Question about Maytag MSD2756G Side by Side Refrigerator
Ice building up in bottom of freezer of side by side MSD27 Maytag
  • 4 more comments
  • sooooooooooo Dec 20, 2008
    This appears to be likely but at the rate that ice is building up, it would overflow the pan in less than a week. We do not have a drain attachment in the back of the fridge that can go to sewer, so my guess is that the drain is plugged and that there is a leak in the ice maker. If the drain were not plugged, water would be pooling up on the floor which is not a solution.
    Thanks
    So the evaporation rate in the pan is greater than the defrost drip volume. But we get 1.5 inches of ice buildup in the bottom in 2 days. The evaporation rate in the pan can accomodate this?
    I have cleared the drain. Do not know what was causing the pluggage but I pulled the fridge out and wiggled/squeezed the rubber boot just below the drain. Flushed about 15 oz of hot water after the pluggage was cleared. I guess the next step is to put everything back together and see if it worked. I'll provide update in a few days.
    Thanks for the help.
  • dean103 Dec 21, 2008
    Were is the Defrost drain tube located on a MS2758DR ?
  • sooooooooooo Dec 31, 2008
    Yep. It worked. No more ice in the bottom.
    But now it appears that I have a bad relay on the compressor or the compressor is going bad. The fridge quit cooling so I checked the defroster to see if it was running to long. I unplugged it and it still did not cool. I checked the back and the comprossor was clicking, humming for 5 seconds, and clicking again. It would do this routine every minute or so. I tapped/wiggled (pretty hard until it sparked) and the compressor started running again and it started cooling and icing on the coils in the freezer compartment. But he compressor is very very hot. Is this normal?
  • dgm2511 Mar 10, 2009
    I have had the same problem with my Matag side-by side and repeated the thaw/cleanout procedure several times. I remove the back panel inside the freezer compartment, thaw the ice that has built up and overflows the pan at the base of the coils, pour hot water into the pan until it drains freely; put everything back together and within 2 weeks it is all iced up again. It seems that the condensation is freezing in the pan before it makes it to the drain. Any suggestions?
    Scholar:
  • 111 Answers
Your defrost drain tube is clogged up. Remove the ice and look for the top of a drain tube about 3/8-1/2" in diameter. Once the ice is gone, use a meat baster (turkey baster) full off hot water stuck in the top of the drain tube and blast hot water through to clean it out. Do this several times with about 4 cups of hot water so you don't over flow the drain pan and flood the floor
Posted on Dec 20, 2008
  • 1 more comment
  • Expert Brian Dec 20, 2008
    What happens is that the defrost water can't get from the bottom of the evaporator (cooling coils) inside the freezer to the defrost drain pan. Normally, once the water is in the drain pan, it evaporates. It doesn't have anything to do with your sewer
    Yep... with the heat from the compressor and condensor plus the condenser fan blowing air it doesn't take long to evaporate out of the pan
    Let us know... usually the blockage is scummy stuff that builds up (actually grows as it is a type of fungus) because it is in a warm and wet environment down below
Maytag side by side msd264rheb freezer works frig isn't cold. We found ice on bottom freezer side and did melt it with a hair dryer. Frig vent is letting in, now a little cool air, but not a lot.
If you found ice in the freezer then there is usually a lot more behind the back plate. If you let it defrost completely it should work good for a couple days until the ice builds up again. you more than likely have a deefrost issue. There are usually nthree components in a typical defrost circiut. The heater, defrost thermostat and a defrost timer or control. one or those is bad.
Jul 28, 2014 | Maytag Refrigerators
We have a Maytag refrig that is making an unusual sound. It is like a low pitched woodpecker sound that is repetitious every 2 seconds. It happens while the compressor is running or not running. Model...
its most likely ice build up, if this is a bottom freezer type. It could still be ice on the fan even if its a top freezer or side freezer. that's where I would look first.
Mar 12, 2011 | Maytag MBF 2256 Bottom Freezer...
There is layer of ice that has formed at the bottom of the freezer side. Due to this there is a leak of water that appears every two or three days. I cleaned the layer of ice once and after 2 or 3 weeks...
Sounds like the drainage hole is blocked with ice, i normally take the back cover off the freezer and at the bottom you will see a build up of ice at the bottom, turn freezer off and carefully remove as much ice as you can, then pour some boiling water over the excess ice and in the middle you will see a drain hole make sure water then freely flows down drain hole. Other than that you could try switching your freezer off for 24 hours to clear ice.
Nov 02, 2010 | Maytag MSB2654HE Side by Side Refrigerator
Maytag refrigerator side stopped working; freezer is fine. WHY?
sounds like a defrost problem maytag has problems with the defrost thermostat use a hair dryer to melt the ice on the coils and see if the defrost thermostat is swelled up on the edge
Jun 30, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
ICE BUILD UP ON THE BOTTOM OF MY FREEZER BELOW THE LAST TRAY
clear ice and with hot water pour into the drain hole till open and drains ,, take back panel of freezer out and wrap a piece of thick cooper wire around the heater and drop into the drain hold about 1in and it will keep drain open / thanks
Jan 14, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Ice build up on bottom of freezer
remove back panel inside freezer. you will see drain tray at bottom with a drain hole in the middle - this is blocked usually with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
Sep 25, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Maytag side by side freezer ice build up
I HAVE A MSD2454GRW, 23.5 CU, MAYTAG AND ICE BUILDS UP ON THE FLOOR OF THE FREEZER TO A POINT WHERE IT RUNS ON THE FLOOR. CAN CLEAN IT OUT AND 12-15 HOURS LATER, ITS BACK.
Jul 20, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag side by side water/ice dispencer
Sorry, mine does it also..bad engineering.
Apr 22, 2008 | Maytag MZD2766GES Side by Side...
Water leakage in and below freezer on Maytag MFD2560HES
you have a clogged defrost drain, or your ice maker (if so equipped is leaking. clogged drain can be remedied removeig drawer , andmelting ice build up behind rear panel of refrig, you see an aluminum trough that the water drips down,using a hair dryer melt all thatice out of the way to clear the drain tube(i use a steam machine i purchased from infomercial works extremly well
Feb 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Icing
I have same problem. I found this posted on web. Will try it tonight. http://davesrepair.com/DIYhelp/DIYrefrigdrainfix.htm
Oct 24, 2007 | Maytag MSD2756G Side by Side Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
501 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
