11 hp 5700 watt generator wont fire
If you could not start in spite of oil and gas change, checked gas supply, spark plug, ignition cables and coils (magnetos) and so on whitout success, then try this:
Your generator has a low oil level protection, which stops the ignition of the motor.
After "a couple of years" sitting without or with old oil, the level switch may have got lazy or stuck down.
If your oil level seems to be good, while measured, find the oil switch and try to shorten or disconnect it.
If you succeed in running the generator change or repair the oil switch.
I hope that this will be helpful, because I don't have your device in front of me, but some people rank such an answer with 2 thumbs, which means useless. Better dont rank.
I have a coleman PM 5K maxa er plus, that has been sitting and will not run. I've checked the plug, cleaned it, removed all the gas and replaced w/ fresh gas. It just wont turn over. I did not get the manual w/ the gen. What is the "on" posisiton the "I" or the "O"? I'm thinking "O" for on but maybe thats too simple. any help would greatly be appreciated
