Question about Astar LTV-19BG TV
NO PICTURE FOR TV
DVD PLAYS FINE TURN IT TO TV NO PICTURE
  • 40 Answers
First turn on your DVD player and keep your DVD playing. Then set your TV in to AV1 (the yellow, red and the white cable) connecting in the back of the TV. Any question call 323-767-6030 and I will go through it, with you.
Thank you,
Ivan.
Posted on Mar 06, 2009
Jumping picture on playback on TV DVD player
Try using another brand of DVDR (cheap ones tends to cause porblems in regular DVD players) and burn at a slower speed.
Nov 24, 2007 | Pioneer DVR-112D DVD RW Dual Layer Burner
TV plays fine when dvd recorder is off. As soon as you turn on recorder the picture gets snowy. It doesn't matter whether it is on video 1 or on the channel setting. I have changed all the cables, still...
It seems that you are keeping the recorder close to the TV set resulting distortion in the picture due to power supply hum,check by keeping it away from set if no change than check the reason of hum received from power supply of recorder by replacing electrolytic capacitors for leakage or proper shielding of power supply in side the recorder.
Jan 22, 2011 | Panasonic DMR-ES40V DVD-Video Recorder
My TV doesn't have any sound with its cable. The
Tries difference setting in the SOUND setting,see how it turn out.Like setting in Variable setting,instead of fix setting.Setting in MONO setting,istead of STEREO setting.
Jun 25, 2010 | RCA 32F531T 32" TV
No longer plays color picture
Try the settings for "pal - ntsc - cvbs" video formats, if the tv and dvd aren't set the same, then this can cause the problem(usually with distortion to picture, depending on how it's mis-matched)
Jul 05, 2009 | Coby DVD-224 DVD Player
Hi I bought a goodmans dual format dvd recorder GDVDR319, tuned in fine, plays fine etc but the picture is pink. Instructions say check the video output but no idea what that means. Thanks
If your normal TV pictures are ok then carefully check your scart plugs are pushed right home and fitting squarely at the TV end and the DVD end.
Jun 14, 2008 | Televison & Video
Vizio liquid crystal tv l32hdtv
Check the cable connections and/or replace the cables to the AV2 input.
If replacing the cable doesn't provide a solution, try running your DVD through the input. Since it works fine now, you would be checking the input AV2 by putting your working DVD. If the DVD plays with no problems, the input is fine.
Also try the VCR using coax into the TV instead of RCA into AV2. This will give you some idea about the condition of the VCR.
I suspect either the VCR or the cables.
Apr 22, 2008 | Vizio L32 32 in. LCD HDTV
Black and white picture
turn off you dvd player... them click on "setup" button on your remote control! them click right botton to appear "tv sys" them click "enter"... choose your tv system, PAL or NTSC.
Jan 15, 2008 | Pioneer DV-360-S DVD Player
Picture only shows in black & white when playing DVD
Same problem with an older JVC player. One end of the S-video cable was loose. Pushed in in tight and everything ok again. Cheap fix if it works for you.
Dec 21, 2007 | Televison & Video
Phillips Projection TV
make sure you have the correct video input connected, play a movie in the dvd player do you get anything, can you use a different video input?
if all is correct go to the menu and see if the menu screen comes up.
Dec 02, 2007 | Philips Magnavox 51MP392H Rear Projection...
Astar LTV-19BG TV Logo
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
