Question about Dell PowerEdge 840 (becwmk1_2) Server
Will only power up for 5 to 10 seconds and then shuts off. I have to unplug the power cord to repeat.
  • Angelo Attard
    Angelo Attard May 11, 2010
    does it get to the windows logo
    President:
  • 1,179 Answers
It sounds like an overheating problem. The newer cpu's have a thermal shutdown sensor that automatically shuts down system if it senses a temp that is too high. Common solution would be to check your cpu/ chassis fan and see if they are working. If not replace.
Posted on Dec 20, 2008
Printer works but gives blank page
Issue: Scans and copies output a blank image Solution: Press ON/OFF switch to reset the multifunction device Reset the device when it is not functioning properly.If the device is not functioning properly or to clear memory, reset it.Important: If resetting the printer's power does not clear the error or return the machine to a functioning state, it may be necessary to attempt a service reset. Click here for instructions to attempt a service reset.On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.) Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.Wait approximately ten seconds and then press the <ON/OFF> button again.Wait until the device has completed its cycling process before submitting another job request.Service Reset:On the operator panel, press and hold the <ON/OFF> button for one second to power off the printer. (The display will go blank.)Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.Confirm the printer is not on and then unplug the power cord from the back of the printer.If the power cord was disconnected (as stated in step 1) in order to shut off the printer, go to step 3.Press the <ON/OFF> button repeatedly five times. Re-connect the power cord.Press the <ON/OFF> button to power the printer back on.Wait until the device has completed its cycling process before submitting another job request.Important:This procedure will not resolve a physical hardware issue. For example, a paper clip is wedged between the paper feed rollers or gears; or, the scanner assembly is detached from the inside housing.This procedure will not resolve all service errors or LCD related anomalies.Service errors appear as four characters (a combination of alpha and numeric codes).
Oct 13, 2011 | Canon PIXMA MP150 All-In-One InkJet...
How to solve E42 printer canon MP 140
  1. On the operator panel, press and hold the button for one second to power off the printer. (The display will go blank.) It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Confirm the printer is not on and then unplug the power cord from the back of the printer.
  3. Press the button repeatedly five times.
  4. Re-connect the power cord.
  5. Press the button to power the printer back on.
  6. Wait until the device has completed its cycling process before submitting another job request.
If the problem still persists, I am afraid you have to take the printer to a service expert.
Sep 30, 2011 | Canon PIXMA MP160 All-In-One InkJet...
How do you clear memory - its telling me its full but I have no message saying cartridges need replacing
Issue: ERROR LCD: MEMORY FULL
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it. important.gif Important: If resetting the printer's power does not clear the error or return the machine to a functioning state, it may be necessary to attempt a service reset. for instructions to attempt a service reset.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Service Reset:
  1. On the operator panel, press and hold the <ON/OFF> button for one second to power off the printer. (The display will go blank.)
  3. Press the <ON/OFF> button repeatedly five times.
  5. Press the <ON/OFF> button to power the printer back on.
Aug 29, 2011 | Canon PIXMA MX310 All-In-One Printer
Canon mx310 error message 5b00
  1. On the operator panel, press and hold the button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the button again.
Service Reset:
    • This procedure will not resolve a physical hardware issue.
    • This procedure will not resolve all service errors or LCD related anomalies.
Aug 27, 2011 | Canon PIXMA MX310 All-In-One Printer
Laptop wont power up, lights and fan come on for about a half second, then shuts off and "cycles" repeatedly until power cord is unplugged
take the battery out and try,, battery maybe bad..
it could be the charger and the battery is to low.. if its not the battery or charger then its likey the motherboard
Apr 11, 2010 | HP Pavilion DV7-1020US Laptop
Photosmart C6180 All in one printer will not start although live
Strange because I have the same issue, and I've had this printer for over 3 years but the problem just started about a month ago.
I reset the printer by: 1) Unplug power to the printer 2) Hold #6 on the keyboard 3) Plug power cord back in while holding #6 Eventually (10 seconds?) the printer will shut down. Once it does, release #6 and power up the printer again.
Warning: This reset all the configuration settings.
This works for me, but there is still an issue because I have to repeat this every time I turn off/on the printer.
Mar 03, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP C6150 Printer that turns off then back on repeatedly
Please DON'T keep posting messages that say "I had the same problem..." Those are useless!
If the software resets don't work, it's possible it's an electronics problem. Here is a repair note that worked for me:
http://www.fixya.com/support/t5821942-hp_photosmart_c6180_continually_powers
Jun 27, 2009 | HP Photosmart C6180 All-In-One InkJet...
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Brief power on then shuts off
It could be a component short or crack on the power supply board. Open the back of the TV and look for signs of defect. The power supply board is the brown one on the right with huge capacitors.
Jul 12, 2008 | Panasonic PT-61HX41 61" Rear Projection...
TV turns off
It sounds like you might either have a bad power cord or you might have an over heating issue. Some times the TV will automatically shut off if it senses a fan issue or it starts to overheat. What technology is your set? DLP, LCOS, DILA...? If its under warranty I'd suggest to get someone out asap to take a look at it.
Sep 13, 2007 | Hitachi 57SWX20B 57" Rear Projection...
Dell PowerEdge 840 (becwmk1_2) Server Logo
317 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
