Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Washing machine continues to drain and will not fill with water
    Scholar:
  • 111 Answers
The end of the drain hose is too low or is stuck too far down the house stand pipe and is causing the machine to siphon water out at the same rate which it is filling. If this wasn't the case, it would be flooding the floor
Posted on Dec 20, 2008
Washing machine constantly fills
The pressure switch, also called the water level switch, is what control the amount of water goes in the machine, If your machine is constantly filling to the overflow point, then that is your problem. Now, if water is going in and the level is staying the same then your machine drain line is lower than the pump and your siphoning out the water as it goes in. Pull the drain up a little a that should fix the problem.
May 08, 2012 | Whirlpool Clothes Washer Water Level...
Samsung washing machines water drains continously
The drain hose is too low, you need to lift the height of the drain hose as it is siphoning and won't be able to fill to the required level.
Mar 05, 2012 | Washing Machines
Water doesnt stop fillinG in panasonic NA F60A6 WASHING MACHINE
Fyi. All new washing maching already tested on their functionality and features but not test run with water intake and drain function. I would like to share My experience last time with this model. The water outlet valve will release by motor when you set to drain mode.it suppose manage to retract back by spring when drain process finish or afte small you change to wash mode.
Take a look on the spring movement.normally it not properly hold valve switch hence the retracted spring not block the valve to stop water drain. Just rectify the alignment of the valve swich which directly connected to the retractable spring.
Dec 26, 2010 | Washing Machines
Water continues to fill after it should have
first does it over flow.if not pull your drain hose up from the drain till it is aleast the same level as the back of the waher control panel.
If the Drain hose is to far down in the pipe this will cause the water to drain out by gravity.the other least likely problem is a bad fill pressure switch.
Sep 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Continues to fill, not holding water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
If the above adjustment doesn't produce positive results, replace the control.
May 31, 2009 | Crosley Washing Machines
Water running out when washing machine is filling?
Hi jojolevaokah
Water siphoning out the drain line
If the water is continues to fill and water is draining while it is filling or agitating, Check the height of the stand pipe. It should be about 36" above the floor. If the height is correct it may need to have an anti-siphoning valve installed into the drain line.
Apr 07, 2009 | Whirlpool LSQ9520L Top Load Washer
Whirlpool washer fills, begins to agitate, then drains
moz-screenshot.jpgThe washer fills and drains at the same time only on the rinse cycle.
Shut the machine off with timer during this period and raise the drain hose. If the water continues to drain, you will need to install an anti-siphon kit.
Please leave a solved rating before you sign out
Jan 31, 2009 | Whirlpool LBR4121JQ Top Load Washer
Washer fills then drains
Daisy, check your drain hose going into the drain. It sounds like you have a siphoning problem. If the drain hose does not have a air gap the water filling will siphon right out. Check this first and post back, Catriver.
Sep 21, 2006 | Kenmore 98702 Stacked Washer/Dryer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
26 people viewed this question
Dan Webster
Dan Webster
Sal De
