Question about Sony FD Trinitron WEGA KV-36HS500 36" TV
HD transmission When I watch this tv from a HD source a light pink or light red band travels from one side to the other. This does not happen when the transmission from a regular source.
  • Gordon Moncibais Apr 06, 2007
    How do you determine what type of cable you are using. Thanks
    New Friend:
  • 40 Answers
What kind of cables are you using. Component,HDMI, DVI
Posted on Apr 04, 2007
Why my jvc television hd61z456 not showing in high definition
What is the signal source that you are watching on your HD61Z456?
The problem you describe usually happens when you aren't using an HD source or have downgraded the signal by the composite input on your TV. (Composite cables only support 480i SD signals.)
You will only see 720p HD content from HD sources, if you use HD compatible inputs. Some OTA channels are also broadcast as only analog signals (usually the -2 and higher sub-channels). If you have cable or satellite, make sure that you have the HD programming and have tuned to the HD version of the channel.
The HDMI and component inputs both support HD signals.
I hope this helps. If you are watching an HD source and the problem persists, I recommend trying new video cables. Next, check if you are getting interference from your devices by using a cable with a Ferrite core. See http://www.monoprice.com/Category?c_id=102&cp_id=10240 for HDMI cables with Ferrite cores. The cores help block interference. If you have very long cable runs, check the behavior with shorter cables between the source and the TV.
(I am assuming you aren't using an SD set top box (VCR, older cable box, low end digital-to-analog converter).)
Dec 19, 2013 | Televison & Video
Is my REGZA 42" 42HL167
This REGZA 42" 42HL167 has ATSC digital tuner built-in. when you set the TV to scan for channels, you must set the source to AIR, not CABLE. Since the Digital TV signals use the Old UHF band for transmission, your amplifier is made for this band? Try it without th amp first.
Please leave rating if it helps
Jan 31, 2011 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
BG1301 Casio watch replacement band
Go to "casio.com" and click on "support".
Although they don't say so directly, their repair section imply that they can replace straps.
Jul 20, 2010 | Casio BG1301-4V Pink Baby-G Watch with...
Red line down the left side, but not all the time
this can happen from loose HD cables and faulty hdmi cable. Confirm when its doing it, like watching cale or just when you watch dvd'd. But if its not all the time, then the plasma cells are still good.
May 04, 2010 | Samsung PS42A410 42 in. HD-Ready Plasma TV
Hi, i have a samsung ps42 s5 plasma. the screen has pink/red striped flickering across the screen. any suggestions?? thanks
You may have a small signal board that is bad. Speak to your local TV tech. I don't beleve you screen is bad...if the stripes you say are traveling. Hope this gives you a clue!
Mar 14, 2010 | Samsung PS42S5H 42 in. HD-Ready Plasma...
Light green and pink spots on my hd tv!!!
For the spots....
I had the same problem, first a blue spot then a green spot showed up. I contacted Panasonic Customer Support. They sent someone out and they fixed the TV for free. They reprogrammed the EEPROM chip in the TV. It is a defect. My TV was 4 years old and out of warranty. They came out last week.
So long as it is not happening by something you have done. It will be fixed free of charge. Call them, it solves the problem.
May 27, 2009 | Panasonic PT-44LCX65 Television
Sony kf50we610 hd pink stripes
That's a good one!
If you're using component video cables, make sure they are good and tight. If it's composite video or S-video inputs, you will likely need service.
Sep 12, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Hi--Bought my panasonic pt-52lcx65 on sale for $2200 in 8/05. Replaced the lamp for about $300 in 1/08, just prior to Superbowl. Admittedly, this was to be expected after family members watched lots of tv over 30 months. However, two months later the blue spot emerged in 3/08, and red spot emerged 5/08. Set looks decorated by a Andy Warhol or Van Gogh wannabe. I'm looking for a fix it solution. Dr. Bob Heiliger, Lebanon, OH.
Jun 08, 2008 | Panasonic PT-52LCX65 44" HDTV
Hitachi 50V500 TV: has a red line that outlines faces or text
It's a light engine defective part. Hitachi knows about it and if you call their customer relations department, they will refer you to a dealer in your area to come and diagnos the problem. Once Hitachi can verify that's the problem, they will ship the part to the dealer. We had our part in 2 days and had it installed today. No more problems. TV looks brand new. We had to pay the installation of $400 but the part runs around $1500 and Hitachi covered it. We felt like $400 was worth the $3600 we bad 3+ year ago when we bought it. The color will only get worse if the light engine is not replaced. Good Luck! It was an easy fix!
Nov 17, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Vertical Lines / Color Differences at edge of Analog vs HD Picture
EXACTLY-YOU HAVE THE USUAL "AGING" CRT PICTURE.THIS WILL ALWAYS HAPPEN WHEN YOU WATCH THE TV W/BLACK BARS ON THE SIDE,THERE IS NOTHING SHORT OF ALL 3 CRTS' REPLACEMENT TO FIX IT. JOE TV
Oct 31, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Sony FD Trinitron WEGA KV-36HS500 36" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
