a software protection feature on some cameras, but this is used to protect a folder or individual picture from accidental deletion, not the whole memory. You set or release this protection from the camera menus.
Nov 30, 2010 | Sony Cyber-shot DSC-W130 Digital Camera
Camera setting is stuck on card write protection setting lock. So I can't take a picture. I went to menu and clicked on "protect image" twice but the "lock" did not go away. What do I do
You should take a look at the actual memory card and make sure there is not a lock (a small slider you can use to protect the card from being overwritten). To check it:
  1. Turn off the camera.
  2. Open the port that holds the battery and memory card.
  3. Remove the memory card
  4. Look at the memory card and see if there is a little slider that can be moved from an On to Off position. There should be a little Lock drawn near it.
  5. If there is such a slider, make sure it's set to the Unlocked or Off position.
  6. Put the card back in the camera and close the door.
  7. Turn on your camera and you should be good to go.
Oct 23, 2010 | Canon EOS Rebel XSi Digital Camera
Sd card locked
Perhaps it is!
Look on the left side of the SD card and move the lever up to the top Write protect OFF down is on.Sometimes when inserting a card the lever catches and moves slightly off the top posotion and is then read as locked.
Sep 15, 2009 | Sanyo Xacti VPC-S60 Digital Camera
My DSE memory card says 'write protected'
Hi there, do this:
To fix this, remove the SD card from your camera. Look on the side and you will find a little switch. One end of the switch says locked the other end says unlocked. Move the switch from locked to unlocked. Replace it in your camera and turn it back on.
Thanks for coming to FixYa and fee free to rate my solution.
Rob
Feb 27, 2009 | Fuji FinePix A340 Digital Camera
Memory card is write protected
thought the cards have a little tab on them so they can be "write protected" it is a little plastic tab on the side of the memory1.gif card you slide up and down. I know most SD cards1.gif have it, CF cards dont so if its anything besides SD memory its probobly the memory card or some little switch or somthing in the camera that tells the camera when the card is in the "Locked" or "Write protected" mode.
Looking at my SD memory cards1.gif they have a little arrow on the edge and they say "Lock" pointing down, the slider is up. Move yours both ways, maybe it has a bad connection in the card (im not sure what it actualy does) or its in a position the camera thinks its locked?
Jan 15, 2008 | Nikon Coolpix 4500 Digital Camera
Turning on the camera
Please look at the memory card closely. If there is a write protect switch, it will give you this error. Please ensure that the write protect switch on the memory card is not in the lock, or protected position.
See more information about SD cards here.
Let me know if this helps!
Brian
Jan 08, 2008 | Nikon Coolpix 4600 Digital Camera
Write protected
On the memory card sometimes there is a little lock thing so lock it then u should not see the write protected thing.
Feb 01, 2007 | Nikon Coolpix 3200 Digital Camera
"Memory card is locked
This error message means that the memory card is write-protected. To take a picture, turn off the camera. Then insert a new card or change the storage location to internal memory.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Nikon Coolpix 4600 Digital Camera Logo
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
