Question about KitchenAid KGSA906PSS Gas Kitchen Range
Gas Range, trouble igniting
I have a KitchenAid gas Range. My bottom burner periodically stops igniting. The igniter seems to spark and the gas sounds like it is flowing and I can smell it. The Range saftey stops the igniter after 4 attempts and trys 5 min later. This goes on for a while, three or four attempts then I shut down out of frustation. I adjust the air flow control by the venturi and bang it goes on the first spark. The problem is that I have to do this every couple of days to make it work. Do I have a range issue or gas quality issue?
  • Anonymous Dec 31, 2008
    where and how do you make this adjustment
  • Anonymous Jan 26, 2009
    I have the same issue. Sometimes it fires up the first try and other times it will cycle the iginitor and keep trying for what seems like forever. I have never adjusted anything, I just turn it off and then try and start it again (sometimes it works and other times I turn it off and on several times).
  • 57 Answers
It is likely that the ignitor needs to be replaced. If the range does not sense the correct amount of resitance in the ignitor it turns the gas valve off. When the ignitor is starting to fail the problem is intermittent, so the range turns on and off as you have described.
Posted on Sep 22, 2009
Random spark from igniter
it sounds like the wire that goes to the stove igniter is shorting out when you are using the oven.
Jun 09, 2014 | KitchenAid KGST307 Gas Kitchen Range
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
One of my gas burners does not ignite, I have to ignite it with a match. When I turn on any one of the other three burners, I see sparking at the all of the three other burners (is the sparking at all of...
Yes,all burners spark as a safety feature in the event any gas knob is turned on.
The non sparking burner could be from a bad spark electrode, poor grounding on the burner cap or a bad spark switch for that burner.
Sep 22, 2010 | KitchenAid KGRC707 Gas Kitchen Range
The ignitor will not stop sparking.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 23, 2010 | Jenn-Air 30 in. JGD8430A Gas Cooktop
Oven set at 350, won't get there. kitchenaid mod#kgrt607hwho.
This sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 30, 2010 | KitchenAid KGRT607 Gas Kitchen Range
Ka gas range the glow bar comes on but it takes sometimes 15 to 20 min before gas is supplied to burner in oven and finaly ignites
Hi, this sounds like a weak igniter, it would have to be a gas oven and the symptoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, if it does light the burner, there may be delayed ignition (pop), does not maintain set temperature or burner does not come on fully, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 22, 2010 | KitchenAid KGST307 Gas Kitchen Range
Gas burners are ticking
The ticking sound you hear is the electronic ignition which is located by each burner. When you turn a burner on the electronic ignition creates a spark which ignites the gas. Once the burner is ignited. turn the knob a bit further and the ticking will stop.
Feb 05, 2009 | DCS RGS-486GD Gas Kitchen Range
Large Burners do not re-ignite
When you are having trouble igniting that one burner, have you tried the other burners?
If they're all the same - i.e. none of them will work at any particular time, that's the spark module.
If some work while one or more don't, that's the burner switches under the knobs.
I doubt this has anything to do with your husband's previous repair; that is, unless you find one of these wires pinched inside.
Mar 12, 2008 | KitchenAid KESC300 Electric Kitchen Range
KitchenAid KGSA906PSS Gas Kitchen Range Logo
443 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
