Question about Hotpoint First Edition FEW12 Front Load Washer
Washing machine not spinning at the end of cycle
Hi There,
I have a hotpoint first edition washing machine that is working but is not spinning at the end, I have had a look and the dial gauge is clicking very loudly so I suspect that something may be wrong with that particular part?
Thanks
Nigel
    Problem Solver:
  • 12 Answers
If the dial is moving round as normal and the machine is filling and emptyin change the motor brushes this will cure the problem
Posted on Dec 21, 2008
Hi i have a Hotpoint wdf740 w/machine When on spin cycle it spins for about 3-4 seconds every few minuets until the end of the cycle (16 Mins) then at the end of the cycle with 1 Min to go it doesn't go...
i went through everything with my Hotpoint and turned out to be the carbon brushes in the motor that needed replaced.15 quid for the brushes and its working great again...Hope you get it sorted.
Oct 11, 2013 | Hotpoint Washing Machines
The wash cycles are working but will not spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 14, 2011 | Hotpoint First Edition FEW12 Front Load...
Hotpoint first edition automatic washing machine washes clothes .
I've got a Hotpoint First Edition WM52 that stopped spinning at the end of the wash cycle. Called the repair man and he said it was most likely just the filter blocked? Suggested I reemove the front base panel and try to locate the filter remove, clean and replace. Front panel wouldn't come off, base panel at the rear, 6 screws to remove revealing a black squeezy hose with slide grips holding them on, on removal of the hose two ten pence pieces, a one pence piece and a childs hair clip blackened with dirt sat blocking the top of the hose.
Hope this helps; repair man saved me £58+vat just with a few words and a bit of persistence from myself
Jun 17, 2009 | Hotpoint First Edition FEW10P Front Load...
Hotpoint wma22 fills with water but won't wash or spin
Suspect motor brushes need replacing.
Simple task accessed by removing the top of the washer and releasing the clips holding the brushes into the motor - clip on back of brush - to remove the brush assembly.
Replace complete brush assembly.
Feb 16, 2009 | Hotpoint First Edition WMA22 Front Load...
Hotpoint 800 wm 11 goes through cycle but won't spill or drain
hi there maybe your waste pipe might be blocked from washing machine or mqaybe there is a blockage somewhere else in your plumbing which does happen queit alot? hope this helps
Jan 11, 2009 | Hotpoint First Edition FEW12 Front Load...
WM 22 will not spin
yes.dose it drain,see it must drain before it can spinso if water is standing in it it wont spin and that would mean your pump is ither blocked or reciving power but not working.
Jan 01, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Faulty Hotpoint WMA76 washing machine
it may be 1) a connection loose at the motor 2) motor brushes are worn out 3) a pcb fault check in that order.
Feb 16, 2008 | Hotpoint First Edition WMA12 Front Load...
Hotpoint Aquarius WM 62
Hi, Does the drum turn during the wash cycle? When it comes to the spin cycle does it go through to the end without the drum turning? It sounds like it could be the motor needs new carbon brushes. Regards, Tom.
Apr 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint First Edition FEW12 Front Load Washer Logo
163 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
