Question about GE Profile¿ Arctica® Energy Star® 25.5 Cu. Ft. Side-by-Side Refrigerator with Dispenser, PSS26MSRSS
Not getting water from dispenser in door
Ge Profile side by side refrig-Model PSS25 mgnaww I get water to the connector but it now leaks and disconnects when I try to operate the water dispenser. Tried to run a narrow wire up the tubing but somewhere near the top inside the door, something blocks the wire. Could it be ice? We've had this GE Profile Arctica for several years and never had the problem before. Can I get inside the door to see if there is ice?
  • reedba2001 Dec 24, 2008
    Brian was right that the water flow was stopped by ice. I used a hair dryer and was able to restore the water flow. I appreciate the part number information. That is very helpful. Not sure if I need to replace the connector now, as it is not leaking. However, it is clear that it is not a very tight fit.
  • ljgasowski Jan 18, 2009
    I can only get water sometimes from the water despenser.
    Problem Solver:
  • 6 Answers
My water dispensor INSIDE the door froze up.
I payed a repair guy $75 to use MY BLOWDRYER to "thaw" the frozen water line INSIDE the freezer door (below the water dispenser).
He said anytime the frozen food extends over the freezer shelf and touches the freezer door for a long enough period of time, the water line inside the door FREEZES!!
PREVENTION: "Keep some airspace between the door and frozen food."
Posted on Jun 08, 2012
  • 235 Answers
If its several years old ,I would try turning it off for a day and then see what happens ,if its a door replacement that's going cost not sure if brian is saying you need to replace the door or just that part because he says you can't get at it .Anyway just trun off the water until you get a new one altogether they don't make them like they use to and something else will go wrong as soon as you get it fixed.
Posted on Dec 20, 2008
    Scholar:
  • 111 Answers
The connector that is leaking is bad causing tubing to come out and leak. The reason it won't flow is it is iced up inside of the door and no, unfortunately, you can't disassemble the door to get to it. It requires a door replacement. The connector is part number WR02X10471 from www.geappliances.com or GE Factory Service Parts at 1-800-626-2002
Ge profile side by side 2005 psh25pswass small amnt of water on inside of refrig on the bottom of refrig floor on side next to freezer. vents in refrig appear to be bringing in very humid air that is
It can have an air leak, but also a clogged drain pan under the freezer evaporator coil. If the refrigerator is getting warm, then it may be another issue
Dec 17, 2014 | GE Refrigerators
Ge profile .. refrig water leaking from freezer door near lower hinge.. seems like the water line?? any help ??
Must be the line going to water dispenser. The manual below has pictures. Use it as a guide to repair the leak.
PSS service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker stopped working. the water and ice dispense from the door, but it does not make any NEW ice...
The water tube to the icemaker inside the refrig is frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Jun 06, 2010 | GE Profile PSW26P Stainless Steel Side by...
A GE Profile Model, double door refrigerator with a water leak
If the leak is on the refrig water valve where the wall water line connects to , then use a 1/2" wrench and tighten the fitting on the water valve itself . If the leak is on the plastic tubing at the bottom of the refrig water valve , pull up on the small white ring while pushing down on the plastic tube to remove it from the valve . Cut off about 1 " of the tubing and reinsert it into the valve with pretty good pressure to be sure it is inserted completely .
Mar 27, 2010 | GE Refrigerators
Ice maker leak in GE refrig.
when the refrig.goes through a defrost cycle the water from the melted ice is supposed to go out a drainline to a pan inthe back.most likely the drain has plugged up and needs cleaning.remoe shelving andtake back panel off drain hole is located below coils,be carefull of coils ,delicate
Jan 22, 2010 | Kenmore 53642 / 53644 Side by Side...
Me GE Profile PSC23M Side by side ice maker quit making ice and water was on floor behind refrig. Is a water line frozen or clogged or do I have to replace ice maker?
It sounds like you just have a leak at the back. Try swapping the wires on the dual water inlet valve. Then try the water dispenser and watch on the back for where the water may be leaking before it gets up to the ice maker.
Oct 04, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water leaks from back of the refrig. Water retrieved from the front
your water valve is bad or you have a loose or bad water lines i advise you pull it out then have someone look back there when you push for water and see where it is coming ffrom
Apr 26, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
if you can get ice but not water from the dispenser then suspect a frozen water line within the door . Check you get water to the connector at the bottom of the freezer door. Sometimes you can clear the blockage by connecting a steamer to the pipe but this will only be a temporary fix . If the pipe has frozen within 6 inches of the dispenser outlet then there is a heater mod that can be fitted WR49X10173
Nov 28, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
No water from door dispenser
you have a frozen wtr line inside door turn it off for a day or 2 then try it again but this time palce a thermometer in frezeer and keep temps at 0 to 4 degrees if it drops below 0 then the line will freeze again
Oct 30, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile¿ Arctica® Energy Star® 25.5 Cu. Ft. Side-by-Side Refrigerator with Dispenser, PSS26MSRSS Logo
361 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
