Question about Microwave Ovens
I have a panisonic inverter microwave that shuts o after running.
I can set the timer to any time lenght but it just shuts of every time the same after running less than 30 seconds. It was working fine yesterday. This has been a good unit and I hate to just throw it away and get another if it can be fixed without too much exspense. What do you think the problem might be?
  • shovel071 Dec 21, 2008
    I have a Panasonic "Inverter System" 1300 W Model NNS952WF large white microwave manufactured 6/2002. Recently the microwave just shut off after approx 25 secs . Well I decided to remove the cover and check things out, I cleaned it up in rear blew some dust off realized everything looked like a bunch of computer board componets and realized I was above my head. So I put the cover back on and plugged it back in. Now it shuts off under 3 secs. SO my prety microvae sits. I am not sure if it would be worth fixing or buying a new one?
MicrowaveSvc
  • 9125 Answers
SOURCE: Microwave runs for 3 seconds and shuts off
This is an inverter-driven model, and this is one way the inverter fails. Often it will tick, too, but the cooling fan may be too loud to hear ticking. If you haven't had smoke, then it may not yet catastrophic. I would bet that a thorough resoldering would take care of it. A good technician can troubleshoot and repair this, as needed, but often they will just replace the inverter. Sometimes that's actually cheaper. Troubleshooting an inverter is way too much for someone without good solid technical experience. I would call a shop and ask for an estimate to replace the inverter. Good luck.
Posted on Oct 14, 2006
MicrowaveSvc
  • 9125 Answers
SOURCE: Microwave shuts off after 3 seconds
Although your model number doesn't seem to show up, the NNS950-series units are powered by an high-voltage inverter. And yours has failed. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan. Sometimes a whole new inverter is cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized appliance / microwave repair shops and ask then specifically about inverter component-level repair and simple inverter replacement costs for your exact model number.
Posted on Dec 28, 2006
MicrowaveSvc
  • 9125 Answers
SOURCE: Unit runs for 59 seconds and shuts off
This is a problem in one of the damper-related components, most likely the switch or motor, but it may also be the motor or the damper door.
The damper is a door located on the right side of the innards. The damper closes and opens depending on cooking mode.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can order Sharp parts from Tritronics at http://www.wehaveparts.com
You can find a helpful exploded view by entering your model number here: http://www3.sears.com
Posted on Nov 17, 2007
SOURCE: Panasonic NN-S262SF stops cooking after 3 seconds
inverter problem the transistor 1M30D is shorted
Posted on Jan 07, 2009
cactus bob
  • 267 Answers
SOURCE: microwave cut off
the main control board is "seeingf" a high amprage draw from the inverter board . you have a problem with the inverter or the magntron . parts are more than a new unit . try to stay away from the inverter type , there just not ready for prime time . google "panasonic inverter reviews " and you will see just common your problem is good luck
Posted on Jan 17, 2009
Panasonic microwave problem help needed
Dan, That unit has an inverter, that is the power source for the part that puts out the Microwave energy called the Magnetron. The inverters are expensive and I stopped doing warranty work for Panasonic beacuse of them. Some pencil pusher somewhere though it was a great idea to replace 3 common fairly inexpensive parts. with that dang inverter. Microwaves have come down a lot in cost, I would buy a new one without an inverter. Sorry, wish I had better suggestions, I DO NOT LIKE THEM. LOL Sorry! Panasonic and their distributors are always out of them and there so expensive no one wants to stock them. I have had new ones sent to me that were already bad.
Aug 20, 2017 | Microwave Ovens
NN-SD6968 set the timer, press start, timer counts down, microwave doesn't run?
I just developed this problem with my panasonic inverter microwave...does anybody know about this problem?
Apr 12, 2011 | Panasonic Microwave Ovens
Panasonic Genius Sensor 1300W
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Aug 30, 2009 | Panasonic NN-SN657SMicrowave Oven
Panasonic Model No. NN-S933BF Microwave Oven
No sorry the issue will be with eiher the inverter, the magnetron or the main timer board. There is a tracer signal that comunicates through these components and if it doesnt get to where it is supposed to go it wil just shut off, the big hint at that is the time interval. It is not something like a sensor heating up and causing a fault. it is not running long enough to get any thing hot it is in the electroincs. Too expoensive to repair, im sorry better to get a new one. Good Luck
Jun 17, 2017 | Panasonic NN-S950BA Microwave Oven
Microwave cut off
Jan 16, 2009 | Panasonic NN-S753 Microwave Oven
Help, my Panasonic NNA724M Combination Oven will no longer microwave. I can set the microwave going but after 20ish seconds the microwave stops and timer is replaced by the clock, without any audible...
This is an inverter model, and when they stop after 20 seconds, it usually means a problem in the high voltage section, either the inverter or the magnetron.
If you don't have experience troubleshooting high voltage inverters, I recommend calling a pro.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 01, 2008 | Microwave Ovens
NN-T990SA Panasonic Microwave Stopped Heating
This model uses an inverter to produce high voltage instead of a convential transformer system. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan. Some manufacturers do not encourage or assist technicians to repair microwave inverters. Most offer the inverter as a whole assembly. But sometimes that is actually cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized repair shops and ask then specifically about inverter repair and inverter replacement costs for your model number.
Dec 21, 2006 | Panasonic NN-T990SA Microwave Oven
Oct 13, 2006 | Panasonic NN-S252WF Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
