Question about Fedders A6P09S2A Air Conditioner
Room air conditioner
Questio. the fan will not come on everything else is working
  • hotnbothered May 15, 2008
    Unit outside is running along - pipes in the attic are cold and there is condensation - green lights inside - FAN NOT BLOWING???
  • 944 Answers
Here is the link to the user manual; http://www.fedders.com/IandOResidential/Appliances/FedSglDualPort.pdf check page 6 first about timer controls and check there is nothing set there that may be stopping the fan. then check the fan hasnt been blocked or damaged, particularly by a damaged filter. Then the most likely problem would be a fault in the fan motor itself - sometimes these will have a thermal cutout switch which can be reset, or an electrical fuse. check for these if you fancy trying a repair yourself. If there is no cutout or fuse then a replacement motor would be probably worth it, although they can often be fixed, it is labour intensive and skilled so could be expensive. in the user manual are all the contact details for fedders dealers and repair facilities, also details of how to get spares (page 9). Hope this helps :)
Posted on Apr 11, 2007
The bottom blower fan (blows hot air out) on my Haier room air conditioner broke and broken plastic parts were inside. I took the broken pieces out and now the fan motor wont turn on. Could motor have...
you can ohm the motor out. Go between each wire and see if you get an ohms reading you should have a reading if you don't then you have a winding burnt out.
Aug 21, 2014 | Heating & Cooling
Tip
How to cool big home with small air conditioner(s)
A lot of people have only one or two rooms that can take an air conditioner in the window. Often times, the air conditioner is also rated at a cooling power that would make you believe that there is no way that it can to cool the whole house/apartment. You can crank it to the max to try to cool as much as possible, but then this makes one room too cold and the others still stay too hot. You can try blasting the cool air down a hallway with a fan on maximum speed, but that only works so well. And, it's noisy, too. Well, I have two 260 sqr ft rated room air conditioners and I am cooling 2000 sqr feet of house to a comfortable 72 degrees in all rooms and it's been 95 outside all day. How to do it?
The trick is setting up your home to take advantage of laminar air flow. Set your air conditioner to say 68 degrees and start it in the middle of the morning before it feels hot outside. Put the AC deflectors pointing downward and towards the door. Put fans in the doorways pointing out of the rooms that have the AC. Point them level to the floor (not up) and put a fan to one side near the end of long hallways. Set the fans on the lowest power setting (not high). If the hallway branches out into a bigger room, put a fan in the room that is blowing across at a right angle to the entry, pointing the air flow parallel to the wall. This will circulate the cool air around the room. Keep the fans on low and pointed parallel to the floor, not up!
What you have created is a re-circulating air flow system, much like the North Atlantic Current that moderates the temperatures of Europe. You can check this by taking a tissue paper and holding it up to the top of the doorway. The air flow should be pushing the tissue away from the room without the AC and toward the room with the AC. This happens because the warmest air will be toward the ceiling and you want that warm air to make its way across the ceilings and back to the room with the AC, so that it can be cooled again. The cooled air from the AC will sink to the floor and the fans will gently push the air out of the room with the AC. It will stay low and travel along the floor in the opposite direction and into the warmer rooms. If you crank your fans up, you will create turbulent flow and that will not cool your house as efficiently as will laminar flow. Monitor the outside temperature and when it gets cooler outside by a few degrees, turn the AC to fan for about 10 minutes to eek out the last of the cooling. Then open the windows for the night to take advantage of the free cooling that nature provides. That's it! Enjoy the summer!
on May 25, 2015 | Heating & Cooling
Haier air conditioner won't cool the room anymore
i bought the air conditionor new and it will not cool what can i do
Jul 05, 2012 | Haier ESA406K 6,000 btu ECO-Friendly...
Air conditioner not working
have you tried turning off and on power from the plug ?
Aug 17, 2009 | Haier HWR08XC7 Air Conditioner
Kenmore room air cond fan runs, no cool. checked
if the fan motor is on but the compressor is not : if the compressor has correct voltage up to the terminals and is not operating, the compressor is bad, if ther is not power to the terminals, the start components may be the culprit, if there is no power to the start componenets then the controller is the issue.
Jul 18, 2009 | Kenmore 75123 Wall/Window Air Conditioner
Air condition unit freezes up
the unit may be too small for the room. or the filter need to be cleaned. also once a rea you need to sprey a mixute of warm water and amonia to clean the coils.
May 16, 2009 | Hampton Bay HBLG5004 Air Conditioner
Fedders A6P09S2A Air Conditioner Logo
212 people viewed this question
Top Fedders Heating & Cooling Experts
Donni Steen
Sheldon Dedek
Mike
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
