Question about Mitsubishi WD-52525 52" Rear Projection HDTV
The screan is dark on the top and bottom and color is strong
The screen comes on and it shows the picture but at the top and the bottom its black like the picture is being pulled in to the middle ...and the color is really strong and bright....i have cleaned the mirror and the 3 lenses and now the picture is more clearer but the color is still bright and tv still haves the black on the top and the bottom......maybe i need to re-in just the mirror.....can you please help me.....thanks
  • 41 Answers
This not the correct Model #, this model is a DLP set and does not have picture tubes and associated lenses. Did you remove the mirror? Does your set have a fold in back? I suspect the back is not fully out in the correct viewing position.
Posted on Dec 21, 2008
Half screan show dark rest screan o k
The LCD screen is defective, the only option is replacement. Go to www.ebay.com Type make and model of your laptop, refine search to screen and go through the list.
Jul 06, 2012 | Computers & Internet
Monitor turns on then goes dark
Either the power supply board is failing and needs repair or a bad bulb in the screen is causing it.
You would have to open it up to get a better idea.
Here's some info:
MAKE SURE ALL POWER is DISCONNECTED For at least 5 minutes PRIOR TO WORKING ON inverters.
If your picture wasn't pinkish or dark at the top or bottom when it was working, then it may be the inverter has gone bad. Inverters are like light bulbs and have life expectancies on the capacitors.
If your picture was pinkish or dark at the top or bottom when it was working then you may have 1 or more of the bulbs failing.
You can check for pinkish if your screen flashes.
What you do is when you have it open to the point of getting to the wires that hook to the back of the lcd screen is to disconnect only the wide ribbon that goes from the video board to the back of the screen. Then start it and check the screen flash color.
These come apart a little different than most. The front trim comes off with the screen. So essentially you are removing the back case first:
Once the four screws are out of the rear corners there are snap tabs that need to be released between the silver trim and the back black plastic (three top and bottom and two on left and right.)
You can use a thin knife blade to help release them as you separate the silver from the back plastic Black part has to be bent outwards to release these tabs.
Then entire guts will come out with the screen ., then the inverter is under the center area under the metal cover.
Shout if you need more info.
If you email me a good picture of the inverter in the area of the larger yellow square component and one from underneath , behind the two small yellow square components, I may be able to get a better idea if it is the inverter from a visual.
Email : bammbamm@ptd.net
Mar 29, 2010 | ViewSonic VX715 17" LCD Monitor
I'm trying to improve the picture- seems to be TOO DARK- tv is 10 yr old ser3 935351541- ihave tried color adj etc
Rca Screen Control These sets have screen control adjustment usually located behind the speaker grill(pops off -velcro or press tabs) and convergence front board. There are 6 contols on a black molded assembly about 31/2"x21/2" square. adjust only the top controls marked "Screen R G B" the bottom ones are focus
Method:
-turn on set and let warm up for 30 min at least
-switch tv to blank unused video input channel
-adjust each control in turn until you see the picture glow (with the corresponding color) and slightly back off the control - repeat for each color - this will increase screen brightness and ballance your color
Hope this helped.
Oct 18, 2009 | RCA P52945 52" Rear Projection Television
MD96015 Monitor problem
Sounds like you may have a bad LCD backlight or inverter. When the screen is dark, take it into a dark area and see if you can see the screen dimly showing. Or, shine a flash light on the screen and see if you can make out anything showing up.
Try this and let me know what you find.
Ron
Dec 10, 2008 | Computers & Internet
Dark picture
you know it sounds like the same problem i had....
look this is something you can try.... "turn the tv off and unplugg it!!!"...you'll need to take out the lower front part of the tv......(where the speakers are to be exact) on each lower end you will find 2 screws..Be careful it will open to the side and there are many wires, i suggest you mark them to know where to put them back...then right in the middle there will be a black cover with about 5 screws..take them out....and look at the very bottom you'll see a thing with 6 pegs....the top ones are for the screen "DO NOT TOUCH THEM"...the ones on the bottom are for the colors...re adjust them...the left one it's for blue, the middle one it's for green and the last one it's for red...
I had the same problem after i moved....and after i re adjust that the tv looks super...
i hope that helps..:P
Sep 17, 2008 | Sony KP-53HS30 53" Rear Projection...
Screen is Black, light I'm in a dark black room black
Same problem as you described. I haven't figured it out yet.
Jul 20, 2008 | Samsung L700 Digital Camera
Color on the picture is dark
You can adjust the brightness on the back of the set which says screen. put a mirror so you can see the screen and slowly turn the screw clockwise until you can see the picture.
Jul 10, 2008 | RCA F36650 36" TV
Rca p52771at - dark picture
Sounds like a bad screen asy,part number 204809,must use the generic,or you could have weak tubes,if so you may just need to turn up the screen drives,this part is located in the right top of the set with the back removed,if no cracks are present adj. the three marked screen's,turn the color all the way down in your menu and adj. for a black and white picture.
Oct 07, 2006 | RCA P52771AT 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
52 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
