Question about GE JVM1870 Microwave Oven
GE JVM1870 Runs, but won't heat up
Some advice that I have received has been that the magnetron, high voltage capacitor, or diode could be bad. Another person in this forum suggested that I check the fuses. After disconnecting the power I have partially disassembled the MWO (microwave oven). I do see two fuses - "Main Fuse" and "HVT Fuse" (High Voltage Transformer?). According to the factory schematics/parts list both fuses are 20A 65TL. Which one do you think could be causing my no heating issue? Should I replace them in any certain sequence? Any other concerns that I should be aware of prior to trying to fix the problem myself? At the end of the day... I can't/don't to afford to 1) buy a new MWO as some have suggested or 2) pay extremely high repair charges for a factory repairman regarding a hopefully simple problem that I could fix. Any help that you could provide would be greatly appreciated as my wife is getting upset that she has not been able to use her MWO for a couple of days now.
  • 1 more comment
  • Anonymous Nov 03, 2007
    Everything on my MWO works except it doesn't heat up.
  • JayMan152 Nov 12, 2007
    Is it worth repairing or would it be better to buy a new microwave?
  • Anonymous Jun 30, 2008
    I have a samsung mivrowave oven. I runs as normal with the normal humming sound but it wont heat up the foods.Is this a problem I could fiux myself? Do magnatrons usually give problems as I also have a GE unit which does not work at all.
  • GE Master
  • 9,149 Answers
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Posted on Apr 10, 2007
    Genius:
  • 1,074 Answers
My brother check the magnetron and the high voltage cap they are bad.or you got to take your microwave to a tech replace both component.good luck.
Posted on Apr 03, 2007
GE profile mirowave JVM1350WW002 - won't heat
There three area's of concern, magnetron, "heats food" the high voltage diode, "sometimes crack" the high voltage capacitor, "usually shorts"
Mar 24, 2012 | GE Profile Spacemaker Over-the-Range...
Jvm1410bc001 won't heat
It is one of three things, open filament in the magnetron, cracked high voltage diode, and a shorted high voltage capacitor.
Mar 21, 2012 | GE Microwave Ovens
GE microwave just stopped working a yesterday. It still runs, fan motor and light still work, but it doesn't heat anything up.
The magnetron is the likely cause, but there are two other parts that can be a factor, the high voltage capacitor and diode, they work together with the magnetron to generate the high voltage and heat the food. If a professional is brought in to assess with parts and labor, it will be high.
Feb 10, 2011 | GE Microwave Ovens
It runs but does not heat.
There are few parts that will cause this type of problem, the first is a high voltage power diode "open or short" the second is the high voltage capacitor becomes defective, or the magnetron that heats the food is a common problem, and the least less likely is the high voltage transformer that drives the magnetron.
Jan 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE built-in Monogram Microwave Runs, but no heat
There are a few causes that would describe the problem you having, the first is a high voltage power diode that fails, the second is the high voltage capacitor that can open or short, the magnetron is the more likely suspect "heats the food" and finally the least likely will be the high voltage transformer that energizes the magnetron. I suggest a appliance repairman or tv technician for the job.
Jan 23, 2011 | Microwave Ovens
GE Spacemaker diode connection
A good high voltage diode will read open in both directions on a standard meter. See: http://www.gallawa.com/microtech/diode.html
If the diode is NOT shorted or burned looking, it's probably fine.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
It has a wiring diagram and a schematic which shows you how the components are connected.
On one terminal of the high capacitor, there is only one connection - to the high voltage output of the high voltage transformer.
The other terminal of the capacitor will be connected to the high voltage diode and the magnetron, as well as one of the heater (cathode) windings of the high voltage transformer.
Here is info on testing the mag:
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though mag is bad!)
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Dec 05, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave runs but won't heat
hello there
here are some things to look for
If the power is on, but it does not work check to make sure the door closes and aligns properly. Microwave door switches have metal terminals on the end that make contact with the door hook or latch. This completes the circuit which allows the microwave oven to run and without this contact the microwave will not operate. A simple misalignment might be breaking the circuit causing the microwave not to operate. If you suspect that the thermal fuse has blown, call a professional appliance repair person. Even an unplugged microwave oven can kill or seriously injure someone. This is because there is a high energy capacitor inside the microwave oven case. If it is not discharged properly, you could be electrocuted.
If your microwave buzzes or hums but does not produce any heat, it could be a faulty defective diode, triode, high-voltage capacitor, or even a faulty magnetron. However, this problem usually means a bad means a bad magnetron, followed by a bad diode. Call a professional appliance repair person for assistance.
Nov 14, 2009 | GE Hotpoint RVM1535 Microwave Oven
GE JVM1631BB not heating
If the measurements you got on the high voltage transformer match what is specified on the mini-manual, then the transformer is probably okay. If there is a serious difference, that may mean the high voltage is too high, which can destroy the high voltage rectifier diode. Otherwise, you have a bad magnetron, regardless of how well it ohms out. Even though the magnetron's continuity readings are good, the magnetron can still be bad. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Jun 02, 2009 | GE JVM1631 Microwave Oven
Microwave oven problem
If your microwave is doing everything, but heating it could be any one of the following components: Magnetron HV Capacitor HV Diode HV Transformer This network works in conjunction to produce the high voltage required to heat. Taking live voltage measurements is dangerous and not recommended. You can, however, do resistance checks on the components with the unit unplugged to see if you can isolate the problem any further. The HV Diode should be mounted somewhere on or near the HV capacitor and will read an open in one direction and a relative short in the other. If you put a meter on the capacitor you should see a varying resistance as the capacitor charges and discharges. There should should be a wiring diagram inside your control panel with the resistance readings for the primary and secondary windings of the transformer and the filament of the magnetron. In a nut shell, you probably have either a bad magnetron or a bad diode. Those are the two components that fail more frequently. Of course, double check all your interconnecting wires too. Good luck and let me know if this helps.
Jun 22, 2007 | GE JVM1660 Microwave Oven
Our GE jvm1870 is now over 4 yrs old, and had been working fine-- until recently when using, didn't heat anymore & also started making a crazy sound.
Am no electrician, so I called GE to help. Needed a new magnetron & some diode. Part was under a 10 yr warranty- the total cost for service call + labor was under $200. Not great, but beats buying a new microwave ($400-700) and having to install it.
Apr 01, 2007 | GE JVM1870 Microwave Oven
GE JVM1870 Microwave Oven Logo
584 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
