Question about Maytag Atlantis MAV6000 Top Load Washer
I have a Maytag washing machine and my wife stopped the wash cycle when she thought it didn't sound normal to her, on of the kids overloaded the machine so we pulled the clothes out drained the water and now it will not start. Is there a fuse for this machine? It's model # MAV6000AWW and it needs help! Thanks, T
  • 943 Answers
Hi thanks for the question. I would look at the lid switch. The over loan could have broken the switch. I would look at the switch. Here Is the break down of your washer. Hope It helps you. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=46605
Posted on Dec 23, 2008
The spin cycle om my Maytag washing machine isn't working, what can I do?
unless you know how to replace the transmission on it I would look for a new one
Mar 27, 2015 | Maytag Neptune MAH5500B Front Load Washer
Maytag centennial washer not working properly in Normal cycle. After it shuts off there is still water in the bottom of the tub. I can move the dial to another setting such as Casual cycle or Heavy Duty...
We have the same problem. The Normal cycle still works, but after the final spin cycle, water is again added (1 gal est.) and the machine stops. Problem occurred after washing an old 25 x 30 inch rug which partially disentegrated when washed. We were seeing particles of the rug in subsequent wash cycles during drain into laundry tub. Don't know if something is plugged in the washer or if it is something else. In another load after the rug wash, the top of the washer was lifted during the wash cycle. The water problem occurred immediately after lifting the lid as the wash load went through remaining cycles. Maybe this affected the timer? Maytag customer service suggested unplugging power cord to re-set timer. This didn't make any difference. We need a technician to tell us if this is a timer problem or something else?
Oct 03, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag neptune MAH5500BWW front loader didn't drain after a wash cycle. first time wife put it on spin for a few minutes and it drained, no problem. A week later that didn't work, code...
Yes you need a new control board. The fact that the motor and impeller was damaged and loosened. You should try taking your Washer in for maintenance check or call the repair man.
Jun 21, 2011 | Maytag Neptune MAH5500B Front Load Washer
We have a Maytag Performa PAV2200 Washing machine...lately, during the spin cycle it makes a loud whinning or scraping type of noise during the spin cycle and sometimes during the wash cycle.... we took...
Might be the tub bearing going out. Is she leaking any?
Here is a visual inspect and repair of the tub seal:themobilian_1841.jpgthemobilian_1842.jpgthemobilian_1843.jpgthemobilian_1844.jpg
I used a pipe wrench to unscrew this top portion of the seal (lefty loosey)themobilian_1845.jpgthemobilian_1846.jpgthemobilian_1847.jpgthemobilian_1848.jpgthemobilian_1849.jpgthemobilian_1850.jpgthemobilian_1851.jpgthemobilian_1852.jpg
Those 6 springs are pretty tough to get back on there without the special tool
other than that it all goes back pretty easy.
Service manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 12, 2011 | Washing Machines
I have a Maytag Quiet Series 200. In the beginning of the cycle, it makes a weird 'whirrrring' noise that goes away right after the first wash cycle. It's getting water. It's very noticable and I worry...
I have a quiet series 300 and it does that, too. I think it just balances the load before washing and is normal. I found this in the manual:
Normal Sounds
Your new washer may make sounds your old one didn
Sep 05, 2010 | Washing Machines
Lost power to washing machine
When you opened the lid to add clothes, your Maytag sensed a door lock fault and went into protective shutdown.
Jan 04, 2018 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Performa washer will not drain?
i'd look at replacing the motor that sounds like the prob
Jun 11, 2009 | Maytag Performa PAV2200
My washer makes a loud noise during a normal wash cycle.
If it is a belt driven machine, then there's the smell. Lean it back a little, enough to fit a paint can under 1 corner and you can feel the belt right on the bottom. Feel for cracks, flat spots or a lot of black dust. Remove belt and make sure everything that it goes around spins free.
Mar 17, 2009 | Maytag PAV2300 Top Load Washer
Maytag Washing Machine Stops after wash cycle...
sounds as if you have abad contact in the timer
advance the timer to a different spin cycle and see if it spins
then bo back to where it stops
if it will spin in the other spin cycles but not where it stops the the timer will need to be changed
Apr 21, 2008 | Maytag Dependable Clean Top Load Washer,...
Maytag stops at any cycle after warm
sounds like a motor problem. the motor might have reached then end of its life and is overheating causing the thermal overload protector to shut down the motor.
Sep 09, 2007 | Washing Machines
Maytag Atlantis MAV6000 Top Load Washer Logo
164 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
