Question about Sony Playstation 3 (PS3) Console
Will not connect to the internet. problems with the DNS?
My roommate add his xbox 360 to our network with a powerline ethernet adapter and that is when it now longer worked.
  • James Tepfenhart
    James Tepfenhart May 11, 2010
    are you using a wireless connection or are you using your cat5 connection.
Put ps3 on and its asking me to up date i done that but then it does not let me sing on line. Also if the inter net is connected to the ps3 the game will not load up why........???
Posted on Aug 17, 2009
How do I connect my 360 to the internet
Either get the Xbox 360 wireless network adapter for about $65 http://www.amazon.com/Xbox-360-Wireless-Network-Adapter-Networks/dp/B002RS7NB2/ref=sr_1_1?s=videogames&ie=UTF8&qid=1311544766&sr=1-1 and connect it via wifi.
or just plug in a standard cat5 ethernet cable into the back.
Jul 24, 2011 | Microsoft Xbox 360 Console
I have just bought Belkin Powerline AV starter kit. I have a Belkin N1 Wireless Modem Router connected through a Carrier PoE adapter. I have tried to connect my Sony TV and PS3 through the powerline units...
Try reset the device and start a new configuration.It seems that your networwork have issues between the router and the powerlines.All need to be in the same network as per router configuration.Connect one adapter to your router and plug it into an available electrical outlet. Plug the second adpter into an available wall outlet and connect the other end to any device with an available Ethernet port such as a gaming console, set-top box, or computer.
pd: OS to use the adapters; Windows 2000, XP or Vista.
Feb 24, 2011 | Belkin Powerline F5D4050 Network Adapter
I have a wireless router hooked to my computer & my son recently got a wireless-G USB adapter so that he can play his xbox 360 online. Will this work, or will we have to put the router on the xbox...
XBOX 360 will only work properly with a 'genuine' USB WIFI adapter designed specifically for it (and at an over inflated price IMO!).
One popular way to play 'network' via the internet is to connect the XBOX 360 to your PC via Ethernet cable and have the PC connecting to the internet either via another ethernet connection or more likely via a Wifi connection which could be via your USB adapter connected to your PC and talking to your Wifi Router)
Dec 26, 2009 | Computers & Internet
How to hook your xbox360 to laptop to get on xbox live
wel if you have wireles internet you can get a wreles adapter for your xbox and conec it that way
Oct 25, 2009 | Microsoft Xbox 360 Console
XBOX LIve help - wireless network adapter
Go to your Airport Utility, then Option-Click the radio setting button to reveal a drop down menu, from there, select "b/g compatible", not "n (b/g compatible)". That takes away the benefits of an 802.11 n network, but it gets the job done with 54 Mbps.
Next up is to Option-Click the button for encryption setting and select "WPA Personal". In DHCP settings under Internet, using the 360's MAC address, reserve an IP so it stays consistent. Finally, in your NAT options, select the 360's IP address as the "Default Host" to prevent any Live functionality issues, and restart your Extreme Base Station. Once you go to the network settings on your System blade, you should see your WPA-encrypted network show up. So your 360 and Airport Extreme can work together with encryption, although you kind of neuter the Base Station in the process.
Feb 05, 2009 | Microsoft LIVE ONECARE 2.0 XP/Vista for PC
My Xbox 360 ADapter Cannot Aquire a IP Address from my Modem
can u please tell me which router it is? in most of the router there is a feature call DMZ. u need to enable the DMZ in the router & then u need to provide the static ip to Xbox 360 like 192.168.1.5 etc in the default getway u need to type the router IP address & on DNS u need to try three different settings 1st on primary DNS type the router ip address like 192.168.1.1, if it didn't work try with univeral DNS try on primary DNS as 4.2.2.2 & on secondary 4.2.2.1, if this didn't work either call ur ISP and ask for the DNS server address of ur ISP and try with that.
Jan 23, 2009 | Microsoft Wireless Network Adapter Xbox...
Xbox network adapter wont connect to a network.
go to youtube type in how to hookup wireless internet to xbox 360 a guy will show you step by step way easy..
Jan 04, 2009 | Microsoft Wireless Network Adapter Xbox...
Xbox live
2 Solutions-----
Number 1 - If your ethernet cord is going from a modem straight to your 360, then get your modem replaced by your ISP.
This will probobly be free, but if your charged, it will be a small fee.
Number 2 - If you have it going to a routerfrom a modem, then go to your 360 main screen, scroll to the far right 'System' blade, select the 4th choice 'Network Settings', and test your Xbox LIVE Connection. It will ask you to sign out. Select yes.
Results should come up (for wired router)
Network Adapter - Wired
Wireless Network - (Left Blank)
IP Address - Confirmed
DNS - Confirmed
MTU - Confirmed
ICMP - Confirmed
XBOX LIVE - Confirmed
NAT - (either moderate, opened, or strict)
If all those are the same, the problem has nothing to do with the xbox itself and you need a new router, or modem.
If results come out to be
''Network Adapter - Disconnected''
After test is run (and your 360 is connected properly to your router AND modem then you have a hardware problem. Whether the problem is in the 360 or the router/modem is easy to test.
Connect the modem directly to the 360 via ethernet. If this fixes the problem, the router is fail.
If you can get on the internet wirelessly and grounded on a computer, the 360 is busted.
Sorry it took me so long to explain that, but i hope it helps you.
Best of luck
-Erk
Jun 18, 2008 | Microsoft Xbox 360 Console
Connecting powerline ethernet adapters through orange livebox
Try to eliminate the problem into smaller parts. Try networking the two via the same power outlet via a multiple power board first in the same room. I don't have much experience with these powerline ethernet but i'm sure the configuration of these will be very similar as wireless router / access points and wireless adapter cards. However what I do know is that your power outlets need to be on the same "phase" of your electrical power system, so if you do this test I suggest (from one outlet board) you know the equipment works and your setup procedure works. then try seperating again and if it still doesnt work, check if your power outlets are wired on seperate phases (depends if your house has 3 phase wiring incoming to your home or not). Try another room or another outlet.
Oct 13, 2007 | Powerline Ethernet Network Adapter
Sony Playstation 3 (PS3) Console Logo
94 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
juanmireles1
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
