Question about Maytag MSD2756G Side by Side Refrigerator
My side by side Maytag fridge
I have the back of freezer panals removed all the way up to the ice maker. The drain at bottom does indead seem to be plugged but at the rate of the ice buildup, the pan underneath the fridge would overflow within a week. Therefore, there must also be a leak in the ice maker causing the water build up in the bottom in the first place.
Does this sound like a plausable cause?
  • dano5659 May 11, 2010
    Where is the tube that should be cleaned? I see a 1/2 inch hole on the right side (inside the freezer) about 6 inches above the bottom panel. Is the drain tube hole?
  • Anonymous Mar 20, 2014
    how do I remove it? there seems to be a clip on the bottom left side but the unit won't side out
    Scholar:
  • 111 Answers
There shoud never be ice built up in the bottom. The problem is thatthe defrost drain water is not getting to teh pan underneath. If it were coming from the icemaker you would have a colum of ice from the icemaker area down the back wall... like a stalagtite. It still sounds like you just need to clean the tube that goies from the inside bottom of the freezer to the drain pan with a turkey baster and hot water
Posted on Dec 20, 2008
Maytag side/side model MSD2754GR- Ice maker while filling overflows running out of freezer section onto floor.
Remove the back panal in the freezer compatment to reveal the evaporator. You will notice the drain pan frozen up with ice. pour hot water on it or blow hot air with a hair drier. If the fridge is turned off the ice will melt and clear the drain hole. When the ice is cleared the water will be alowed to flow out to the evaporating pan under the fridge. Be sure that the water runs freely out of the fridge and allow a few hours to dry. Good luck. Be careful not to damage the evaporating coils.
Dec 07, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water on the inside floor of the refridgerator,
remove back panel from freezer and unglog hole where it collects water. its glogged
Feb 11, 2010 | Maytag MSD2756G Side by Side Refrigerator
Found water leaking from our maytag side by side model MSD2142ARW. Disconnected ice maker 4 weeks ago thinking it was that, and still leaking and has ruined my new laminate floors. Is the freezer gasket or...
The defrost drain hole in the freezer side is frozen closed.
Turn off the fridge.Remove the bottom bin and look on the back wall of the freezer for the drain pan. It will have a block of ice in it. Use a hair dryer to defrost the pan AND the drain hole inside the pan,until you can pour a cup of water through the drain hole.
Dec 28, 2009 | Maytag Freezers
My Maytag wide by side is leaking water from the
Yes. Your defrost drain hole in the lower rear of the freezer is frozen over with ice. Turn off the fridge. Remove the shelves and bins from the freezer side. Break up any ice on the floor of the freezer and dispose of it. Use a hair dryer to melt the ice over the drain hole in the rear portion of the freezer. Once it is clear pour a 1/4 cup of bleach into the drain hole.
Dec 20, 2009 | Refrigerators
Ice build-up water leak
sheck the back wall of the freezer where it sits in that trough, more often than not this complaint is the fault of a defrost drain. if you can try to remove the back panal on the freezer, if its a defrost issue there willl be a huge amount of ice behind that panal blocking the defrost drain.
after you chip what you can away, you'll find that a hair dryer and hot water are the best way to get that drain clear so it wont happen again
Oct 12, 2009 | Maytag MSD2454G Side by Side Refrigerator
I have a problem with my freezer, it has water pooling then freezing in the bottom of the freezer. The water also runs out onto the floor. It looks to be coming out of the opening in the back of the...
Your defrost drain line is clogged and frozen over with ice.
Turn off the fridge. Remove the bottom freezer drawer. Take a hair dryer and thaw the drain hole at the back bottom section of the freezer. After you defrost the drain line pour 1/4 cup bleach into the drain hole.
Jun 28, 2009 | Maytag MSD2454G Side by Side Refrigerator
I have a maytag MSD2754GR, the freezer bottom is all iced
The drian hole has become stopped up and ice has accumulated in the the drian hole. You will need to unplug the fridge and remove the cover on the back (located at the bottom, 6 screws). On the freezer side there is a drian hole with a rubber 90 and a clear line that runs to the drain pan. Remove line and unstop. Don't not put the line back on yet.
Now for the fun part, remove the basket and the two bottom shelves from the freezer. Half way up the back there are 2 screws that need to be removed. After removing screws pull up on the top cover to so you can remove the bottom cover. The bottom cover maybe froze to the coils and to the inside drain pan. Break the ice with a butter knife, and remove cover ( do not hit the coils). Now you need to break the ice that is froze to the the pan and under it. Once you have remove all the ice you will see the drain hole, use a small pointed object to break ice that is in drain hole. Now you can put the drain line back on and make sure that the other end is in the drain pan under the fridge. Now reassemble the fridge and plug it back up.
It took me about 20 minutes to do this.
Hope this helps.
Jun 22, 2009 | Maytag MSD2456G Side by Side Refrigerator
Ice on bottom of the freezer
Your drain is blocked causing the ice in the bottom of the freezer.
The drain is located about 7 inches up from the bottom rear of the freezer.
Just below the back freezer panel.
Turn the fridge OFF.
Remove the bottom bins.
Take a hair dryer and thaw the ice in the drain.
Pour 1/4 cup of bleach in the drain line.
Problem solved.
Feb 24, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Ice build up in bottom of freezer
Check the ice maker. sometimes they get cracked a will leak water into the freezer compartment. Also check the ice maker fill tube for leaks or someone could have spilled something. Although this is tipical of a clogged drain. What happens is when the fridge go into derfost, it will melt all the frost that is on the evaporator, turning it into water. The water drains down to a trough under the evaporator and down a drain hole in the trough ( this trough is behind the evaporator cover ) Removing the melted frost from the freezer. If that drain is clogged, the water cannot leave the freezer. Then when the fridge starts back up ,it will freez the water that was not drained. After repeated defrosting the water will fill this trough and run off into the bottom of the freezer to be frozzen when the fridge starts to cool again.
Nov 16, 2008 | Refrigerators
Ice and water on bottom of freezer
sjlobo, sounds like your defrost drain pan is frozen over or has some gunk in it. When the unit goes into defrost the water is running onto the freezer floor and out the front. Remove the lower bin and check the drain hole. You may have to remove the freezer back panel. If you can, just use some very hot water and some sort of baster to unfreeze the drain. Check this first, Catriver..post back.
May 05, 2007 | Maytag MSD2758G Side by Side Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
150 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
