Question about Canon PIXMA MP610 InkJet Printer
The I J preview is poor quality not the same as photo
I was getting professional prints, now for no reason my prints and the I J preview screen show lots of noise in my photos.I have tried all adjustment with no luck. Is my driver not working properly?
Why are the areas that should be black on a photo coming out dark red. All the cartridges are working properly as I have printed a test page and recently removed the head for cleaning.
The priter is a Canon MP610
Posted on Oct 21, 2009
When i print the quality is poor and is show some lining
you are using a laser jet or are making photo copies. if laser jet you need a new cart rage if photo copies the copy scanner has dust trapped in it
Apr 12, 2015 | Office Equipment & Supplies
My printing is so poor
if your printer is printing poor quality photos i would recommend changing out the ink cartridges and probably getting a new hd printer
hope this helps!
Apr 09, 2012 | Zebra Office Equipment & Supplies
How can I scan a document then print it with larger print?
You can scan a document or photo or negative film etc.. using a scanner, there a many types of scanners which you can choose as per your requirement. There are dedicated scanners, all in one integrated scanners, or two in one like that.. but if you need it for your professional use or daily use, it's better to get a dedicated scanner not "all in one" since with all in one if the copier fails or fax fails, the scanner will also fail because they are related and built-in integrated.
The process of scanning a document is as follows;
  • > Place the document on the scanner's flatbed.
  • > Press scan button or scan using the integrated software from the computer.
  • > Customize the scan settings/quality.
  • > Save the scanned documents.
Printing a document to a larger size is different, you can use photo editors like photoshop, paint.net etc..where you can changed the resolution as well as the size of the image. It's best to change the size or resolution before you give the print command. Or you can also change the print size with the paper size or print size.
If you still need more help, please let me know with more details. I am ready to assist you.
Good luck.
Thanks for using FixYa.
Jul 04, 2010 | Computers & Internet
I have an R2880 printer that has given me great results printing out of photoshop cs4 using a LaCie crt monitor. I changed to a Dell 2408wfp monitor and all my photo prints now come out dark. I have...
Print and screen color matching is HORRIBLY difficult. It could be a case of old ink, humid air, poor calibration, or different qualities of paper (when comparing two prints).
For best, most consistent products, go to a professional photo finisher/print shop.
Oct 25, 2009 | Epson R2880 InkJet Photo Printer
Rx 620 slow to print
Epson's RX620 scans and prints photos at high quality. Text, however, was slow to print and not that good.
it_portal_pic_41791_t.jpg Epson's multifunction devices fall into two categories: general-purpose models that are designed for home or small office use, and photo-oriented devices such as this, aimed more at the enthusiastic amateur snapper.
Because it's a photography-centred device, the RX620 uses dye inks. On photo paper, these produce more vibrant colours than pigment-based inks, and a true gloss finish, but on plain paper produce inferior, less vivid results.
The Stylus Photo RX620 is quite large, and looks dated - but it's not short of modern photo-printing features. Its built-in memory card reader is compatible with seven commonly used digital memory formats, including xD and SmartMedia. Photographers using film will appreciate the scanner, with its high optical resolution and transparency backlight.
On plain paper the RX620's text printing showed bandingand rough outlines on default settings. Our five-page black-and-white text document took two and a half minutes to print. Increasing quality settings made it even slower.
We tried realigning the print heads to improve print quality. The RX620's manual process involves choosing the best-aligned examples from four rows of 15 patterns. This takes good eyesight, and it can be hard to choose between similar-looking options. We needn't have bothered - text remained unchanged.
Photo printing was far better. The RX620 produced some of the best prints we've seen from a multifunction device, but only at its highest quality - and slow - setting. Our A4 test picture took 15 minutes 12 seconds to appear.
The RX620's scanner is excellent, previewing an A4 sheet in six seconds and scanning a 6x4in photo at 600 dots per inch (dpi) in just 14.5 seconds. Negative scan times were reasonable, with a single frame scanned at 2,400dpi in 1 minute 40 seconds.
The RX620 can perform many advanced functions without being attached to a computer, and its colour screen has a clear menu system. Prints can be made directly from memory cards, photo prints or even film. There are four document copying settings, but results using the default Text quality are adequate for most office purposes.
The RX620 isn't a brilliant multifunction device. It does many things well, but its printer is too slow, and simply not good enough on plain paper.
Please rate my solution after reading it. Thank you
Feb 27, 2009 | Epson RX620 All-In-One InkJet Photo...
Poor display quality (wallpapers, photos etc) of samsung g600
u should save images as .bmp and than transfer them to your g600, or save them as .jpeg but resolution should be 240x320 or less for good previewing!
Pictures in my photos just zoom in and out and quality is way better!
Or save some of them in mms save and then you can view it in full screen in that sms.
hope it helps a bit..
Nov 21, 2008 | Samsung SGH-G600 Cellular Phone
Poor print quality
your heads are defective due to a mumber of reasons. cheaper to buy new one
Jul 11, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Problems with sony cyber-shot dsc-t20
Kindly initialize your camera from menu and camera will starts with factory default settings.
May 27, 2008 | Sony Cyber-shot DSC-T20 Digital Camera
Poor lcd image quality
This is normal operation, it gives you a quick preview followed by a detailed one, if the camera was to put a detailed preview up straight away you would just have a blank screen to look at for 2 seconds
May 16, 2008 | Samsung Digimax L730 Digital Camera
Print is right when preview is very magenta (like 40 pts magenta)
This sounds like a calibration problem. The first thing I would try is to un-install the driver, download the latest drivers from the manufacturer's website then reinstall the new software.
I'm not familiar with the drivers of this printer but look to see if there is a printer/monitor calibration area try the settings there.
The other obvious place to look in is the software you are printing from. Try printer/Monitor calibration in the help menu
Jan 24, 2008 | Epson Stylus 2200 InkJet Photo Printer
Canon PIXMA MP610 InkJet Printer Logo
106 people viewed this question
old marine
old marine
