I have a VSZ-D509S Pioneer digital processor receiver.The receiver started going into the poweroff mode and shutting off after playing it for a while. In order to troubleshoot i disconected all components an speakers, unpluged it and replugged it backi. I turned the receiver back on with nothing attached and the offpower mode came on again and system slill shut off. Can you help me
    President:
  • 624 Answers
It most likely has a bad channel in the amplifier circuit. This is a very difficult job to repair. You would need all the right tools like soldering equipment, multimeter, hand tools, ect. You also would need some electronics knowledge, even if you are getting help troubleshooting it. It must be repaired right the first time or you risk blowing up all the parts you put in when you try to turn it back on again if you do not have a variac to use to power it on.
If you want some help troubleshooting I can give you some help, but you would be better served to take it to a service center and let a professional do it.
Posted on Feb 06, 2009
How to 'fix' a Pioneer VSX-D509S that stopped working when we lost power to our house. Suggestions?
Try holding down the advanced surround button and power button. If the unit locked itself into protect, this should clear it.
Jan 03, 2013 | Pioneer VSX-D509S Receiver
We received the vsx d509s from our son, he hooked it up, and we were enjoying our surround sound in connection with our tv. However, when I hooked up the cd player, all the speakers worked fine, but now...
It is possible that you have switched it from a surround mode to stereo mode. Instructions on how to select a sound mode begin on page 36 of the manual, which can be viewed at the link below.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000033275.pdf
Jun 27, 2011 | Pioneer VSX-D509S Receiver
Digital signal only works on tv output not on cd,dvd,or any other setting
TV output? Do you mean the audio coming in from the TV?
Have you looked at the manual and assigned each digital input to the appropriate device? What other devices are involved and have you tried moving it/them among the working/non working digital inputs?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-D509S-Receivers-manual/id/385ci970/t/2/
Apr 23, 2011 | Pioneer VSX-D509S Receiver
I have receiver VSX-D509S. Have had it for
Check for a bad ground on the input circuit board. you will need to re-solder them. Remove top cover and rear panel (many screws on rear panel) The input board can easily be accessed and resoldered. you should also check for a bad ground on the speaker jacks. If it is not repaired, sooner or later you will probably need an output IC. good luck.
Oct 16, 2009 | Pioneer VSX-D509S Receiver
Pioneer VSX-D509S keeps shutting off
Aside from any intrinsic problem with your receiver, the usual suspects are;
1) Poor receiver ventilation. 2) Very high levels of bass. 3) Shorts in the speaker wiring. 4) A rubbing loudspeaker voice coil.
Sep 20, 2009 | Pioneer VSX-D509S Receiver
Overloads all the time under 40db.
Hi Glen. The thing with these new units is that they are so fussy when it comes to frequency range on the speakers. The frequency has to be within the range that the amplifier specifies, or you'll have problems. I suggest that you check your manual to see what the required frequency shuold be and take it from there. I have one myself and love Pioneer
Aug 02, 2009 | Pioneer VSX-D509S Receiver
I turn on my Pioneer VSX-D509S 5.1 surround amp comes on for a few seconds and then it says "powering off"... and shuts off
Disconnect all your speaker wires from the back of the receiver and turn it back on. If it shuts off, you need to have it serviced. If not post a comment and I can walk you thru troubleshooting. Hope this helps
Jun 24, 2009 | Pioneer VSX-D509S Receiver
Vsx-d506s problem
It may be a PROTECT MODE. Check is your other equipment properly connected to receiver.
Oct 09, 2007 | Pioneer VSX-D506S Receiver
"POWEROFF" display comes up randomly
there may be broken soldering points in the receiver take it to a workshop or open it your self and check it on the power source
Jul 02, 2007 | Pioneer VSX-D509S Receiver
173 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
