Question about Harley Davidson Road Tech HA90 MP3 Player
Starting problems 93 fat boy , problems with starting, how totest starting system .
  • 91 Answers
Is the handle bar switch working take the small wire of the starter check for voltage when button is pushed if you do then problem is in starter test the starter take a short length of wire touch one end to the pos side of batt and touch other end to starter where small wire came off, if strter clicks but dosent engage the solonoid is proable bad it is under the cover with the three small bolts on end of starter hope this helps give me a rating please
Posted on Jan 03, 2009
Fat boy 1999, trying to re wire and it doesnt start up, one black wire hangs loose but I cant find anywhere for it to connect to. Headlights work.
There are a lot of black wires on a Fat Boy and without more information, I can't help you. I have a schematic for 91-93 FatBoy that I will send you if you will contact me directly at wd4ity@bellsouth.net. There are a few modifications on it but it will still give you something to work with.
First, is your bike fuel injected or carb equipped? If it's injected, there isn't much I can help you with in that area. Do you have a spark? Does the starter turn the engine over? I need a LOT more information.
Thanks
Steve
Jan 07, 2011 | 2000 Harley Davidson FLSTC Heritage...
Charging system were is the stator located
you will have to remove the primary cover,then remove clutch and compensating nut,then pull rotor cover off to get to stator and as a tech. you should have a service manual you should be able to get one on line or at an h-d dealership
Apr 13, 2010 | 1993 Harley Davidson FLSTF Fat boy
I need to rebuild a 93 harley davidson carb . I need a carb diagram
library sec 629 has many books-or secure rebild guide online
Sep 07, 2009 | 1993 Harley Davidson FLSTF Fat boy
My 93 Fat Boy sat for awhile and wouldnt start
I don't want to sound like "Chicken Little" here. I would in light of the potential possible issues strongly recommend taking your bike to shop you are comfortable with.
You just asked for what we think, the number of items that could be damaged are long, and with the bike sitting up for a while you may have other items that would need to be addressed to get it going. This may be one of those times where dropping it off at the shop is the best thing to do.
Hope this helps,
JP
Aug 30, 2009 | 2003 Harley Davidson FLSTF Fat boy
How do you go about checking for dirt in the carburetor jet of a 93 Harley Fat Boy?
Take the carburetor out and clean it. Often the dirt is too small to see.
Jun 14, 2009 | 2000 Suzuki DR 125 SE
Where is the fuse block located on a 93 fat boy
On 1986 - 1994 fl models the Fuse / Circuit Breaker Panels are located in one of three locations:
1. Under the Seat
2. Behind the Left Side Cover
3. In the Fairing / Headlight Bucket
Apr 27, 2009 | 1993 Harley Davidson FLSTF Fat boy
93 fat boy will not continue to run once started and wont restart
sounds like a fuel supply problem it probably has some build up in the fuel system from sitting so much, if it has a screen in the bottom of the tank it could be clogged with sediment from the fuel sitting. or in the filter if it has one could be clogged with old gas or dirt particles. Clean the tank if needed, unhook fuel line at engine and make sure there is flow from the tank. I sometimes blow air through the line back up to the tank to back wash any problems.
good luck
Mar 28, 2009 | 1993 Harley Davidson FLSTF Fat boy
Open Questions:
See all Harley Davidson Road Tech HA90 MP3 Player Questions
Harley Davidson Road Tech HA90 MP3 Player Logo
80 people viewed this question
Top Harley Davidson Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Harley Davidson Audio Player and Recorder Expert? Answer questions, earn points and help others
