Question about Whirlpool 19.8 cu. ft. Side-by-Side Refrigerator ED20TQXF
WATER RUNNING OUT FROM UNDER REFRIGERATOR
I HAVE A HOTPOINT 19.8 cubic foot Model CSX20EA. Water runs out from under the left front, enough to soak a dishrag in 7 days. I think the drain line is plugged, but can't find it or a drip pan. I have no icemaker in freezer. Can you tell me where the drip pan and drain line are located? i I hate to take the back off until I know what could be causing the leak. (Fridge and freezer are working fine. It's the leak that bothers me.)
    Scholar:
  • 111 Answers
If the floor of the freezer is full of ice, your defrost water drain tube is clogged. Remove the ice in the freezer bottom, find the top of the drain tube inside the freezer near the top of the ramped up area, about the size of your index finger and blast hot water through it with a turkey baster. About 4 cups of good hot water but not boiling
Posted on Dec 20, 2008
How many cubic feet is the 106.5942801 model?
1 Open the refrigerator door. Measure the depth of the refrigerator
from the front edge of the refrigerator opening to the back wall. Make sure that you measure in feet and not in inches. Note the depth measurement on a piece of paper.
2 Measure the height and the width of your refrigerator's opening. Note the two additional measurements on your paper. Multiply the depth, height and width measurements to obtain the refrigerator's cubic foot measurement.
3 Take the same measurements from the interior of the freezer. Multiply those measurements together to get the cubic foot size of your freezer.
4 Add the cubic foot measurement of the refrigerator interior to the cubic foot measurement of the freezer interior. This gives you the total cubic foot measurement for the refrigerator.
Things You Will Need
  • Tape measure
  • Note paper
APPLIANCE 911
May 19, 2016 | Kenmore Refrigerators
What is the cubic foot size of this fridge...
Greg,
If you put in the make and model of your refrigerator, it did not come through with your question. As far as sizing goes, most manufacturers will usually put part of the cubic foot size in the model number. For example, I just installed a refrigerator that at the store they labeled it as a 21.2 cubic foot refrigerator and the model # starts out as GTE21GS... That .2 cubic foot does not show up in the model but the 21 does, so that should give you a basic starting point. Hope this helps!
Aug 14, 2015 | Refrigerators
Cubic feet in maytag model number rtt1900
19 cubic foot is your answer.
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Sep 01, 2014 | Refrigerators
My whirlpool fridge is not cold enough, there is water leaking from the top. I leave a plastic bowl under to catch the water. This has to bee emptied every several days. Here is the model ET18PKXGW01. I...
We had the same problem, but the bottom of the fridge was freezing over. Took apart and blew air through the line from under fridge. Goop came out. Put back together and ran perfect!
Jul 31, 2011 | Whirlpool 17.6 Cu. Ft. Top-Mount...
About every 4-5 days I notice water on the floor coming from under the front grille.I assume it has something to do with the defrost cycle and maybe a drain tube is clogged? I have a 25 cubic foot side by...
Yes its possible clogged drain tube will cause that, de-clogged it by using soft stick or solid wire right enough to penetrate inside the drain tube. Then clean it with water, before doing that transfer the inside of refrigerator (food, beverages, fruits,etc) get it back until you finish the job.
Jun 12, 2011 | Kenmore 53642 / 53644 Side by Side...
Water on floor under freezer side csx20ea model hotpoint sems like twice a day a puddle the size of a cereal bowl is under front left hand side of my side by side fridg i have a pergo hard wood floor im...
If you have an ice maker, check for a leak in the water line. If no ice maker, there could be a leak in the pan for the defrost water, or the drain hose is out of position. Also, check to see if the water is actually leaking out from the freezer door. That would indicate a clogged drain. The bottom inside the freezer may have water, or ice on it. If so, suspect the clogged drain.
Jan 06, 2010 | Refrigerators
Overflow of condensation water
If you have a water filter the water will leak past the filter to the pan if it's clogged up and needs changing.
The defrost water drains to the pan, so if you are having a lot of frost it could fill it up. Excess frost can be caused by leaky door gaskets and frequent door openings.
The condenser fan near the pan should be running when the compressor runs to help evaporate the water in the pan.
Sep 09, 2009 | Haier HTE21WAAWW Top Freezer Refrigerator
Hotpoint side by side csx20ea
Replace the defrost timer. Good luck!
barneyluc
Oct 06, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Cubic feet?
Most refrigerator models with two digits, the rest letters, the digits stand for the cubic foot capacity of the refrigerator. In you case, 23 cubic foot model.
Sep 16, 2008 | Amana Refrigerators
Refrigerators Logo
1,098 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
