Question about Panasonic DVD-CV51 Multi-disc DVD Player
Rumbling drive My DVD player "rumbles" at the beginning when playing a disc...for about 5 minutes. It then quietens down for most of the movie and then makes more noise at the end. It is as if it was out of balance, or running off center. The picture is OK at all times. There is no noise when playing CDs. Thank you for any help.
    Genius:
  • 1,074 Answers
The dvd motor needs to be service or change take it to a tech to look at it.
Posted on Apr 03, 2007
2004 ford freestar rumbling noise as I drive down the road at about 45-60mph - it sounds and feels a bit like I hit a rumble strip but it is coming from the engine
Sounds like a half shaft. Reach around behind each wheel and see if there is play in the shaft that leads from the wheel to the transmission. There should be no play. Other possibility is a bearing hub. Jack up car, grab the tire at 9 and 3 o'clock. Shake wheel if there is movement not from the tie rod then it is the bearing hub.
Jan 24, 2014 | Ford Freestar Cars & Trucks
Bd370 freeze
your lacer needs to be clean or it has to be replace
Aug 25, 2009 | LG BD370 BLU RAY PLAYER
After burning the DVD once,
Several possible solutions.
1. If you are using DVD-R discs, your player probably does not support them. There are known compatibility issues with DVD-R discs. If your burner supports it, use DVD+R discs.
2. Try burning at the slowest possible speed. That can help your player pick up the disc better.
3. Did you remember to put a menu in the beginning of your movie? Even if you have the disc set to skip the menu when inserted, it still must exist for some DVD players to recognize it as a disc and play it.
May 31, 2009 | Pinnacle Systems Studio AV/DV Version 9...
Dvd pixilating and skipping about an hour and a half into disc
Use a dvd cleaner and then try the movies. Hope this helps.
Dec 21, 2008 | JVC HR-XVC33U DVD Player/VCR
DVD Stuck in player
There is nothing you can do with this problem unless you are able to repair DVD players, the loading mechanism of any DVD player is very complicated, chances are a small part has broken. Call the dealer and ask for the phone # of the repair center they use, call them for an estimate, don't go through the dealer, they will double the repair bill from the radio shop.
Oct 14, 2008 | 2003 Lincoln Aviator
Disney dvd player wont play movies (dvd) but plays music (cd) fine
Might be the type of movie - some of them are only able to play "G" ratings. Try this: click <play> 1234 <play> It will likely unlock the dvd that is in and will begin to play. You will have to do the 'code' each time, or there's an unlock program you can purchase.
Aug 07, 2008 | Disney Princess DVD Player
I bought a DVD and I played it on my laptop. It worked on the laptop but when i put it into the DVD player it wouldn't play. So I tryed playing the DVD in the PC and it also worked on there. Again I...
DVD movies have region codes, and they typically only play on a player or DVD-ROM drive sold in the country where the DVD movie was sold.
The actual region code is in one byte on the DVD (digital versatile disc). The DVD player or drive has a region code in its firmware. Personal computer DVD-ROM players often have the code in the software or MPEG-2 decoder. The two codes must match for the player or drive to play the movie. The code is also printed on the back of a DVD package, superimposed on a small image of the globe.
DVD regional locking is used to control which DVD movies play in which countries or groups of countries. Movies are often released on different dates around the world. Region 1 has its own player that will only play Region 1 discs. Likewise, Region 2 players can only play Region 2 discs and not play any of Region 1's discs. The six codes are:
  1. United States and Canada
  2. Europe and Japan
  3. Southeast Asia
  4. Latin America and Australia
  5. Russia, rest of Asia and Africa
  6. China
please check the DVD region code again and what PLAYER u are using to play on PC / LAPTOP??
where did you buy the DVD player??
Jul 23, 2008 | Televison & Video
Video on P241 DVD player
replace the bigger IC of the module
Oct 23, 2007 | Samsung DVD-P241 DVD Player
MY SAMSUNG DVD+VIDEO COMBO V4600
What you're describing is a common problem for this particular unit, a bad spindle motor. In some cases the motor can be removed by the tech and torn down for cleaning.. But in a high percentage of cases shops just replace the motor... What's happening, as your symptom appears the spindle motor is beginning to spin irratically. In turn the picture can sometimes just drop out. In others it simply folds over and is unwatchable. The spindle motor is not too expensive.. Good Luck Bill
Jun 10, 2007 | Samsung DVD-V4600 DVD Player/VCR
Panasonic DVD-CV51 Multi-disc DVD Player Logo
154 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
