Home | Nikon | COOLPRINT Thermal Printer | What is involved in hoo...
Nikon COOLPRINT Thermal Printer
Problem for Nikon COOLPRINT Thermal Printer
What is involved in hooking up two printers to the same computer?
By Grant - usenet poster
Same Problem
Dec 29, 2008
-   I have an Hp C4240 and an Hp C6380. Bot are All in One's I would like to connect both printers to my Dell computer. I went to the Hp site but got no help there. What do I need to complete this task?-   mafay
Nov 14, 2007
-   I have the printer installed but it won't print.-   richard56
Best Solution
posted on Aug 08, 2005
Helpful)
pawa
Rank: Apprentice
Rating: 0%, 0 votes
It is easy to hook up two printers to one computer. One can use the traditional parallel port while the other uses the newer USB (Universal Serial Bus) connection. Probably your old printer will need to use the parallel port connection. A new printer will more than likely be USB compatible.
Remember when you are printing, one of these two printers will probably be your default printer. When using the other printer, you will need to change the choice of printers. This can usually be done right from the Print screen. After you have clicked on Print, you will be given a drop down Print Box. The selection of printers can be seen by clicking the down arrow next to the Name box. Click on your printer of choice to select it; then click OK to print.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Jun 17, 2008
Very Helpful)
techwaredist
Rank: Master
Rating: 86%, 10 votes
If your question is regading Rimage Everest, Everest II, Everest III or Everest 600 printers, the answer is you can not successfully hook up more than one Rimage printer per computer. I have tried it with Everest II and Everest III. I can get both printers to print, but the print quality and alignment is poor.
- techwwaredist
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Aug 18, 2007
Somewhat Helpful)
mrogers
Rank: Wiz
Rating: 83%, 180 votes
You can connect 2 printers up via usb.
Was this helpful?
Yes
No
Solution #4
posted on Jul 02, 2008
Not Rated)
jglassm
Rank: Apprentice
Rating: 0%, 0 votes
Use a Jet Direct EX Plus3, model J2593A, for connecting 2 HP 2000c's to same computer at same time. It can be configured how ever you wish, for example, printer 1 for photo paper, printer 2 for text, etc.Available on eBay for about $20.
I repair HP2000C printers professionally and offer refurbished 2000C's with trade in allowance for existing 2000C printer. www.glassmoyer.net/HP2000C.
Was this helpful?
Yes
No
Popular Solutions for Nikon COOLPRINT Thermal
Questions and Unsolved Problems for Nikon COOLPRINT Thermal
Do you recommend Nikon COOLPRINT Thermal Printer?
Answer
Answer
it says i have to download a high speed usb controller for my wireless usb adapter for it to be... (More)
Answer
On IMac OS 10.4 The printer gave me the choice of printing both sides. On )S 10.6 that choice has... (More)
Answer
Canon PIXMA MP 780 paper jam error message at ejection slot remains after paper jam removed. INITIAL... (More)
Answer
Canon MP 780 paper jam error message at ejection slot remains after paper jam removed. INITIAL... (More)
Answer
when i try sending fax it says low memory on display and the fax doesn't go through it stops.-- low... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Nikon COOLPRINT Thermal...:
Top Printer Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
