Question about Yamaha HTR-5740 Receiver
Yamaha HTR - 5740
Receiver works but can't figure out how to set up surround sound via receiver. It was working but Direct tv tech came out last week to install HDTV receiver and now lost surround sound and can't remember how to set up.
Can you provide proper steps? Thanks!
Sincerely,
Mark
  • 120 Answers
SOURCE: my yamaha htr 6050
Make sure you speakers are turned on on the receiver,
Posted on Jan 24, 2008
SOURCE: No component video output
Hope this helps
The Yamaha HTR-6030 offers two types of video monitor output: Component and Composite. You may need to connect both types to your television as the HTR-6030 does not have composite to component video conversion. In other words, to view your VCR on your TV, you need to use the composite video monitor connection. However, for a DVD player or other source that has component video connections, use the component video monitor output to your TV. If your TV has both types, you simply switch between the two with your TV remote to access the proper video monitor output signal from the HTR-6030.
Posted on Feb 28, 2008
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
  • 4 Answers
SOURCE: Programming manufacturing code
I tried to program the remote supplied with my Time Warner HD-DVR, only to discover that ... using the proper Yamaha code only allows you to turn the HTR-5740 off ... not ON!
I had to get the programmable version of the remote, and use its "learn" function to assign the "power on" function to an unused keystroke combination on the remote!
Posted on Dec 22, 2008
marklights54
  • 12 Answers
SOURCE: I need the remote code for the Yamaha HTR-5740
0176,1176
http://www.comcast.com/remotes/universal.html
Posted on Mar 01, 2009
Surround problem with Yamaha HTR-5930 5.1 Channels Receiver
The signal that comes from most tv's via the optical output is a stereo signal only. That is what your receiver is reading. You would have to manually set your receiver to decode the signal into surround,.
Apr 18, 2013 | Yamaha HTR-5930 Receiver
Yamaha HTR-6230 receiver set up w/HDMI no sound
BD and DVR hooked up to the receiver and from the receiver to the TV right? If yes: Your receiver set to pass sound trough to the TV, if you want sound from the home theater setting has to be changed.
Nov 28, 2009 | Yamaha RX-V463 Receiver
HTR-5740 Receiver Subwoofer Problem
as long as there is a speaker out from the receiver you should be ok just make sure polarity for spkr is right --remember you workng with AC current bad wire will cause fire==
Jun 26, 2009 | Yamaha HTR-5740 Receiver
No sound
I had the same problem on 3/21/09...I found it was the PS3 settings. I had to go into the visual settings (not sound) and change the linear sound to optic digital...but I also had to purchase a digital optical cable...plug everything into your tv instead of the receiver and then hook up the digital optical cable from your tv to the receiver. A it will work and b it is a better sound quality than that of the HDMI cable.
Mar 14, 2009 | Yamaha HTR-6130 Receiver
I need the remote code for the Yamaha HTR-5740 Surround Sound System. It is for the 3 in 1 Comcast Remote.
follow the comcast instructions, then enter 30176 when you are to enter the 5 digit code.
Feb 28, 2009 | Yamaha HTR-5740 Receiver
I'm trying to figure out the same thing, so if you ever figure it please let me know, I will do the same. thanks.
Jul 21, 2008 | Yamaha HTR-5740 Receiver
6050 yamaha receiver issues
the problem is how you wired it, guess you plugged the ps3 directly to the tv. to hear the ps3 through surround sound, you would have to wire it through the reciever like everything else...
Jan 28, 2008 | Yamaha HTR-6030 Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
Yamaha HTR-5740 Receiver Logo
70 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
