Robert Shaw 9600 - no heat blowing question
I have the same issue - and I posted this on the original thread someone else posted.
*** I had issues determining what color the "common" wire was. I have ared, white, yellow and green. Between the white and red i get .10-.70volts - between the yellow or green and red I get 28 volts.
Sodoes this mean I need better batteries - the instructions say"energizer" - but if this is the case - does it mean it is not myfurnace?
I can hear the unit buzzing atop the roof. But insideto air blows unless I turn the "fan" position to "on". - Then of courseno heat comes out.
Would be grateful for any reply!
  • Thomas Woodburn
    Thomas Woodburn Apr 05, 2017
    Turn the power off and remove stat. Wire red and white together and turn power on. This should bring the heat on. If it does then the problem is the tstat. If not its either the wire or the unit
  • jack morton Apr 05, 2017
    You mentioned " on the roof". Is this a travel trailer? I changed a control board on a traveler where I had to change the tstat with it. The tstat had no common and needed no batteries. Just an FYI. As far as what color the common is, we can use any color for any terminal. It just depends on how the unit is wired versus the tstat. As Thomas said, jump R to W and you should have heat. This is only true if W is your heat circuit. If it is wired to NORMAL wiring practices, R is power, W is heat, Y is cool, G is fan, and Blue is common if available. Again, we can use any color we want. If you have 28v to Y and G, that's odd to me because that tells me that your cool and fan circuit are powered up with the tstat off the wall. So be careful jumping anything! I think you need a tech to help figure it out or you may jump a wire and end up opening the transformer costing more money on labor and parts. Hope this helps!
  • Heating & Co... Master
  • 1,997 Answers
Typically red is power green is indoor fan white is for heat and yellow is for cooling. Sounds like you don't have a common. This IS ok just means your tstat requires batteries. BUT, if your tstat turns the fan on then it's not the batteries. Is this a newly installed tstat? Sounds like you might be on "gas" setting rather than "electric" need to check the settings or sometimes on the back of the tstat there's a little switch to flip to electric. Many tstats come from the manufacture set for gas rather than electric. Good Luck!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Posted on Apr 05, 2017
SOURCE: Wiring diagram needed RV rooftop coleman
Motor1258,
Thanks for the response, to be more specific, the nine pin connector was damaged, but I was able to connect the wires back to main unit panel. I am ready to hook to the hunter thermostat and do not know which wires to connect to. This is my problem and I do not want to short something out. Hope this helps, I want to get it installed again. Thanks again for caring....Jerry
Posted on Aug 16, 2008
bobicehouse
  • 1524 Answers
SOURCE: I need help with my central heat and air unit, it
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Thermostat wire color codes explained.
Please note. Not all installers use the proper color codes when they install or replace equipment. It may be necessary go go to the furnace or outdoor unit to verify what wires are for what purpose. Also be sure there are no splices in the wire that could change the wire colors between components.
  • R (red) or Rh (Red heat) 24 volts from equipment.
  • Rc (Red cooling) 24 volts from transformer in cooling equipment.
Note: If only furnace has a transformer and cooling equipment does not jumper Rc and Rh.
  • W (White) sends 24 volts to furnace control to start the heating cycle.
  • W2 (no standardized wire color, usually whatever wire color is available) controls second stage heat.
Note: W2 is most often used for heat pumps to control what is called emegency heat or Auxillary heat, and most often will use the white wire.
  • Y (yellow) often (blue) is used, controls cooling unit (outdoor condensing unit) also is used for heat pump heat.
  • Y2 (no standardized wire color, usually whatever wire color is available) controls second stage cooling.
  • G (Green) controls the fan "on" operation of the furnace/air handler. Also often is used to start the blower for many electric furnaces.
  • C (common) most often brown but can also be black or other color available to installer.
  • O (orange) Energizes heat pump reversing valve for cooling (Trane and most other brands).
  • B (Blue) Energizes heat pump reversing valve for heating (Rheem, Ruud and Weatherking).
Posted on May 07, 2009
  • 232 Answers
SOURCE: Thermostat Wiring Problems!!!
. your blue is probably common and if you hooked it to Y you shorted the transformer or blew the low voltage fuse. Green is fan, yellow is AC, Red is 24volt. Is it a heatpump or just ac? I think its probably a heat pump and your brown is your Reversing valve it needs to be hooked to O on the new stat. If its a heatpump your tstat must be a 2heat 1 cool stat w/ aux heat. Without knowing what terminals the wire were hooked to on the old stat you may have to look at whats hooked up at airhandler( furnace) and on A/C (heatpump) tobe able to determine what goes where on the new one.
Posted on Sep 20, 2009
Testimonial: "Thank you, it was a heat pump"
james3751
  • 614 Answers
SOURCE: I am replacing a White
Yes you did correct. Tape of f blue wire. On your thermostat you should have el/gas turn top el and fan should work Russ
Posted on Mar 23, 2010
  • 266 Answers
SOURCE: RV Dometic Duo Therm roof top AC w/heat pump Model
If the Air comeing out is the same as the temp inside the RV make sure the compressor is running and not just the fans. It could be low on freon. If freon is ok then you would need to ck the wiring to the selector switch for a short. It would be obviouse because there will be melted wires. I am leaning toword low on freon since you have already been inside the wiring/control unit.
Posted on Aug 08, 2010
Thermostat kicks on and off
I am not familiar with this unit but I would first replace the batteries if there are any. Be sure the heat does not blow on the thermostat when on. If that does not solve the problem I would replace the thermostat.
Jan 30, 2014 | Shaw Robert RS-9420 Thermostat
I have a Robert Shaw thermostat and it converted to celsius degrees. How do I program it for farenheit???
The thermostat is preset to display the temperature in degrees
Fahrenheit (US models) or degrees Celsius (Canadian models). The
temperature display can be changed. Press and hold both the
?° and ?°Ÿbutton for three seconds. The display will read F or C.
Release buttons. Press the ?° or ?°Ÿbutton to switch the display.
Jun 16, 2010 | Shaw Robert RS-9420 Thermostat
My Robertshaw 9600 displays 99 degrees and because it is satisfied, is not calling for heat. The temp is actually in the lo 60's and falling. I've tried battery replacement, but nothing changed. Other...
Hmm. I don't think it posted the first time around. So I'll try again.
There is a temperature sensing diode on the back side of this thermostat's circuit board. This diode may have failed or become disconnected.
I'd lean towards its having become disconnected, as I've been inside an example of this Robertshaw (originally Maple/Chase) 9600 thermostat and noticed that the soldering on this part was of poor quality. So if you have a soldering iron, and know how to use it, you could probably fix it.
I have a web page (just the facts, no ads, malware or fluff) that talks of some other common problems with this thermostat and how to fix them:
http://greyghost.mooo.com/maplechase9600/
Feb 04, 2010 | Shaw Robert RS-9420 Thermostat
No display on Robertshaw 9600; unit seems dead/furnace works
have you checked to make sure you have a fresh battery in it
Jul 25, 2009 | Shaw Robert RS-9420 Thermostat
Error code on robert shaw 9600 thermostat
i am having a ER on my shaw robert theromostat model RS-9420
Jun 30, 2009 | Shaw Robert RS-9420 Thermostat
Robert Shaw thermostat suddenly went blank
Best solution GET RID IT BEFORE IT'S TOO LATE....Original 9420 installed 8-18-06 changed temperature by itself and would not allow any adjustments...this one replaced on 1-3-08 and this one is doing same thing. Heat set on 70 when I noticed it getting extremely hot I checked thermostat and it was on 99 and would not allow me to adjust. Switched to off position waited 25 minutes and cut back on to heat....still will not allow me to adjust down from 99.....THIS PIECE OF **** WILL BE REPLACED TOMORROW WITH ANOTHER TYPE OF THERMOSTAT.
Apr 11, 2009 | Shaw Robert RS-9420 Thermostat
Heating & Cooling Logo
71 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
