Question about Samsung LN-S4041D 40 in. LCD HDTV
Getting lines in my picture
It stated with a spot on the upper right side of picture . Now there's a line coming down fro the spot down the right side of the screen. What can I do to fix it myself?
  • scottagregor Jan 17, 2009
    Same problem - Lines started appearing...
  • simoneadams9 Feb 02, 2009
    I have a similar problem, a black patch just off the centre of the screen and within the black patch is a white dot. Any ideas what the problem is and how to fix it as the TV is 3 months out of warrenty (just my luck!)
    Thanks
The problem i have with my samsung lcd tv, as soon i put it no,instantlly it will toun off. what do u think is the problem? send me a mail matayo4life@yahoo.vom
Posted on Dec 20, 2008
Richo 1013f copier problems-grey lines on copies
Most often this problem is coming fro the PCU or Photoconductor Unit. If you open the right side door just look for the long greenish colored cylinder. It should be clean. If you see a toner film or more specifically the same "lines" on the surface of the drum that you see on the copies then you will know. If this is the case you will need a new PCU. Installation is a piece of cake.
Here is a link with pictures, part numbers etc.
http://www.precisionroller.com/search.php?q=ricoh+1013+drum
Good Luck and Thank You for using Fixya.
Sep 03, 2010 | Ricoh Aficio 1013F Copier
Upper left side scroll buttons take the curser to the top or bottem of list , no one line at a time. Do you think the problem is the button or board or software?
Use your Thumb stick to move the cursor around the screen, from one icon to another. The left side buttons are for scrolling from screen to screen only.
Manual states: Move up/down, right/left to move through lists, highlight fields, on-screen buttons, icons, enter data or move the map panning.
If this solves your problem, please come back and rate our solution, thank you.
Mar 26, 2010 | Garmin eTrex Legend GPS Receiver
Vertical line and five spots in every sheet of paper I print
Thats on the drum, time for a new cartridge.  The equial distance of the marks on the right side of the page point to the drum  which I presume is built into the toner cartidge.
May 30, 2009 | HP LaserJet 1012 Printer
Red line down right side of screen
I would have a tech come out and look at it. Sometimes the ribbon connectors from the upper or lower buffer boards have poor or corroded contacts. Should'nt be a major deal since it comes and goes.
Apr 21, 2009 | Vizio P4 46 in. HD-Ready Plasma Television
SONY TV MODEL # KP-65WV700 SER.# 9002706
Blue Gun is right side of TV if you look in TV from back side. Part number is as follows..
8-733-663-25 {CRT 07MVC62(B)-L} [KP-65WV700 ONLY]
Mar 13, 2009 | Sony Televison & Video
Spots on picture
I had the same problem. Panasonic is kind of a pain about the whole thing. You have to find out who your local Panasonic repair place is, tell them there is a service bulletin and they will get on it. You must be diligent! Do not take no for an answer! If it comes down to it, and the repair shop won't do it for you, then call Panasonic and endure a loooooong wait time. Trust me though...this is the issue. Once the eeprom gets fixed/updated/whatever, the picture looks amazing! Good luck.
Aug 16, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Spots/Lines on the prints
Take out the drum cartridge (piece with the long green arm) and look down inside the printer for any toner that may be leaking on your pages.
So I understand correctly, you were seeing different color toner on the cyan and yellow rollers?. If so gently clean that side of the roller off. Rotate the white gear on the right side of the toner cartridge back towards you and see if the correct color comes back on the roller. If you were seeing grooves on the roller then they will have to be replaced.
Put the toner cartridges back in and run color calibration.
Press menu/select. Right arrow key until you get to engine. Press select. Left arrow key until you get to service.
Press select. Right arrow key until you get to color calibration.
Press select.
Any other information would be helpful.
Jul 17, 2008 | Konica Minolta magicolor 2430 DL Laser...
Horizontal blue line
The intermittent horizontal line is cause by a loose solder connection in the vertical amplifier IC.
The IC is mounted on a heatsink nearby or around the flyback transformer.
The way to fix this failure is to add fresh solder where you see some brown spots on the circuitry that were cause by components getting hot.
Good Luck.
Jun 20, 2008 | Sharp 25R-S100 25" TV
Samsung LN-S4041D 40 in. LCD HDTV Logo
108 people viewed this question
Henry  Thomas
Henry Thomas
