Question about Whirlpool GS563LXSS - stainless Steel Gas Kitchen Range
My knob on my oven is frozen
My gas oven has been sitting in storage for the last few years and we took it out and connected in our rental and the knob for the bottom oven is completely frozen/stuck and wont move. the oven was only used for a month before stored so i shouldnt have to buy a new knob. is there anything i can do at home to fix
  • Expert Brian May 11, 2010
    Could it have possibly gotten moisture in it and then stored in a cold place? Have you tried pushing in on the knob while you try turning it?
  • 35 Answers
Did you try WD40(in the UK) or Q20(in South Africa)? You can buy it at hardware shops. It is a penatration flued which is a bit oily.
Posted on Dec 21, 2008
THE GAS OVEN DIES WHEN YOU LEAVE KNOB
are you turning it after it lights before releasing the knob
pushing it in starts the piezo spark but turning it lets in the gas
Jul 15, 2016 | Smeg C6GGXU 24" Freestanding Gas Range...
Whirlpool gas oven light bulb lasted 5 years but now keeps burning out?
all appliance bulbs are not created equal it needs to be specifically an oven bulb to take the heat .
Feb 14, 2016 | Whirlpool Accubake 30" Self-cleaning...
We have a briggs and stratton lawn mower that has very few hours on it but has been in storage for the last 5 years, it starts but dies
Clean the gas tank,after a year gas can turn into a gel which will clog the carb,clean the air filter,check spark plug,and readjust the carb(a small screw on the carb
Sep 03, 2012 | Briggs & Stratton Garden
Just bought a Leisure Gourmet Classic gas cooker. Connected the gas and plugged it in but none of the burners will light. The ignition is working but no gas is getting through. Any ideas folks? TIA, Andy
I had a similar problem when my new Leisure cooker was installed last December. The burners would light when I held the knobs in but when I let go the flame would go out. The engineer took off each of the burner knobs and stuck a small wad of aluminium foil between the inside of the knob and the contact on the front of the cooker - he said it's a design fault and the gap is just a bit too large for contact to be made reliably. This fixed the problem and I've had no trouble since.
Jun 22, 2010 | Ovens
The ignition coil on my oven glows fine, seems like there is no gas. Won't light.
it may glow but it s weak the gas wont flow
seems like alot of these going bad
I had 3 last week in my rentals
Nov 21, 2009 | Frigidare FGB24S5DC Gas Single Oven
My magic chef kitchen range oven won't turn on, no gas
Some of the models require you to push in the oven thermostat knob to set the pilot if it blows out. So try pushing in the knob and hold it while lighting the pilot. When the pilot lights continue to hold the knob in for about a minute. When you let go of the knob the pilot should stay lit. If it does not stay lit then try it one more time. If it continues to go out the thermocouple or aso might be bad and will need service.
Sep 11, 2009 | Magic Chef 31000 Gas Kitchen Range
Hotpoint self cleaning oven won't heat
maybe a bad connection with the heating element. Check to make sure bottom element is pluged in all the way. May need to be replaced if anything looks strange (ie. burnt spot, hole, srrange color, or maybe no external sign)
Aug 15, 2009 | General Electric Stove/Oven/Range Chrome...
Belling G755 Cooker oven wont stay lit
I'll give this a go! With a cooker like this, you depress and then turn the control knob, press the ignition button and continue to depress the control knob for a few seconds. This is because a device called a thermocouple is heated by the flame and you have to continue to depress the control knob so that sufficient gas flows to heat up the thermocouple. If the thermocouple does not get hot or stay hot then the gas valve is automatically closed - stopping the gas. The thermocouple is a 'flame failure' safety device. If the gas gets cut off then the flame goes out and the thermocouple goes cold switching off the gas valve automatically. However, you are having to try and manually keep the gas going for a good five minutes. I would think that there is either a problem with the thermocouple or the gas control valve! Tony www.birminghamelectricsltd.com
Jun 18, 2009 | Belling Solitaire G755 Gas Kitchen Range
Rangemaster 110 gas cooker - RH Oven lights but doesn't heat up
Will the flame go out if you turn the control knob to the off position?
Sometimes gas cooking control knobs have two seperate types of control in the one knob. One control turn the gas on or off, one adjusts the variable quantity of gas allowed through a gap to your flame jets. Some control knobs can get gummed up and stick a little. The can be fixed by carefully taking apart the control knob, taking note of EXACTLY how everything goes back together and cleaning any gummed up bits. Then reassemble the knob and drizzle soapy water over the control to test for leaks. A leaky gas join blows bubbles and makes noise. Let me know if this fixes the problem.
John
May 08, 2009 | Rangemaster 110 (Gas) Kitchen Range
Old Magic Chef Gas Oven won't light
sounding like thermostat isn't working. If you could ohm out the t-stat should be closed when you call for heat. If that passes the test then only thing it could be is the gas valve.
Nov 24, 2008 | Magic Chef Ovens
Whirlpool GS563LXSS - stainless Steel Gas Kitchen Range Logo
334 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Archie Ferrarini
Archie Ferrarini
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
