Question about E-Machines eMachines Desktop PC
Driver not working
Disk explodes in driver and now driver won't close. ARGHHHH! I don't know what to do!!!! Some disk fragments are stuck in the driver.I can't take out the fragments. What should i do???? Please HELP!
  • 55 Answers
Unfortunately you will need to replace the drive. I have seen this happen once before and you will never get all of the little tiny fragments for disk out of the drive and it will cause damage to other disks that you put in the drive. I would replace it and save yourself a whole lot of headache.
Posted on Dec 20, 2008
How do i fix a crack in the moddle of my disk
Well-- You don't.
Even though the disk may still function, as it spins in the console, you run the risk of having the disk fragment. This could damage your console's internal components.
If the game is already burned to your hard drive, the disk won't spin, but using a damaged disk is still risky.
I'd recommend buying a new disk.
Hope this helped,
-Dan
Oct 09, 2011 | Microsoft Xbox 360 Console
Laptop won't boot. Caps lock and numeric lock lights are blinking. It was working fine after I installed a new hard disk and restored the whole system using my recovery disks and backup. I installed...
Don't restore the system to a hard disk of different size. You may fix the old disk again and use it while using the new (probably larger) disk as an external disk (by fixing a driver bay).
If you want to use the new disk you will have to install the operating system and software from scratch.
Jul 27, 2011 | HP Pavilion dv5-1004nr Notebook
My 50 inch hitachi hd projection tv picture won't
This T.V. more than likely has a bad lamp. I don't know the model number so look up on ebay for a lamp replacement by model number after you inspect it and find it to look cloudy or exploded.
Jun 20, 2011 | Hitachi Televison & Video
SIR MY pc take long time to start window
Improve performance by defragmenting your hard disk
Fragmentation makes your hard disk do extra work that can slow down your computer. Removable storage devices such as USB flash drives can also become fragmented. Disk Defragmenter rearranges fragmented data so your disks and drives can work more efficiently. Disk Defragmenter runs on a schedule, but you can also analyze and defragment your disks and drives manually. To do this, follow these steps:
  1. ?id=microsoft.windows.resources.shellexecutetopiciconClick to open Disk Defragmenter.
  2. Under Current status, select the disk you want to defragment.
  3. To determine if the disk needs to be defragmented or not, click Analyze disk. ?id=18abb370-ac1e-4b6b-b663-e028a75bf05b If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
    Once Windows is finished analyzing the disk, you can check the percentage of fragmentation on the disk in the Last Run column. If the number is above 10%, you should defragment the disk.
  4. Click Defragment disk. ?id=18abb370-ac1e-4b6b-b663-e028a75bf05b If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Disk Defragmenter might take from several minutes to a few hours to finish, depending on the size and degree of fragmentation of your hard disk. You can still use your computer during the defragmentation process.
Notes
  • If the disk is already in exclusive use by another program, or if the disk is formatted using a file system other than NTFS file system, FAT, or FAT32, it can't be defragmented.
  • Network locations can't be defragmented.
  • If a disk that you're expecting to see under Current status is not showing up there, it might be because it contains an error. You should try to repair the disk first, then return to Disk Defragmenter to try again. See Check your hard disk for errors for more information.
    also "hibernate" the computer instead of "shut down"
May 20, 2011 | Microsoft Computers & Internet
GMC Envoy 2004 XUV tailgate won't latch closed. Pressure switch makes latch click but when I go to close it, it does not latch.
Two things happen. One the latch is already latched and therefore it's closed before the gate shut, When you try to close it you might notice that the door don't close all the way. This doe'snt have to be thwe case. the other thing that happens if the lock mechanism is working, You here it click? The latch is stuck as the opener is stuck. You might get lucky and spray the latch with Blaster or other rust buster type penatrant. Theres angles though the opening of the latch . Spray on several angles and repleatly close the door trying to vibrate the Penatrant into the stuck area. Looking at the latch use a screw driver to move the latch and see if you can cycle it though it's positions to see if you can latch and unlatch it with the tool and reopen by pullung the handle ( you may need to try ther inside handle too and even the remote openner if you have one. Ussaaaly you need to push the button twice to open the rear hatch so it may take a few trys and spraying to get it to come loose.. Some vehicals stay closed a long time and stuck is the way to think.. But if the door is used often the linkage inside the door mayh have come off the the latch is closed and the linkage doesn't open the laTCH AND THE THING MANAGED TO GET CLOSED WITHT THE DOOR OPEN.
May 09, 2011 | 2004 GMC Envoy
Running slow
THERE MAY BE 2 REASONS.
1)FRAGMENTED FILES :
TO DE FRAGMENT THE DRIVES OR FILES -RIGHT CLICK ON MY COMPUTER -->SELECT MANAGE-->AND EXPAND THE STORAGE OPTION IN LIST(CLICK ON + SYMBOL OF STORAGE)
CLICK ON DISK DE FRAGMENTER -->SELECT ONE DRIVE DRIVE--->CLICK ON DE FRAGMENT TAB-->IT STARTS DE FRAGMENTING .IT TAKES SOME TIME TO DE FRAGMENT .AFTER DETRAGMENTING ONE DRIVE ,DE FRAGMENT THE OTHER DRIVES AND CLOSE IT.
2)DOUBLE CLICK ON MY COMPUTER---> SELECT C:\ DRIVE OR THE DRIVE WHICH CONTAINS YOUR OPERATING SYSTEM-->SELECT WINDOWS (IF THERE ARE NO FOLDERS CLICK ON SHOW ALL HIDDEN FILES )FOLDER OPEN THE TEMP FOLDER & Prefetch AND DELETE ALL IT'S CONTENTS.
PLEASE GIVE VOTINGS TO IMPROVE MY PROBLEM SOLVING SKILLS
Feb 18, 2011 | HP Computers & Internet
Computer wont restart
try booting up in safe mode and run Disk Clean up, and run a Virus scan, and anti-spyware scan, update all system drivers. and scan for disk fragment faults
Jun 23, 2010 | Alcatel Speed Touch USB (3EC18607GA) Modem
Original motherboard sound drivers from MB disk don,t work.
Here is a link to the driver page for your board.
updates and see if this is
http://www.biostar-usa.com/app/en-us/mb/driver.php?S_ID=377
You could try downloading the driver from the site..Maybe there is a problem with the one on the disk. Also check the BIOS updates and see if this is a known issue. They may have a BIOS update to fix this issue. Before installing the driver/software I would remove the current audio software and remove the audio from the device manager and then re-boot the computer. Then install the downloaded software and see if that works.
Sep 08, 2009 | Biostar TA790GX Motherboard
Red light flashing on samsung le40a stuck in standby mode
hi nick think it may be blown capacitors on your power input board?
Aug 03, 2009 | Televison & Video
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
