Question about KitchenAid KGRC707 Stainless Steel Gas Kitchen Range
F2:E1 None of the controls on my oven work. All I get is a code that reads F2:E1. I have no clue what this means and the mannual has no information on this. In the mean time my control pannel is completely locked up and I can't use my oven. Do you have any idea what this means?
  • Anonymous Mar 25, 2014
    i have the following readout F7:E1 what does this mean
This has happens to us regularly. Today when it happened I unplugged the oven and let the it cool hoping that would help. It didn't. I did that several times over a couple of hours to no avail. When it powers up, there are a sequence of different readings on the screen before the error code comes up. In my final effort, just before the code F2:E1 appeared, and it read PF, I quickly turned on the oven and that interrupted the sequence. It is now working. Lucky. I hope this helps someone.
Posted on Apr 03, 2009
I got the same error. Turns out it was just water that seeped in and shorted something. I just gave it some time and wiped it off and pressed cancel and it disappeared.
Posted on Apr 17, 2008
  • 641 Answers
The F2:E1 error code relates to keypad cable unplugged. 1.Check keypad connector for firm connection (keypad connects to control board). 2. Press CANCEL. If error code returns after 60 seconds, replace keypad pad. Some models incorporate keypad in to control board as one unit. In this case, replace control board (ERC) Good luck!
Posted on Sep 06, 2007
E1 F2 error code
Check the ribbon cable for connection
Mar 27, 2013 | Whirlpool RBS245PDS Electric Single Oven
Error code of E1 F2 on a kitchenaid double wall oven. What does that mean?
F2 - E1
Keypad cable unplugged
1.
board).
keypad (also called touch pad or membrane switch). Some models incorporate
(also called ERC or clock).
Feb 15, 2011 | KitchenAid KEBC207 Electric Double Oven
My kitchenaide convection oven is displaying the E1 F4 error.
KitchenAid ovens are popular for their classic design and simple user interface. When a problem occurs in the function of a KitchenAid oven, an error code will display on the clock as soon as the malfunction registers in the oven's memory. Each code corresponds to a particular type of malfunction. Most can be corrected by disconnecting the power supply for one minute and then restarting. If the code persists, either replace the indicated part or contact a service center. F0/F1
  • The F0 and F1 codes refer to electrical issues. If the code appears as only two digits, the problem is a transistor failure, so you must replace the electronic range control (ERC). If the code displays four digits, it will read F0-E0, which indicates a failure switching from analog to digital, or F1-E1, which refers to a safety flip-flop. Both problems require the replacement of the ERC.
  • F2/F3/F4
  • The F2, F3 and F4 codes refer to problems with the oven temperature sensor or the keypad. If you see the two-digit F2 code, it means your keypad has shorted and the ERC must be replaced. The four-digit F2-E0 code means that the oven temperature is too high. Test the door lock and the relay operation, and correct as necessary. A two-digit F3 code means an open temperature sensor or thermal fuse, so those parts must be replaced. A four-digit F3-E0, F3-E1, F3-E2 or F3-E3 code or a two-digit F4 code means that either the oven is registering as too hot or the temperature sensor has shorted. Either way, the oven temperature sensor must be replaced.
  • Nov 22, 2010 | Microwave Ovens
    The top display says F2:E1 and the oven won't function. How do I fix this?
    This is not exactly a solution, but it does explain what F2:E1 means. According to this page, it is a control panel malfunction. It may be caused by a shorted wire, but it may just be the control panel malfunctioning on its own.
    Nov 04, 2010 | KitchenAid Architect Series KEMC308KSS...
    Kitchen aid wall oven Model YKEBS2780B1 SHOWS
    Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
    2. Test relay contact operation
    3. High resistance in oven temperature sensor F3
    Thanks
    May 26, 2010 | Ovens
    I have a Whirlpool Oven RBS305PDS16 is having an error code E1 F2 and then it shuts off. What could be wrong?
    E1 F2 means bad connection between touch pad and control board. if connections are ok it may require parts. may get very expensive.
    Aug 20, 2009 | Whirlpool RBS305PD Electric Single Oven
    Our Whirlpool oven started beeping and the code read, E6 F2. We talked to a Whirlpool rep and he told we needed a new touchpad. We ordered a new touch pad and when we hooked it up, the code read E1 F2,...
    F2-E1 - Touch Pad (Keypad) Cable Unplugged -
    Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
    Select the 'cancel' function and wait 60 seconds.
    If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
    It appears your timer/clock has failed in this instance.
    For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
    I recommend both sites because ...
    FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
    PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
    RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
    If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
    In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
    Anything too complicated or beyond your scope should be handled by a professional.
    If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!@#@!
    Feb 06, 2009 | Whirlpool RBD305PD Electric Double Oven
    Kebc207 oven error code E1 F2
    This is information from the Tech Sheet.
    Fault Code F2 - Error Code E1: Code Explanation: Keypad keytail not connected. Recommended Repair Procedure: 1. Check keypad connector for firm connection. 2. Press CANCEL. If error code returns after 60 seconds, replace keypad. 3. Replace control.
    Jul 15, 2008 | KitchenAid KEBC207 Electric Double Oven
    Error codes on kitchen aid range
    Hi.
    F2 E1 is a keypad connection error.
    Here the complete list of Kitchenaid error codes:
    Troubleshooting KitchenAid oven, range and...
    Feb 11, 2008 | Kitchen Ranges
    F2:E1 error
    Dec 14, 2007 | KitchenAid KGRC707 Stainless Steel Gas...
    KitchenAid KGRC707 Stainless Steel Gas Kitchen Range Logo
    1,630 people viewed this question
    Top KitchenAid Kitchen Ranges Experts
    Marvin
    Marvin
    Colin Stickland
    Colin Stickland
    Jacques Valiquette
    Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
