Question about Kenmore Dryers
Tiny beads stuck in dryer. Can't see them. Can hear them.
How do I get into the dryer to clean out these tiny beads. They were removed from the lint vent and inside the drum. I can't see anymore of them in plain view, but I know they are there. When the dryer runs you can hear them clink clank around.
Thank you!!
  • 10 Answers
SOURCE: black soot in dryer
There are several possible causes: a)  exhaust vent is restricted forcing the lint to enter the dryer shell and overheat and/or be picked up by the blower -- you seem to have inspected this b)  check the hot gas inlet to the drum.. on some dryers, lint buildup can occur in tight spots and it will overheat and char c)  ducting is not intact or leaks allowing lint to leak into the dryer shell -- this will occur over time, and all dryers should be taken apart and cleaned out on a regular basis... also, all ducting should be inspected and sealed as needed d)  verify that the inlet vents to the dryer shell are not blocked and allow adequate air flow to the burner assembly -- natural gas normally won't smoke due to incomplete combustion, but..  likewise, verify the room has adequate ventilation particularly if the utility room or closet is very small,  e)  check the drum drive belt, as it gets old, it will release dust and minute pieces which will be picked up by the blower -- replace if needed... f)  verify that the seals on the drum are still good -- replace as needed g)  as 'washer-tech' advised, do a thorough cleaning and inspection... put it back together with all ducting tight and free flowing
Posted on Jul 27, 2008
aborcass
  • 2651 Answers
SOURCE: Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Posted on Nov 16, 2008
jsrock516
  • 5911 Answers
SOURCE: Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Posted on Sep 29, 2009
milten1
  • 1304 Answers
SOURCE: Lint is massing toward the bottom of the lint trap
please check your exhaust vent, where the dryer air comes out of the house, this particular pattern is very indicitive of a slow moving exhaust, you may need to clean the duct between the machine and exhaust as well
Posted on Oct 22, 2009
Testimonial: "Thanks, I'll do that!"
nnesmith
  • 162 Answers
SOURCE: CLEANING LINT TRAP ON MY FRIGIDAIRE DRYER
pop the hood. theres a clip on both sides at front. use small blade to depress. next remove two quarter inch hex head screw just inside on both side. the entire front panel comes off. unplug unit before beginning.
Posted on Mar 03, 2010
Hoptoint CDT40G condenser tumble dryer pump running no heat or movement
hi i have a ctd40 mine wouldent go a few years ago on the heater i had three stats on one of them there is a tiny hole i pushed a sewing needle in hole it reset the stat you can see if you look at bottom of stat it might be concave so pushing it out set it again dryer then worked pull plug first
Apr 29, 2013 | Hotpoint Dryers
Tip
How to Fix Dryer Lint Problems
<span>Instructions</span> Things You'll Need: <ul> <li> <span>Vacuum cleaner</span> </li> <li> <span>Screwdriver</span> </li> <li> <span>Electric leaf blower</span> </li></ul> <ol> <li> Remove the lint trap from the dryer and peel off the accumulated fuzz.<br /> </li> <li> Vacuum the top of the dryer, the floor nearby and underneath for lint at least once a week. When you remove the lint trap, tiny particles fly into the air and settle nearby. Behind and underneath the dryer are favorite hiding places for dryer lint.<br /> </li> <li> Disconnect the vent tube from the rear of the dryer and inspect it every month. Dryer lint accumulates more easily in flexible plastic tubes than rigid aluminum ones, because curves halt the lint's path.<br /> </li> <li> Clean the vent tube leading to the wall annually. As for the tube leading to the exterior, a trick that sometimes works is aiming an electric leaf blower down the tube. The leaf blower can expel the lint through the exhaust on the exterior. Before using the leaf blower, check that all duct work is fastened securely.<br /> </li> <li> Unscrew and remove the back panel on the dryer, if you're mechanically inclined. Particles that escaped the lint trap can accumulate inside the dryer cabinet, so vacuum this area.<br /> </li></ol>
on Jan 04, 2011 | Dryers
Bosch vision 300 gas dryer shows error E12 evry few min. Checked and cleaned lint. Checked exhaust vent. Still E12 every 10-15 min. The dryer is only 6 months old.
A friend of ours has a bosch gas dryer and she had the similar problem. She called the Bosch repairman and he came out to her house and sprayed the lint filter with Greased Lightning to clean out the tiny holes in it. He charged $100 and left. He said it would take care of the problem. Has not had any problems since. http://www.greased-lightning.com/ It is worth a try. Good luck.
Jan 17, 2011 | Bosch Dryers
We have cleaned everything--the vent clear out of the house; everything and yet the E001 buzzer keeps going off saying the lint filter is not clean--it is. We are so disappointed in this dryer! Can you...
A friend of ours has a bosch gas dryer and she had the same problem. She called the Bosch repairman and he sprayed the lint filter with Greased Lightning to clean out the tiny holes in it. He charged $100 and left. He said it would take care of the problem. Has not had any problems since. http://www.greased-lightning.com/ It is worth a try. Good luck.
Dec 01, 2010 | Bosch WTMC3510UC Gas Dryer
Mar 03, 2010 | Frigidaire FER641FS Electric Dryer
Oct 22, 2009 | Kenmore 62602 Electric Dryer
Foreign object in dryer
If it isn't a Pearl or Diamond, I'd leave it.
It fell down into the blower area which has an affinity for catching stuff (like buttons, wire, shoelaces, etc) this should cause no problem at all.
Someday I'll clean mine too ;-)
Mar 27, 2009 | Kenmore 63942 Dryer
Lint sticks to the lint cover and lint filter.
Use a degreased such as goo gone, or an aerosol electric parts cleaner/degreaser. It may look gone, but there is still scum built up in those tiny little holes.
Dec 26, 2008 | Frigidaire GLEQ642A Electric Dryer
Bosch axxis WTL lint indicator problem.
I have been struggling with this lint filter problem big-time. After reading the previous user's comment that his mesh holes had become clogged, I took a closer look at my filter and noticed that the tiny holes in the mesh were, indeed, clogged up. In fact, when I initially ran water on the filter it pooled up on the mesh like a solid plate...pretty good sign that air wasn't able to pass through the filter properly.
I used a soft toothbrush and soap to clean the filter, and when I ran water to rinse it off it the water passed right through the mesh. I popped it back in and, voila...That fixed it!!
Mar 08, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Dryers Logo
117 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
