Question about Bulldog Remote Starter & T-Harness Kit for 95-03 Chevy Blazer/Chevy S-10 Pi
Blows the 15 amp fuse
2005 dodge pickup,installed starter in october worked fine for 1 month now it blows fuse connected to vehicles red power wire.replaced fuse worked for 4 days now fuse blew again.also the hood safety switch broke i ordered it 3 times from your company stil have not received. frank.
  • l4cub43 Dec 20, 2008
    i should not have to go buy a switch for a product you sell.you should be supporting your product.the fifteen amp fuse was installed at the factory. i hope is was just a over sight.
    Problem Solver:
  • 8 Answers
If you live in a town that has a remote starter installation shop you can just go there and buy a new pinswitch for around 6 dollars i recomend changing the location of it under the hood
and if your red power wire has only 15 amps of protection you should switch it for a 30 amp fuse thats the minimum that is going to be pulled when the unit cranks the starter wire so the 15 will deffinately melt or blow and check to insure the ground is perfectly connected (in the world of current vs. resistance the weakest point will give in first...
Posted on Dec 20, 2008
  • Derek Nott
    Derek Nott Dec 20, 2008
    I dont work for bulldog electronics
    personally I turn them away from my shop as they are the cheapest and most not supported product in the industry
    they have no quality control systems at factory thats why they come in plastic blister packs
    ive seen them work fine in a car for a year then as fast as you can blink the whole car is in flames in a garage
    I did not say that i sold the item your talking about
    I dont understand why you put blame on me for you not doing your research and going for the cheap way out this is simply a case of "you get what you pay for" iam just a sole person trying to help people solve their problems
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
1998 dodge ram 1500 dash lights wont work
Walker Muffler - Aluminized Steel Direct OE Replacement 1998-2001 Dodge Ram 1500.-------------------------------------------------------------------------------------
SLIM HID XENON light
Jan 10, 2013 | 1998 Dodge Ram 1500 4WD
05 Neon 30 amp starter circuit
The ignition switch . Free wiring diagrams here http://www.bbbind.com/.htmlfree_tsb Enter vehicle info. year , make , model an engine size . Under system click on electrical distribution ,then under subsystem click on power distribution .
Jul 18, 2017 | 2005 Dodge Neon
Schematic to driver side fuse box
Cavity Fuse Description
1) 15 Amp Blue Horn Relay, Power Sunroof
Relay, Power Window Relay
2) 10 Amp Red Rear Fog Lights (Export Only)
3) 20 Amp Yellow Cigar Lighter
4) 10 Amp Red Headlight Low Beam Right
5) 10 Amp Red Headlight Low Beam Left
6) 20 Amp Yellow Body Control Module/Power Door Locks
7 )10 Amp Red Left Park Light/Left Tail Lamp/License Plate Lamp
8) Spare
9) 10 Amp Red Right Park Light/RightTail Lamp/License Plate Lamp/Cluster
10) Spare Cavity Fuse Description
11) 15 Amp Blue Flasher
12) 15 Amp Blue Stop Lights
13) 10 Amp Red Body Control Module/CMTC/Cluster/Pass. Airbag On,Off Indicator, Auto Daylight
Mirror/Light Bar Switch (Renegade Only)
14) 10 Amp Red PDC Fuel Pump/AC Clutch,
Starter Relay/Engine
Controller/Transmission
Controller (Diesel Only)
15) Spare
16) 20 Amp Yellow Power Outlet (Rear)
17) 15 Amp Blue Rear Wiper
18) 20 Amp Yellow Radio Choke & Relay
19 20 Amp Yellow
Frt Fog Lights/Trailer Tow
Stop and Turn Lights
20 Spare
21 10 Amp Red Radio
22 20 Amp Yellow
Power Sunroof Relay/
Antenna Module (Export
Only)
23 Spare
24 10 Amp Red PDC Blower Motor
25 10 Amp Red Heated Seat Switches/HVAC
Control Head/Trailer Tow
Battery Charge
26 10 Amp Red Headlight High Beam Right
27 10 Amp Red Headlight High Beam Left
28 Spare
29 10 Amp Red Heated Mirrors/Rear Window
Defroster Indicator
30 15 Amp Blue Heated Seat Module
31 Spare
32 10 Amp Red Wiper Switch/Front and
Rear Wipers
33 10 Amp Red SKIM Module/Data Link
Connector
34 15 Amp Blue Body Control Module/
Cluster/Interior Lights,
Hands Free Module/Radio/
CMTC/ITM Module & Siren
(Export Only)
35 Spare
36 10 Amp Red Airbag Control Module/
Occupation Classification
Module (Right Front Seat)
37 10 Amp Red Airbag Control Module
38 10 Amp Red ABS Controller/Shifter Assembly
39 10 Amp Red Hazard Flasher (Turn
Signals)/Backup Lamp
Switch (Manual Transmission
Only)/Transmission Range
Switch (Automatic Transmis
May 23, 2011 | 2005 Jeep Liberty
I have a 2004 dodge stratus that has power to lights but does not turn over when i try to crank even after jumping it off.
Hi.
Check ignition switch fuse. This is a 20 Amps. see that it has not blown. In 2004 Fuse should be nr 8 in the power box under the hood (newer models #24).
Once you are sure that battery, fuse and wires are OK, check starter and ignition switch. Check if there is 12V to starter while cranking. If there is power and the starter motor does not turn, then the motor is gone.
If there is no power to starter motor when you crank, then the ignition switch located inside the steering column may need replacement. Before repairing, try reading error codes with a code scanner.
Apr 15, 2011 | 2004 Dodge Stratus
Dodge charger fuse box , where the fog lights relay goes ?Thanks
Cavity/ Fuse /Circuits
1/ 20 Amp Yellow/ Left High Beam Headlight
2/ 20 Amp Yellow/ Right High Beam Headlight
3/ 15 Amp Dk. Blue/ Adjustable Pedal
4/ 20 Amp Yellow/ Horn
5/ 25 Amp Clear/ Headlamp Washer - If Equipped
6/ 15 Amp Dk. Blue/ Front Control Module (FCM)
7/ 20 Amp Yellow/ Fog Lamp
8/ 15 Amp Dk. Blue/ Park Lamp
9/ 15 Amp Dk. Blue/ Non ABS Brakes
10/ 5 Amp Orange/ Starter
11/ 20 Amp Yellow/ Auto Shutdown/Powertrain Control Module (PCM)
12/ - -
13/ - -
14/ 25 Amp Clear/ Powertrain Control Module
15/ 20 Amp Yellow/ Injectors, Ignition Coils
16/ 15 Amp Dk. Blue/ Powertrain Control Module
17/ 30 Amp Pink/ Antilock Brake System (ABS) Valves
18/ 30 Amp Pink/ Windshield Wiper/Washer
19/ 50 Amp Red/ Radiator Fan
20/ 20 Amp Lt. Blue/ Starter
21/ 50 Amp Red/ ABS Pump Motor
22/ 40 Amp Green/ Radiator Fan High/Low
23/ 50 Amp Red/ High Intensity Lighting
24/ - -
25/ 30 Amp Pink/ Lighting Left High Beam/Right Low Beam
26/ 20 Amp Lt. Blue/ Transmission
27/ 30 Amp Pink/ Lighting Left Low Beam/Right High Beam
if this helps please rate 4 thumbs up.
Jan 21, 2011 | 2007 Dodge Charger SRT8 Sedan
How to disarm or reset an alarm system for a 1996 Jeep Cherokee?
Hope this helps:- Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm.
Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206): 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
Row 1: 1-6 (left to right) Row 2: 7-12 Row 3: 13-18 Row 4: 19-22
1996 Jeep Grand Cherokee Fuse Panel (Passenger Side kick panel) Reply
CAVITY FUSE DESCRIPTION 1 -10 amp (RED) Radio 2 -15 amp (Lt Blue) Cigarette Lighter 3 -10 amp (RED) Rear Washer Switch, Body Controller 4 -10 amp (RED) Airbag 5 -10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II 6 -15 amp (Lt Blue) Vehicle Information Center/Graphic Display Module Park & Side Lamps, Overhead Console Lighted Visor, Automatic Dimming Mirror 7 -20 amp (Yellow) Body Amp, Cluster, Body Controller 8 -20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo Lamp, Trailer Tow 9 -15 amp (Lt Blue) Brake Switch 10- 10 amp (RED) Rear Window Defroster 11 -10 amp (RED) ABS Module 12 -10 amp (RED) Heater-Ventilation-A/C Control & Recirculation Motor 13 -15 amp (Lt Blue) Hazard Switch, Turn Signal Switch 14 -15 amp (Lt Blue) Spare 15 -15 amp (Lt Blue) Spare 16 -10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp, Halo Lamp Cargo Lamp, Underhood Lamp, Dome/Read Lamp Right & Left Visor, Automatic Dimming Mirror 17 -15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display Module, Park & Side Lamps, Headlamp Switch, Body Controller 18 -20 amp (Yellow) Spare 19 -15 amp (Lt Blue) Passing Light 20 -15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle Information Center 21 -15 amp (Lt Blue) Power Outlet 22 -10 amp (Blue) Airbag Module -------------------------------------------------------------------------------------
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm. Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehicles
Dec 18, 2010 | 1996 Jeep Grand Cherokee
I have a 1996 Jeep Cherokee and the heater vents dont work.I have tried to find a picture of the fuse panel i can read but i cant..When you swith it to vents it only comes out of the defrost.Where can i...
Hope this helps:
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehiclesairconman.jpg
Dec 16, 2010 | 1996 Jeep Grand Cherokee
I need a schematic for my 1998 Dodge pickup diesel
you have a direct short in the main starting line,ie the battery to the starter or the starter wires take a very good look and you will find/see the problem it will be a main red wire touching ground/earth.adrian,,
Jul 30, 2010 | 1998 Dodge Ram 2500 2WD
To install a cd /radio
any short or 'spark' will most likely blow the fuse.fuse panel is located below the dash on drivers side.look for a 10 Amp [red] fuse.complete wiring procedures,then replace fuse.
Oct 19, 2009 | 2005 Dodge Caravan
2001 DODGE STRATUS BLOWING 15 AMP START FUSE
the starter is the most often cause of the failure the solonoid gets shorted and blows the fuse replacing the starter should fix it, i have also seen a couple of wires for the starter rub against the heat shield and blow the fuse
Sep 25, 2009 | 2001 Dodge Stratus
Bulldog Remote Starter & T-Harness Kit for 95-03 Chevy Blazer/Chevy S-10 Pi Logo
195 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
John
John
baire
john h
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
