Question about Coleman Powermate Powermate 5000W Generator
Wont turn over
I have a coleman 6875 doesnt seem to be getting a spark and even with a new plug.
  • 169 Answers
Check the oil level, these generators have an oil monitoring system that prevents the engine running if the oil isn't all the way up to the bottom of the threads in the oil fill hole.
Posted on Jan 02, 2009
I am unable to pull the starter rope and start the engine. It has been covered and unused for a few months and the oil looked good. Any suggestions
take the plug out and see if it will turn over try to start it with the plug out. if it does turn over you can put the plug back in and see if it will start. but it sounds like the needle and seat in the carburetor are bad letting fuel into the combustion area where it becomes full of gas and wont allow the engine to turn over because of compression (replace the needle and seat)
Mar 13, 2017 | Garden
What spark plug does a Coleman Powermate 6875 use
Doesn't seem to be anything online. Phone them and ask.
Specs are here
Generator manual with phone number
Oct 05, 2016 | Coleman Electrical Supplies
How do you change the spark plug on a Coleman Powermate 5000 10P Generator? It has been sitting for about eight years since last use and won't start. Would like to change the spark plug, but it seems...
The plug is under the gas tank. They can be difficult to get to and you may have to remove/loosen the tank. If you can remove the spark plug wire you could test for spark. If you have a spark and it still doesn't crank the spark plug is probably the least of your worries unless you drained the tank and the carb (most people don't.)
If you have a spark give a spritz of starter fluid into the carb after removing the air filter and see if it runs for even a bit. If it does fire and doesn't run, clean the carb.
Good luck.
Jan 07, 2018 | Coleman Powermate Powermate 5000W...
Generator has been running steady for 2 weeks. It will not start now. It has spark, gas is good, oil is good. It is a 5000 coleman powermate electric generator. Did it die due to a 2 week running? It...
if it doesnt turn over how did you test the spark?
if i have read it wrong then always try a new spark plug, these can fail under compression but will spark happily outside the cylinder.
if it wont turn over then it could be siezed or dropped a valve.
Apr 23, 2011 | Coleman Powermate Powermate 5000W...
Honda lead 100cc scooter wont start atall.changed the spark plug and filter still no luck.doesnt seem to be getting petrol to the spark plug
maby you have touched somthing on the carb when you changed the air filter or maby spark plug is to big or maby faulty try new one or your old one
Apr 13, 2010 | 2007 Honda XL 125 V Varadero
A coleman generator 6875 won't start please give
Dump ALL old fuel out of tank, you might have got a clog in the fuel line, carburator, fuel valve. Remove carb bottom Sediment bowl then spray Carb cleaner thru the gas inlet AT the carb 3-4 secs CAUTION: KEEP YOUR HEAD BACK.. that cleaner hurts if you get it in your eyes... and NEVER SPRAY A HOT ENGINE (np with yours tho no start) Refill tank with NEW fuel (or strained at least if emergency remote repair) Place a suitable catch container over gas inlet line to carb (at carb) open fuel valve chk for fuel FLOWING (no dripping) into container. replace fuel line to carb start as normal
if not firing still chk that spark plug, might need cleaning now that rest is ok.
Nov 21, 2009 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
What carb does the powermate 6875 use?
check this web site you can down load the manual and parts list for your gen.
Mar 24, 2009 | Coleman Powermate Powermate 5000W...
97 blazer cranks but wont start,when does start runs great
Your next step in diagnosis your problem should be to check for spark, you'll have to use a spark tester for this, simply removing a spark plug and looking at it WILL NOT WORK, a spark tester looks similar to a spark plug but it has about a 3/4" gap.
Another thing you should check is the voltage of the battery with a multimeter while cranking the engine, if it drops below 9.6v your computer will turn off and your injectors wont fire and neither will your plugs.
If you don't have a multimeter just try jump starting the vehicle.
Hope this helps
Feb 22, 2009 | 1997 Chevrolet Blazer
Coleman 6875, Does it have an auto idle???
If you've got an auto idle function you'll also have a switch somewhere to shut it off, so look for that first.
Engine surging is almost always a problem somewhere in either the air cleaner or the carb. Check the air cleaner, if it's not dirty take the bowl off the carb and look for dirt in the bottom.
Feb 02, 2009 | Coleman Powermate Powermate 5000W...
Wont start
Check the spark at the plug,the compression and carburation.Check and clean the gas and air filters.Disassembly thr carb and clean it with compressed air.Change the gas from gas tank and start the engine.
best regards savumihai71
Dec 20, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Powermate 5000W Generator Logo
342 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
