Question about Konica Minolta DiMAGE Z3 Digital Camera
NEW sd 2gb inserted into KonicaMinolta Dimage error
Error message comes up " unable to use card"
Would like any suggestions on what to do.
The card in the format that it is in works fine in my other digital camera. (Cannon Powershot)
Hi, have a look in the troubleshooting solved probs list. There is a solution and link with instructions to upgrade the camera firmware. I had a look and just decided to run with 1gig cards, it's a bit complicated!
Posted on Feb 09, 2009
Error message when trying to install new sd card
Some cameras cannot take certain types of SD cards. They could be too new for the camera or have a higher storage capacity than the camera can recognize. Sometimes you can update camera firmware to accept these cards, but often you are limited to what the camera can accept.
Sep 16, 2014 | Cameras
I have inserted a new sdhc 4gb card in my Dimage x 50 and have reformated but keep getting Unable to usecard
The X50 works with MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You will need to use cards 2GB and smaller.
Jan 25, 2011 | Konica Minolta DiMAGE X50 Digital Camera
Turn on camera and system error screen comes up and you cannot do anything to camera.
1st you need to update the firmware to 1.3u
download firmware here
http://ca.konicaminolta.com/support/americas/digital_cameras/dimage-z/dimage-z3/software_drivers/index.html (this allows 2GB cards)
instructions are here
http://ca.konicaminolta.com/support/americas/digital_cameras/dimage-z/dimage-z3/software_drivers/firmware/installation_guide.html
(instructions are a little vague on where macro mode button *flower button* is)
Also, you might have a bad SD memory card. format the card (erasing all data/pics on card)
and take some picks and try again.. if you can
If still a system error try a different SD card to get past error then update firmware with THAT SD card.
IF that don't work.... your hosed... ;(
Nov 17, 2010 | Konica Minolta DiMAGE Z3 Digital Camera
Unable to format the 2GB Memory card. Message occurs : Windows unable to complete the format.
A hidden application is disrupting your format process download "unlocker" software application from google, install it then right click on the memory card icon you find unlocker option double click n press unlock all after this try formating your memory card will work fine
Sep 20, 2010 | SanDisk 2GB microSD Memory Card
Minolta dimage s414 camera, error no card try to use a 4 gb flashcard and then it read unable to use card.
The S414 was designed to work with SD cards. Your 4GB card is actually an SDHC card. While it will fit into the slot, it will not work. You need to stay with SD cards, 2GB and smaller.
Jul 11, 2010 | Konica Minolta DiMAGE S414 Digital Camera
While using my Magellian GPS 1200 the screen froze up and when I went to restart it the following messang appeard.SD card has been removed.Program will restart.Please insert SD card with map. I tried re...
More then likely when the screen froze up on you it it had a little power glitch as well, nothing serious but it did wipe out some of the information in it's memory about the SD card.Power the unit up and let it come up with the error, then use the reset button. Might be hard to find since it's just a little hole with the word reset around it, using a paperclip push in the button and see what happens. If the error comes up again then i am thinking that you will need a new SD card. Quick test for this, remove the SD card from the gps unit and try rebooting, it should come up with an error, no SD card or no map, stick in an SD card from another device, 2gb, see if the gps can find the card, it should give you an error that says unable to find maps. If you get these error codes then most likely the gps unit is fine but it pooched your programs on the SD card.
Hope this helps
Apr 27, 2010 | Magellan Roadmate 1200 Car GPS Receiver
Inserted new memory card error message:memory card error unable to access format under menu
I'm guessing that you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Nov 07, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Minolta Dimage S414 camera doesn't like a new 4GB CF card
Check your manual to see if your camera accepts a card that large.
Aug 30, 2009 | Konica Minolta DiMAGE S414 Digital Camera
When inserting SD Card in to Dimage Z5 the camera will not read card. (''Unable to use card.) Please help.
http://ca.konicaminolta.com/support/americas/digital_cameras/dimage-z/dimage-z5/compatibility/detail.html
Your card is probably not supported by the camera.
Jul 05, 2009 | Cameras
Card can not be formatted
There is a write protect switch on the side of the card. That may be the reason why the comp is unable to use it.
Jun 05, 2009 | SanDisk 4GB Secure Digital High Capacity...
Konica Minolta DiMAGE Z3 Digital Camera Logo
652 people viewed this question
Top Konica Minolta Cameras Experts
Computer Links
Steven Wander
Steven Wander
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
